BSOD
  • 125 views
  • Dekar
  • Laatst online: 23:23
Ik krijg net opeens een blue screen. Volgens whocrashed ligt het aan 2 dingen, mn wifi driver en ntoskrnl.exe ofzo. Wat kan ik hieraan doen?
On Wed 10-8-2011 12:27:31 GMT your computer crashed
crash dump file: C:\Windows\Minidump\081011-23727-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7FD00)
Bugcheck code: 0xA (0x0, 0x2, 0x0, 0xFFFFF80003018477)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: netw5v64.sys (netw5v64+0x5B7D)
file path: C:\Windows\system32\drivers\netw5v64.sys
product: Intel® Wireless WiFi Link Adapter
company: Intel Corporation
description: Intel® Wireless WiFi Link Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: netw5v64.sys (Intel® Wireless WiFi Link Driver, Intel Corporation).
Google query: netw5v64.sys Intel Corporation IRQL_NOT_LESS_OR_EQUAL
The Beauty of the House is immeasurable; its Kindness infinite
  • TheVMaster
  • Laatst online: 01:40
TheVMaster
Moderator WOS
Eh.....wat dacht je van zelf zoeken op Google?
Volgens mij is dit niet de eerste keer dat je zonder even aan te geven wat je zelf al hebt ondernomen een topic opent. Ik zou ook even de regeltjes door lezen voordat je weer een topic maakt, dan weet je precies wat er hier wel en niet kan/mag en waaraan je startpost moet voldoen.
Het is hier namelijk op GoT de bedoeling dat je eerst zelf op zoek gaat naar een oplossing voor je probleem alvorens je hiervoor een topic aanmaakt. We zijn namelijk geen Helpdesk...
Dus als jij even laat zien dat je zelf ook inzet hebt getoond, zijn je mede-Tweakerts ook vast wel genegen om mee te denken.. O-)
Dit topic gaat dus op slot!
Ben je het hier niet mee eens? Reageren mag in Oneens met de actie van een moderator? Post het hier :+
DiscVault - Beheer je fysieke schijvencollectie | Beschikbaar als Self-Hosted, iOS (ook TestFlight) en Android (beta).
