Huawei UMTS stick op Linpus Linux Lite
  • MacLinux
  • Laatst online: 27-03-2024
Netbook Aspire One
Linpus Lite v1.0.3.E
CPU intel(R) Atom(TM) N270 @ 1.6 Ghz
kernel 2.6.23.91w
mknod /dev/ttyUSB0 c 188 0
mknod /dev/ttyUSB1 c 188 1
mknod /dev/ttyUSB2 c 188 2
rmmod usb-storage
stop de UMTS stick in de USB-poort:
modprobe usbserial vendor=0x12d1 product=0x1446
lsusb -v
Bus 001 Device 005: ID 07ab:fcf6 Freecom Technologies
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x07ab Freecom Technologies
idProduct 0xfcf6
bcdDevice 1.00
iManufacturer 1 Freecom
iProduct 2 DataBar USB2.0
iSerial 3 907B18000337
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
MaxPower 200mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk (Zip)
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
wvidial
--> WvDial: Internet dialer version 1.60
--> Cannot get information for serial port.
--> Initializing modem.
--> Sending: AT+CPIN=0000
--> Sending: ATQ0
--> Re-Sending: AT+CPIN=0000
--> Modem not responding.
Hoe krijg ik een /dev/???? die wel reageert?
  • Mijzelf
Zit die wvidial wel naar /dev/ttyUSBx te kijken? Misschien de conf file er op nakijken?
  • MacLinux
ik heb een /usr/bin/wvdialconf bestand, maar dat is geen tekstbestand. Voor de rest geen wvdial.conf.
  • MacLinux
Ik keek even niet goed. Sorry. Onder /etc/ staat idd wvdial.conf die naar /dev/ttyUSB0 wijst.
Ik had zelfs een wvdial.huawei.conf gevonden en de originele door deze vervangen maar geen succes.
  • u_nix_we_all
Je dumpt een hele opsomming in de TS waar weinig commentaar bij staat, maar ik heb er wel wat vragen bij:
- waarom doe je handmatig een mknod ? (3x ?)
- die modprobe, ook handmatig ? En waarom daar handmatig vendor en device ID opgeven ?
- de lsusb -v laat niet je Huawei stick zien, alleen een Freecom mass storage device.
- waarom rmmod je usb-storage ?
- wat zeggen de logs (/var/log/messages) / dmesg
You don't need a parachute to go skydiving. You need a parachute to go skydiving twice.
  • MacLinux
- ergens gegoogled dat je apparaten moet aanmaken. Niet logisch maar kan ook geen kwaad.
/dev/ttyUSB* verschijnt niet uit zichzelf
- Ook dit commando heb ik meerdere sites gevonden. Allemaal met product en vendor erbij.
Bij deze het goede apparaat:
Bus 001 Device 003: ID 12d1:1446 Huawei
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x12d1 Huawei
idProduct 0x1446
bcdDevice 0.00
iManufacturer 3 Huawei Technologies
iProduct 2 HUAWEI Mobile
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 55
bNumInterfaces 2
iConfiguration 1 Huawei Configuration
bmAttributes 0xc0
Self Powered
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Omdat anders het apparaat als een mass storage apparaat wordt benaderd terwijl het als een modem benaderd moet worden.
/var/log/messages is leeg
dmesg:
Linux version 2.6.23.9lw (root@localhost.localdomain) (gcc version 4.1.2 20070925 (Red Hat 4.1.2-33)) #105 SMP PREEMPT Fri Jun 27 18:56:59 EDT 2008
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001f376000 (usable)
BIOS-e820: 000000001f376000 - 000000001f3bf000 (reserved)
BIOS-e820: 000000001f3bf000 - 000000001f46d000 (usable)
BIOS-e820: 000000001f46d000 - 000000001f4bf000 (ACPI NVS)
BIOS-e820: 000000001f4bf000 - 000000001f4f0000 (usable)
BIOS-e820: 000000001f4f0000 - 000000001f4ff000 (ACPI data)
BIOS-e820: 000000001f4ff000 - 000000001f500000 (usable)
BIOS-e820: 000000001f500000 - 0000000020000000 (reserved)
BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fed14000 - 00000000fed1a000 (reserved)
BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
501MB LOWMEM available.
