Request help for choosing Power Supply
  • 205 views
Hello everyone.
I just recently have chosen some computer compenents for my new custom built pc. But i don't know what power supply i should buy. Everyone i ask keeps saying the opposite.
These are my specs:
- MSI N560GTX-Ti Twin Frozr II/OC
- Intel® Core™ i5-2500
- LiteOn IHAS124
- Antec TriCool 120mm
- ASUS P8H61-M -=Rev.3.0=-
- Kingston ValueRAM 4 GB DDR3-1333
Please tell me what power supply i should take and the ammount of watt.
And if you have any other tips please tell me.
Thanks
  • Jerdek
  • Laatst online: 09-12-2024
ask the-mask @ [BBG aanschaf] Voedingen - Deel 28
Kennis maakt macht, kennis delen maakt machtige vriendschappen.
  • JJ Le Funk
JJ Le Funk
:twk
you need to sum the wattage and amperage used by all different components and make sure you leave some head room just to be sure and for future components. Note that amperage can differ per rail.
[ Voor 12% gewijzigd door JJ Le Funk op 25-08-2011 21:35 ]
d:)b :henk d:)b
  • dion_b
  • Laatst online: 02:31
dion_b
say Baah
Hi Gangboss,
GoT is a Dutch-language forum. We welcome visitors from everywhere, but do ask that you are able to read what has already been written here on a subject before you post your own questions. For that reason being able to read and write Dutch is really a requirement, otherwise everyone would be re-inventing the wheel constantly in various languages.
The question you asked here is addressed in a dedicated "Best Buy Guide" topic:
There is a lot of info there, and it is also the place to ask questions if the info itself isn't sufficient. If you can't read it, I'd recommend looking to an English-language forum instead.
Oslik, blyat! Oslik!
