Probleem met D-Link DIR 655 Router
  • Empulse
  • Laatst online: 25-08-2023
Sinds enkele dagen ondervind ik problemen met mijn dir-655 router. Het duurt ontzettend lang om websites te laden (transferring data, looking up, connecting bericht verschijnt voor 5-10 seconden).
Router log:
[INFO] Sun Aug 14 20:34:46 2011 Blocked incoming TCP connection request from 93.45.132.83:63308 to 82.176.32.250:55145
[INFO] Sun Aug 14 20:34:45 2011 Above message repeated 1 times
[INFO] Sun Aug 14 20:34:45 2011 UPnP renew entry 255.255.255.255 <-> 82.176.32.250:63765 <-> 192.168.0.197:63765 UDP timeout:0 'Teredo'
[INFO] Sun Aug 14 20:34:44 2011 Blocked incoming TCP connection request from 93.45.132.83:63308 to 82.176.32.250:55145
[INFO] Sun Aug 14 20:34:42 2011 Above message repeated 2 times
[INFO] Sun Aug 14 20:34:42 2011 Blocked incoming TCP packet from 66.169.117.28:49029 to 82.176.32.250:52755 as RST received but there is no active connection
[INFO] Sun Aug 14 20:34:41 2011 Log viewed by IP address 192.168.0.192
[INFO] Sun Aug 14 20:34:41 2011 Blocked incoming TCP connection request from 93.45.132.83:63308 to 82.176.32.250:55145
[INFO] Sun Aug 14 20:34:41 2011 Blocked incoming TCP packet from 24.229.211.92:54162 to 82.176.32.250:52719 as RST received but there is no active connection
[INFO] Sun Aug 14 20:34:40 2011 Blocked incoming TCP packet from 67.204.16.21:59847 to 82.176.32.250:52719 as RST:ACK received but there is no active connection
[INFO] Sun Aug 14 20:34:38 2011 Blocked incoming TCP packet from 71.14.16.196:60007 to 82.176.32.250:52835 as RST received but there is no active connection
[INFO] Sun Aug 14 20:34:35 2011 Allowed configuration authentication by IP address 192.168.0.192
[INFO] Sun Aug 14 20:34:33 2011 Blocked incoming TCP packet from 93.45.132.83:63235 to 82.176.32.250:58886 as RST received but there is no active connection
[INFO] Sun Aug 14 20:34:31 2011 Blocked incoming TCP packet from 98.163.214.252:26894 to 82.176.32.250:52661 as RST received but there is no active connection
[INFO] Sun Aug 14 20:34:30 2011 Blocked incoming TCP connection request from 93.45.132.83:63235 to 82.176.32.250:58886
[INFO] Sun Aug 14 20:34:26 2011 Above message repeated 3 times
[INFO] Sun Aug 14 20:34:25 2011 Blocked incoming ICMP packet (ICMP type 8) from 130.207.98.49 to 82.176.32.250
[INFO] Sun Aug 14 20:34:25 2011 Blocked incoming TCP connection request from 93.45.132.83:63235 to 82.176.32.250:58886
[INFO] Sun Aug 14 20:34:24 2011 Blocked incoming TCP packet from 204.83.50.17:4504 to 82.176.32.250:52719 as RST:ACK received but there is no active connection
[INFO] Sun Aug 14 20:34:24 2011 Blocked incoming TCP connection request from 93.45.132.83:63235 to 82.176.32.250:58886
[INFO] Sun Aug 14 20:34:23 2011 Above message repeated 1 times
[INFO] Sun Aug 14 20:34:22 2011 Blocked incoming ICMP error message (ICMP type 3) from 66.190.23.83 to 82.176.32.250 as there is no UDP session active between 82.176.32.250:51413 and 192.168.1.115:42322
[INFO] Sun Aug 14 20:34:17 2011 Blocked incoming TCP packet from 112.202.143.203:34415 to 82.176.32.250:52369 as RST received but there is no active connection
[INFO] Sun Aug 14 20:34:13 2011 Blocked incoming TCP packet from 71.162.227.169:62759 to 82.176.32.250:52719 as RST received but there is no active connection
[INFO] Sun Aug 14 20:34:10 2011 Blocked incoming TCP packet from 81.166.172.225:13758 to 82.176.32.250:20098 as RST:ACK received but there is no active connection
[INFO] Sun Aug 14 20:34:09 2011 Blocked incoming TCP packet from 81.82.55.97:54991 to 82.176.32.250:52719 as RST received but there is no active connection
[INFO] Sun Aug 14 20:34:08 2011 Blocked incoming TCP packet from 75.81.138.25:6881 to 82.176.32.250:52190 as RST received but there is no active connection