Entering add_active_range(0, 0, 128256) 0 entries of 256 used
Zone PFN ranges:
DMA 0 -> 4096
Normal 4096 -> 128256
HighMem 128256 -> 128256
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0 -> 128256
On node 0 totalpages: 128256
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
Normal zone: 970 pages used for memmap
Normal zone: 123190 pages, LIFO batch:31
HighMem zone: 0 pages used for memmap
Movable zone: 0 pages used for memmap
DMI 2.4 present.
ACPI: RSDP 000FE020, 0024 (r2 INTEL )
ACPI: XSDT 1F4FE120, 0064 (r1 INTEL Napa 1 1000013)
ACPI: FACP 1F4FC000, 00F4 (r4 INTEL Napa 1 MSFT 1000013)
ACPI: DSDT 1F4F2000, 5D05 (r1 INTEL Napa 1 MSFT 1000013)
ACPI: FACS 1F488000, 0040
ACPI: SSDT 1F4FD000, 04C4 (r2 PmRef CpuPm 3000 INTL 20051117)
ACPI: HPET 1F4FB000, 0038 (r1 INTEL Napa 1 MSFT 1000013)
ACPI: APIC 1F4FA000, 0068 (r2 INTEL Napa 1 MSFT 1000013)
ACPI: MCFG 1F4F9000, 003C (r1 INTEL Napa 1 MSFT 1000013)
ACPI: ASF! 1F4F8000, 00A5 (r32 INTEL Napa 1 MSFT 1000013)
ACPI: SLIC 1F4F1000, 0180 (r1 INTEL Napa 1 MSFT 1000013)
ACPI: BOOT 1F4F0000, 0028 (r1 INTEL Napa 1 MSFT 1000013)
ACPI: PM-Timer IO Port: 0x408
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 7:12 APIC version 20
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Processor #1 7:12 APIC version 20
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
ACPI: HPET id: 0x8086a201 base: 0xfed00000
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 30000000 (gap: 20000000:c0000000)
swsusp: Registered nosave memory region: 000000000009f000 - 00000000000a0000
swsusp: Registered nosave memory region: 00000000000a0000 - 00000000000e0000
swsusp: Registered nosave memory region: 00000000000e0000 - 0000000000100000
swsusp: Registered nosave memory region: 000000001f376000 - 000000001f3bf000
swsusp: Registered nosave memory region: 000000001f46d000 - 000000001f4bf000
swsusp: Registered nosave memory region: 000000001f4f0000 - 000000001f4ff000
Built 1 zonelists in Zone order. Total pages: 127254
Kernel command line: ro root=LABEL=linpus vga=0x311 splash=silent loglevel=1 console=tty1 quiet nolapic_timer
bootsplash: silent mode.
mapped APIC to ffffb000 (fee00000)
mapped IOAPIC to ffffa000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Detected 1596.093 MHz processor.
Console: colour dummy device 80x25
console [tty1] enabled
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 504104k/513024k available (1904k kernel code, 7516k reserved, 543k data, 188k init, 0k highmem)
virtual kernel memory layout:
fixmap : 0xfff9b000 - 0xfffff000 ( 400 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xe0000000 - 0xff7fe000 ( 503 MB)
lowmem : 0xc0000000 - 0xdf500000 ( 501 MB)
.init : 0xc0369000 - 0xc0398000 ( 188 kB)
.data : 0xc02dc0d8 - 0xc0363fa4 ( 543 kB)
.text : 0xc0100000 - 0xc02dc0d8 (1904 kB)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
hpet0: 3 64-bit timers, 14318180 Hz
Calibrating delay using timer specific routine.. 3195.61 BogoMIPS (lpj=6391228)
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfe9fbff 00000000 00000000 00000000 0040c39d 00000000 00000001 00000000
monitor/mwait feature present.
using mwait in idle threads.
CPU: L1 I cache: 32K, L1 D cache: 24K
CPU: L2 cache: 512K
CPU: Physical Processor ID: 0
CPU: After all inits, caps: bfe9fbff 00000000 00000000 00003940 0040c39d 00000000 00000001 00000000
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
ACPI: Core revision 20070126
CPU0: Intel(R) Atom(TM) CPU N270 @ 1.60GHz stepping 02
SMP alternatives: switching to SMP code
Booting processor 1/1 eip 3000
Initializing CPU#1
Calibrating delay using timer specific routine.. 3191.98 BogoMIPS (lpj=6383964)
CPU: L2 cache: 512K
CPU1: Intel(R) Atom(TM) CPU N270 @ 1.60GHz stepping 02
Total of 2 processors activated (6387.59 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
checking TSC synchronization [CPU#0 -> CPU#1]: passed.
