add remote desktop server to active directory
  • 224 views
im kind of stuck with the followin problem, i have 2 windows 2003 servers.
- server-1 is a exchange and active directory server.
- server-2 nothing.
the thing is i want to do is that i can login on server-2 trough RDP with the users in the active directory in server-1.
i have no idea how to this, does anybody know how?
  • babbelbox
  • Laatst online: 11:42
1. Start learning about Active Directory
2. Add server-2 to the domain handled by server-1
Do you know where i can read up on this?
  • Appel
  • Laatst online: 09-10 00:01
I would suggest you leave this to your local IT administrators. But I can help you on your way with what you want to do.
You need to join server-2 to the active directory domain. Then you need to install the Terminal Services role. Do note that you will need Terminal Server CALs (Client Access Licenses) (Now called RDS-CAL) for every user or machine that will use the Terminal Server. (The Terminal Server comes with two admin CALS, these can be used by system administrators to administer the Terminal Server)
Also you might want to take in to consideration to user a Terminal Server profile for the user accounts that will use the Terminal server.
Verwijderd schreef op zaterdag 09 juli 2011 @ 16:54:
Microsoft TechNet is a good source of information. Also you can pretty much use Google :P
[ Voor 15% gewijzigd door Appel op 09-07-2011 17:16 ]
  • alt-92
alt-92
ye olde farte
Je kan gewoon nederlands lezen en schrijven hebben we al gezien.