[INFO] Sun Aug 14 20:34:07 2011 Blocked incoming ICMP error message (ICMP type 3) from 82.13.19.201 to 82.176.32.250 as there is no UDP session active between 82.176.32.250:17664 and 10.0.1.11:48
[INFO] Sun Aug 14 20:34:05 2011 UPnP renew entry 255.255.255.255 <-> 82.176.32.250:63765 <-> 192.168.0.197:63765 UDP timeout:0 'Teredo'
[INFO] Sun Aug 14 20:34:02 2011 Above message repeated 2 times
[INFO] Sun Aug 14 20:34:00 2011 Blocked incoming TCP packet from 24.215.233.198:42414 to 82.176.32.250:64102 as RST received but there is no active connection
[INFO] Sun Aug 14 20:33:49 2011 Blocked incoming TCP packet from 99.231.66.63:63224 to 82.176.32.250:61014 as SYN:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:46 2011 Blocked incoming TCP packet from 81.166.172.225:13758 to 82.176.32.250:20098 as FIN:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:43 2011 Blocked incoming TCP connection request from 71.201.6.36:52497 to 82.176.32.250:51259
[INFO] Sun Aug 14 20:33:41 2011 Blocked incoming TCP packet from 76.226.176.120:26291 to 82.176.32.250:56295 as RST:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:37 2011 Blocked incoming TCP connection request from 71.201.6.36:52497 to 82.176.32.250:51259
[INFO] Sun Aug 14 20:33:34 2011 Blocked incoming TCP packet from 81.166.172.225:13758 to 82.176.32.250:20098 as FIN:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:34 2011 Blocked incoming TCP connection request from 71.201.6.36:52497 to 82.176.32.250:51259
[INFO] Sun Aug 14 20:33:34 2011 Blocked incoming TCP packet from 188.24.139.89:22372 to 82.176.32.250:60337 as RST received but there is no active connection
[INFO] Sun Aug 14 20:33:30 2011 Blocked incoming TCP packet from 189.138.147.189:62209 to 82.176.32.250:52719 as RST:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:29 2011 Blocked incoming TCP packet from 71.42.62.4:3291 to 82.176.32.250:52719 as RST received but there is no active connection
[INFO] Sun Aug 14 20:33:28 2011 Blocked incoming TCP packet from 81.166.172.225:13758 to 82.176.32.250:20098 as FIN:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:26 2011 Blocked incoming TCP packet from 71.14.16.196:60007 to 82.176.32.250:51636 as RST received but there is no active connection
[INFO] Sun Aug 14 20:33:25 2011 Blocked incoming TCP packet from 81.166.172.225:13758 to 82.176.32.250:20098 as FIN:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:22 2011 Blocked incoming TCP packet from 188.24.139.89:22372 to 82.176.32.250:60337 as SYN:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:21 2011 Blocked incoming TCP packet from 76.194.42.62:55439 to 82.176.32.250:52719 as RST:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:19 2011 UPnP renew entry 255.255.255.255 <-> 82.176.32.250:63765 <-> 192.168.0.197:63765 UDP timeout:0 'Teredo'
[INFO] Sun Aug 14 20:33:16 2011 Blocked incoming TCP packet from 24.215.233.198:42414 to 82.176.32.250:63492 as RST received but there is no active connection
[INFO] Sun Aug 14 20:33:16 2011 Blocked incoming TCP packet from 188.24.139.89:22372 to 82.176.32.250:60337 as SYN:ACK received but there is no active connection
[INFO] Sun Aug 14 20:33:14 2011 Blocked outgoing ICMP packet (ICMP type 3) from 192.168.0.194 to 8.8.8.8
Ik heb een aantal threads gelezen waarin mensen hetzelfde probleem beschrijven en aangeven dat dit door de update van de firmware komt. Ik heb de firmware echter een jaar geleden pas voor het laatst geupdate...
TK - Invisible Shield voor Macbook Pro 15'' Unibody in V&A
  • Sharky_NL
  • Laatst online: 09-04 12:47
Welke firmware versie heb?
Draai zelf hier v1.34 en heb de problemen die jij meldt totaal niet...
[ Voor 64% gewijzigd door Sharky_NL op 14-08-2011 20:53 ]
  • Empulse
1.31EUB02, maar dat is de laatste versie...
  • Sharky_NL
Welke Hardware versie heb je? ik heb hier de A3 met v1.34 draait als een trein.