Brought up 2 CPUs
PM: Fastpoweoff 1.0
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: Using MMCONFIG
Setting up standard PCI resources
ACPI: EC: Look up EC in DSDT
ACPI Error (evxfregn-0109): lawson ec 06
[20070126]
ACPI: EC: GPE = 0x17, I/O: command/status = 0x66, data = 0x62
[20070126]
ACPI: System BIOS is requesting _OSI(Linux)
ACPI: If "acpi_osi=Linux" works better,
Please send dmidecode to linux-acpi@vger.kernel.org
ACPI: Interpreter enabled
ACPI: (supports S0 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI: Lawson Test 3
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI quirk: region 0400-047f claimed by ICH6 ACPI/GPIO/TCO
PCI quirk: region 0500-053f claimed by ICH6 GPIO
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P32_._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP1._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP2._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP3._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP4._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 *11 12)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 *11 12)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp: PnP ACPI: found 9 devices
ACPI: ACPI bus type pnp unregistered
SCSI subsystem initialized
libata version 2.21 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Time: tsc clocksource has been installed.
Clockevents: could not switch to one-shot mode:<6>Clockevents: could not switch to one-shot mode: lapic is not functional.
Could not switch to high resolution mode on CPU 1
Could not switch to high resolution mode on CPU 0
pnp: 00:01: ioport range 0x200-0x20f has been reserved
pnp: 00:01: ioport range 0x164e-0x164f has been reserved
pnp: 00:01: iomem range 0xe0000000-0xefffffff could not be reserved
pnp: 00:01: iomem range 0xfed1c000-0xfed1ffff could not be reserved
pnp: 00:01: iomem range 0xfed14000-0xfed17fff could not be reserved
pnp: 00:01: iomem range 0xfed18000-0xfed18fff could not be reserved
PCI: Bridge: 0000:00:1c.0
IO window: 5000-5fff
MEM window: 37300000-383fffff
PREFETCH window: 30000000-30ffffff
PCI: Bridge: 0000:00:1c.1
IO window: 3000-4fff
MEM window: 36300000-372fffff
PREFETCH window: 31000000-320fffff
PCI: Bridge: 0000:00:1c.2
IO window: 2000-2fff
MEM window: 35200000-362fffff
PREFETCH window: 32100000-330fffff
PCI: Bridge: 0000:00:1c.3
IO window: 1000-1fff
MEM window: 34100000-351fffff
PREFETCH window: 33100000-340fffff
PCI: Bridge: 0000:00:1e.0
IO window: disabled.
MEM window: disabled.
PREFETCH window: disabled.
ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1c.0 to 64
ACPI: PCI Interrupt 0000:00:1c.1[B] -> GSI 17 (level, low) -> IRQ 17
PCI: Setting latency timer of device 0000:00:1c.1 to 64
ACPI: PCI Interrupt 0000:00:1c.2[C] -> GSI 18 (level, low) -> IRQ 18
PCI: Setting latency timer of device 0000:00:1c.2 to 64
ACPI: PCI Interrupt 0000:00:1c.3[D] -> GSI 19 (level, low) -> IRQ 19
PCI: Setting latency timer of device 0000:00:1c.3 to 64
PCI: Setting latency timer of device 0000:00:1e.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 6, 262144 bytes)
TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 102k freed
Simple Boot Flag value 0x5 read from CMOS RAM was invalid
Simple Boot Flag at 0x44 set to 0x1
Total HugeTLB memory allocated, 0
io scheduler noop registered
io scheduler deadline registered (default)
Boot video device is 0000:00:02.0
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:1c.0:pcie00]
Allocate Port Service[0000:00:1c.0:pcie02]
Allocate Port Service[0000:00:1c.0:pcie03]
Allocate Port Service[0000:00:1c.1:pcie00]
Allocate Port Service[0000:00:1c.1:pcie02]
Allocate Port Service[0000:00:1c.1:pcie03]
Allocate Port Service[0000:00:1c.2:pcie00]
Allocate Port Service[0000:00:1c.2:pcie02]
Allocate Port Service[0000:00:1c.2:pcie03]
Allocate Port Service[0000:00:1c.3:pcie00]
Allocate Port Service[0000:00:1c.3:pcie02]
Allocate Port Service[0000:00:1c.3:pcie03]
vesafb: framebuffer at 0x20000000, mapped to 0xe0080000, using 2400k, total 7872k
vesafb: mode is 640x480x16, linelength=1280, pages=11
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 43971 bytes,<6>...found (640x480, 43983 bytes, v3).
