Wifi KPN TG789vn traag sinds een paar week
  • halfgaar
  • Laatst online: 13-08 18:55
Wij hebben KPN 20/4 mbit internet met een Thomson TG789vn experiabox. Recentelijk is het wifi gedeelte erg traag geworden. De laatste tijd gebruiken we de laptop alleen met kabel en dat werkt wel goed.
Ik heb vandaag even een ping naar de experiabox aan laten staan en daar is het inderdaad te zien:
4 bytes from 192.168.2.254: icmp_seq=0 ttl=64 time=1.004 ms
64 bytes from 192.168.2.254: icmp_seq=1 ttl=64 time=0.790 ms
64 bytes from 192.168.2.254: icmp_seq=2 ttl=64 time=0.725 ms
64 bytes from 192.168.2.254: icmp_seq=3 ttl=64 time=0.714 ms
64 bytes from 192.168.2.254: icmp_seq=4 ttl=64 time=0.705 ms
64 bytes from 192.168.2.254: icmp_seq=5 ttl=64 time=20810.100 ms
64 bytes from 192.168.2.254: icmp_seq=6 ttl=64 time=19810.212 ms
64 bytes from 192.168.2.254: icmp_seq=7 ttl=64 time=18811.075 ms
64 bytes from 192.168.2.254: icmp_seq=8 ttl=64 time=17811.471 ms
64 bytes from 192.168.2.254: icmp_seq=9 ttl=64 time=16812.007 ms
64 bytes from 192.168.2.254: icmp_seq=10 ttl=64 time=15812.348 ms
64 bytes from 192.168.2.254: icmp_seq=11 ttl=64 time=14813.110 ms
64 bytes from 192.168.2.254: icmp_seq=12 ttl=64 time=13813.705 ms
64 bytes from 192.168.2.254: icmp_seq=13 ttl=64 time=12814.239 ms
64 bytes from 192.168.2.254: icmp_seq=14 ttl=64 time=11814.636 ms
64 bytes from 192.168.2.254: icmp_seq=15 ttl=64 time=10816.258 ms
64 bytes from 192.168.2.254: icmp_seq=16 ttl=64 time=9816.134 ms
64 bytes from 192.168.2.254: icmp_seq=17 ttl=64 time=8816.277 ms
64 bytes from 192.168.2.254: icmp_seq=18 ttl=64 time=7820.760 ms
64 bytes from 192.168.2.254: icmp_seq=19 ttl=64 time=6821.557 ms
64 bytes from 192.168.2.254: icmp_seq=20 ttl=64 time=5822.186 ms
64 bytes from 192.168.2.254: icmp_seq=21 ttl=64 time=4822.616 ms
64 bytes from 192.168.2.254: icmp_seq=22 ttl=64 time=3823.076 ms
64 bytes from 192.168.2.254: icmp_seq=23 ttl=64 time=2824.615 ms
64 bytes from 192.168.2.254: icmp_seq=24 ttl=64 time=1824.488 ms
64 bytes from 192.168.2.254: icmp_seq=25 ttl=64 time=824.612 ms
64 bytes from 192.168.2.254: icmp_seq=26 ttl=64 time=0.740 ms
64 bytes from 192.168.2.254: icmp_seq=27 ttl=64 time=1.634 ms
64 bytes from 192.168.2.254: icmp_seq=28 ttl=64 time=0.725 ms
De buren hebben dezelfde internetaansluiting en dezelfde router en zij rapporteren hetzelfde: wifi traag, draad prima.
Mijn theorie is dat KPN wellicht een update op de router heeft uitgerold die de boel ontregeld heeft.
Hebben meer mensen deze ervaring? Of weten mensen meer?
  • hostler
  • Laatst online: 15-10 13:14
hostler
Yeahhh dude!
Zit er KPN branded firmware op? Wat als je een firmware van Thomson zelf er op zet?
  • halfgaar
Er zit een KPN firmware op ja. Maar die kan ik toch niet zomaar vervangen? Dat kon vroeger nooit, in ieder geval. Ik moest altijd apparaten vinden die niet van KPN kwamen om zelf met de firmwares te klooien.
En KPN wil me dan niet meer helpen, denk ik.
  • hostler
hostler
Yeahhh dude!
halfgaar schreef op vrijdag 09 september 2011 @ 19:51:
Heb je deze router gekocht, of is hij te leen? Als hij te leen is mag je hem (denk ik) niet flashen, maar als je hem van KPN hebt gekocht mag je er mee doen wat je wilt. Zoek dit eerst eens uit voordat je begint met het flashen naar een firmware van Thomson zelf.
Verander het kanaal eens, grote kans dat het dan weer goed is.
  • Zenix
Zenix
BOE!
Kan je power reduction modus uitzetten bij wireless gedeelte? Dat is vaak een boosdoener.
  • halfgaar
Power reduction heb ik al uitgezet, hielp niets. Verder, volgens de wifi analyzer is het kanaal waar het op staat, 11, de beste. En de buren die het probleem dus ook hebben, draaien een heel ander kanaal. Maar, ik kan het proberen.
En of ik hem te leen heb, ik weet het eigenlijk niet. Ik heb door een fout van KPN deze internetaansluiting gekregen. De router zat ineens in de bus.
  • Zenix
Zenix
BOE!
halfgaar schreef op vrijdag 09 september 2011 @ 22:29:
Ik werk dagelijks met die dingen ( zonder beperkte firmware ) maar naast power reduction modus en kanaal manual veranderen kan je verder niet echt iets doen. Overigens werkt het draadloze gedeelte bij mijn 789vn prima, waar ik wel admin account voor heb gekregen van mijn ISP.
[ Voor 23% gewijzigd door Zenix op 09-09-2011 22:36 ]
  • IceM
  • Laatst online: 07:35
10 tegen 1 dat er een externe storingsbron zorgt voor de slechte wlan kwaliteit. Dat is vrij simpel te bepalen door het modem mee te nemen naar een andere locatie en daar de wlan functionaliteit te testen (en dan niet 10meter verderop maar op je werk bijvoorbeeld).
Je zou nog een factory reset van het modem kunnen doen (knopje aan de zijkant +- 15 sec inhouden totdat je een klik hoort) en kunnen spelen met de wlan kanalen.
  • Uthog
  • Laatst online: 20-08-2024
Alle aparaten die je bij een KPN aansluiting gebruikt(Experiabox en ITV ontvanger en Digitenne) zijn in bruikleen.
Kanaal wijzigen wil ook wel eens helpen.