Console: switching 1 lawson
consoles lawson 0
Console: switching consoles 1-17 to colour frame buffer device 78x25
fb0: VESA VGA frame buffer device
Real Time Clock Driver v1.12ac
hpet_resources: 0xfed00000 is busy
Linux agpgart interface v0.102
agpgart: Detected an Intel 945GME Chipset.
agpgart: Detected 7932K stolen memory.
agpgart: AGP aperture is 256M @ 0x20000000
[drm] Initialized drm 1.1.0 20060810
ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:02.0 to 64
[drm] Initialized i915 1.6.0 20060119 on minor 0
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
loop: module loaded
ata_piix 0000:00:1f.2: version 2.12
ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 17 (level, low) -> IRQ 17
PCI: Setting latency timer of device 0000:00:1f.2 to 64
scsi0 : ata_piix
scsi1 : ata_piix
ata1: SATA max UDMA/133 cmd 0x000101f0 ctl 0x000103f6 bmdma 0x000160a0 irq 14
ata2: PATA max UDMA/100 cmd 0x00010170 ctl 0x00010376 bmdma 0x000160a8 irq 15
ata2.00: ATA-5: P-SSD1800, Ver2.Y0C, max UDMA/66
ata2.00: 15761088 sectors, multi 0: LBA
ata2.00: configured for UDMA/66
scsi 1:0:0:0: Direct-Access ATA P-SSD1800 Ver2 PQ: 0 ANSI: 5
sd 1:0:0:0: [sda] 15761088 512-byte hardware sectors (8070 MB)
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1 sda2
sd 1:0:0:0: [sda] Attached SCSI disk
sd 1:0:0:0: Attached scsi generic sg0 type 0
PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:MOUE] at 0x60,0x64 irq 1,12
i8042.c: Warning: Keylock active.
i8042.c: Detected active multiplexing controller, rev 1.1.
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
ACPI: PCI Interrupt 0000:00:1f.3[B] -> GSI 17 (level, low) -> IRQ 17
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Starting balanced_irq
Using IPI No-Shortcut mode
RAMDISK: Compressed image found at block 0
EXT2-fs warning: checktime reached, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem).
TuxOnIce: No attempt was made to resume from any image that might exist.
Freeing unused kernel memory: 188k freed
Warning: unable to open an initial console.
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
Synaptics Touchpad, model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04771/0xa40000
input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input0
ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 16, io mem 0x38544400
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 8 ports detected
input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
Initializing USB Mass Storage driver...
mtrr: no more MTRRs available
usb 1-1: new high speed USB device using ehci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
usb 1-3: new high speed USB device using ehci_hcd and address 3
usb 1-3: configuration #1 chosen from 1 choice
usb 1-5: new high speed USB device using ehci_hcd and address 4
usb 1-5: configuration #1 chosen from 1 choice
scsi2 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
scsi3 : SCSI emulation for USB Mass Storage devices
scsi4 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 3
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ACPI: SSDT 1F380C90, 0239 (r2 PmRef Cpu0Ist 3000 INTL 20051117)
ACPI: SSDT 1F37FE10, 01C7 (r2 PmRef Cpu0Cst 3001 INTL 20051117)
ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
ACPI: Processor [CPU0] (supports 8 throttling states)
ACPI: SSDT 1F380F10, 00D0 (r2 PmRef Cpu1Ist 3000 INTL 20051117)
ACPI: SSDT 1F37EF10, 0083 (r2 PmRef Cpu1Cst 3000 INTL 20051117)
ACPI: CPU1 (power states: C1[C1] C2[C2] C3[C3])
ACPI: Processor [CPU1] (supports 8 throttling states)
input: Power Button (FF) as /devices/virtual/input/input2
ACPI: Power Button (FF) [PWRF]
input: Power Button (CM) as /devices/virtual/input/input3
ACPI: Power Button (CM) [PWRB]
input: Lid Switch as /devices/virtual/input/input4
ACPI: Lid Switch [LID0]
input: Sleep Button (CM) as /devices/virtual/input/input5
ACPI: Sleep Button (CM) [SLPB]
ACPI: AC Adapter [ACAD] (on-line)
ACPI: Battery Slot [BAT1] (battery present)
input: Video Bus as /devices/virtual/input/input6
ACPI: Video Device [OVGA] (multi-head: yes rom: yes post: no)
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.0: irq 16, io base 0x00006080
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ath_hal: module license 'Proprietary' taints kernel.
ath_hal: 0.9.17.1 (AR5212, RF5111, RF5112, RF2413, RF5413)
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
intel_rng: FWH not detected
ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 17 (level, low) -> IRQ 17
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.1: irq 17, io base 0x00006060
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
wlan: 0.8.4.2 (Atheros/multi-bss)
ath_rate_atheros: Version 2.0.1
Copyright (c) 2001-2004 Atheros Communications, Inc, All Rights Reserved
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:1d.2: irq 18, io base 0x00006040
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.3[D] -> GSI 19 (level, low) -> IRQ 19
PCI: Setting latency timer of device 0000:00:1d.3 to 64
uhci_hcd 0000:00:1d.3: UHCI Host Controller
uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
uhci_hcd 0000:00:1d.3: irq 19, io base 0x00006020
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 2 ports detected
ath_pci: 0.9.4.5 (Atheros/multi-bss)
ath_pci: Acer-5.3.2.14-2008-Sep-23
Linux video capture interface: v2.00
r8101 Fast Ethernet driver 1.008.08-2-1-NAPI loaded
ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 17 (level, low) -> IRQ 17
PCI: Setting latency timer of device 0000:02:00.0 to 64
eth0: Identified chip type is 'RTL8102E'.
eth0: RTL8101E at 0xe03fe000, 00:1e:68:97:6a:df, IRQ 17
ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 18 (level, low) -> IRQ 18
uvcvideo: Found UVC 1.00 device Acer Crystal Eye webcam (064e:d101)
PCI: Setting latency timer of device 0000:03:00.0 to 64
####################WLAN ID:001c ####################
Setting ah_eepromDetach
input: Acer Crystal Eye webcam as /devices/pci0000:00/0000:00:1d.7/usb1/1-5/1-5:1.0/input/input7
usbcore: registered new interface driver uvcvideo
USB Video Class driver (SVN r215)
SAMSoft library init ...
ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1b.0 to 64
ForteMedia SAM-Soft Library Loaded!
ALC INIT<7>usb-storage: device scan complete
scsi 3:0:0:0: Direct-Access HUAWEI TF CARD Storage PQ: 0 ANSI: 2
scsi 2:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
scsi 4:0:0:0: Direct-Access Freecom DataBar USB2.0 PMAP PQ: 0 ANSI: 0 CCS
scsi 2:0:0:0: Attached scsi generic sg1 type 5
sd 3:0:0:0: [sdb] Attached SCSI removable disk
sd 3:0:0:0: Attached scsi generic sg2 type 0
sd 4:0:0:0: [sdc] 2015232 512-byte hardware sectors (1032 MB)
sd 4:0:0:0: [sdc] Write Protect is off
sd 4:0:0:0: [sdc] Mode Sense: 23 00 00 00
sd 4:0:0:0: [sdc] Assuming drive cache: write through
sdc: unknown partition table
sd 4:0:0:0: [sdc] Attached SCSI removable disk
sd 4:0:0:0: Attached scsi generic sg3 type 0
sr0: scsi-1 drive
Uniform CD-ROM driver Revision: 3.20
sr 2:0:0:0: Attached scsi CD-ROM sr0
Marking TSC unstable due to: possible TSC halt in C2.
Time: hpet clocksource has been installed.
wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
wifi0: mac 14.2 phy 7.0 radio 10.2
wifi0: Use hw queue 1 for WME_AC_BE traffic
wifi0: Use hw queue 0 for WME_AC_BK traffic
wifi0: Use hw queue 2 for WME_AC_VI traffic
wifi0: Use hw queue 3 for WME_AC_VO traffic
wifi0: Use hw queue 8 for CAB traffic
wifi0: Use hw queue 9 for beacons
wifi0: Atheros 5212: mem=0x35200000, irq=18
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: HPC vendor_id 8086 device_id 27d0 ss_vid 0 ss_did 0
Load service driver hpdriver on pcie device 0000:00:1c.0:pcie02
pciehp: HPC vendor_id 8086 device_id 27d2 ss_vid 0 ss_did 0
pciehp: Device 0000:02:00.0 already exists at 2:0, cannot hot-add
pciehp: Cannot add device 0x2:0
Load service driver hpdriver on pcie device 0000:00:1c.1:pcie02
pciehp: HPC vendor_id 8086 device_id 27d4 ss_vid 0 ss_did 0
pciehp: Device 0000:03:00.0 already exists at 3:0, cannot hot-add
pciehp: Cannot add device 0x3:0
Load service driver hpdriver on pcie device 0000:00:1c.2:pcie02
pciehp: HPC vendor_id 8086 device_id 27d6 ss_vid 0 ss_did 0
Load service driver hpdriver on pcie device 0000:00:1c.3:pcie02
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
PM: Fastpoweroff, default profile added
Clocksource tsc unstable (delta = -165544920 ns)
wlan: mac acl policy registered
<ath_vap_create> sc_softled = 0
ath_vap_create: LED ON
r8101: eth0: link down
ath_stop_locked: LED OFF 2
aufs 20080505
Adding 1052248k swap on /dev/sda2. Priority:-1 extents:1 across:1052248k
ISO 9660 Extensions: Microsoft Joliet Level 1
ISOFS: changing to secondary root
  • CAPSLOCK2000
  • Laatst online: 18:21
CAPSLOCK2000
zie teletekst pagina 888
MacLinux schreef op dinsdag 20 september 2011 @ 18:47:
dat klinkt als:
casper@raki:~/ > apt-cache show usb-modeswitch
Package: usb-modeswitch
Description: mode switching tool for controlling "flip flop" USB devices
Several new USB devices have their proprietary Windows drivers onboard,
especially WAN dongles. When plugged in for the first time, they act
like a flash storage and start installing the driver from there. If
the driver is already installed, the storage device vanishes and
a new device, such as an USB modem, shows up. This is called the
"ZeroCD" feature.
On Debian, this is not needed, since the driver is included as a
Linux kernel module, such as "usbserial". However, the device still
shows up as "usb-storage" by default. usb-modeswitch solves that
issue by sending the command which actually performs the switching
of the device from "usb-storage" to "usbserial".
This post is warranted for the full amount you paid me for it.
  • u_nix_we_all
Ah, so. Ja nu begin ik het te begrijpen. Dat verklaart ook dat die serial device nog niet gevonden wordt.
  • MacLinux
Met modeswitch ben ik ook al bezig geweest maar onder yum kan ik dat pakket niet vinden.
Maar als het modem niet gevonden wordt heeft volgens mij modeswitch ook geen zin.
  • Mijzelf
MacLinux schreef op dinsdag 20 september 2011 @ 19:53:
Nou ja, volgens CAPSLOCK2000 is zo'n ding zonder modeswitch dus een mass storage device. Dus logisch dat er geen modem wordt gevonden.
  • u_nix_we_all
Is die modeswitch eenmalig ? Of moet die iedere keer gedaan worden na het inpluggen ? Als het eenmalig is zou je het even via een andere distro kunnen doen, of misschien zelfs een windows systeem.
Oh, hier is een static executable (zou moeten werken want heeft alle libraries meegecompileerd)
Edit: nevermind, die link is dood.
[ Voor 5% gewijzigd door u_nix_we_all op 21-09-2011 11:56 ]
  • CAPSLOCK2000
CAPSLOCK2000
Ik heb er zelf geen ervaring mee, maar ik denk dat het ding iedere keer dat je hem insteekt omgeswitched moet worden. Misschien dat het usb-modeswitcher pakket dat op een of andere automatiseert.
  • mrmartijn
  • Laatst online: 21-01 23:24
Als je de USB massaopslag "uitwerpt" dan schakelen die modems ook over naar serial mode. (in elk geval onder windows).
http://blog.brixit.nl - Programming, electronics and guitars. http://debestesupermarktpizza.nl - pizza
