RUNAS op Terminal Server geeft error 1385 -> logon failure
  • mazz
  • Laatst online: 07-10 20:22
Hi!
Ik probeer op een terminal server een applicatie te draaien onder iemand anders zijn account met de runas.exe app van windows.
Blijkbaar heb ik de rechten niet goed staan want ik krijg de melding:
Logon failure: the user has not been granted the requested logon type at this computer
De gebruiker waaronder ik de app wil draaien heeft geen admin rechten, en dat wil ik graag zou houden.
Wel heeft hij de rechten 'Allow logon as batch job' , 'Allow log on through terminal services' en 'Allow log on locally'
Wat mis ik hier?
20 jaar, en wat had ik bereikt?
  • alt-92
alt-92
ye olde farte
Check je eventlogs dan.
  • mazz
Doe ik , maar staat min of meer hetzelfde in.
An account failed to log on.
Subject:
Security ID: DOMAIN\user
Account Name: user
Account Domain: DOMAIN
Logon ID: 0x90a3915e
Logon Type: 2
Account For Which Logon Failed:
Security ID: NULL SID
Account Name: user2
Failure Information:
Failure Reason: The user has not been granted the requested logon type at this machine.
Status: 0xc000015b
Sub Status: 0x0
Process Information:
Caller Process ID: 0x1f8
Caller Process Name: C:\Windows\System32\svchost.exe
Network Information:
Workstation Name: SERVER01
Source Network Address: ::1
Source Port: 0
Detailed Authentication Information:
Logon Process: seclogo
Authentication Package: Negotiate
Transited Services: -
Package Name (NTLM only): -
Key Length: 0
This event is generated when a logon request fails. It is generated on the computer where access was attempted.
The Subject fields indicate the account on the local system which requested the logon. This is most commonly a service such as the Server service, or a local process such as Winlogon.exe or Services.exe.
The Logon Type field indicates the kind of logon that was requested. The most common types are 2 (interactive) and 3 (network).
The Process Information fields indicate which account and process on the system requested the logon.
The Network Information fields indicate where a remote logon request originated. Workstation name is not always available and may be left blank in some cases.
The authentication information fields provide detailed information about this specific logon request.
- Transited services indicate which intermediate services have participated in this logon request.
- Package name indicates which sub-protocol was used among the NTLM protocols.
- Key length indicates the length of the generated session key. This will be 0 if no session key was requested.
http://www.ocf.berkeley.edu/~chunghau/?p=28
dit kwam ik ook nog tegen. Maar alles staat al ingesteld zoals daar beschreven.
Volgens mij is het ergens een optie die ik mis. Maar welke..
[ Voor 4% gewijzigd door mazz op 21-06-2011 14:08 ]
  • alt-92
alt-92
ye olde farte
Pak ProcessMonitor erbij en kijk dan welke se<PrivilegedRight> je mist ten opzichte van een werkende account?
Overigens staat er wel degelijk relevante info in je EventID, kijk maar naar het type logon.
Return Codes that cannot be converted with the net command
[ Voor 24% gewijzigd door alt-92 op 21-06-2011 14:16 ]
  • mazz
Ga ik doen.
Dit heb ik ook nog gevonden:
Note: User account running RunAs must be assigned "Act as part of the operation system" rights and also have "Create token" rights. User account used to run the process must be assigned "Logon as a batch job" rights.
Helaas zonder resultaat.
Ik ga nu aan de slag met de proc monitor
Edit: bedoel je deze proc monitor? http://technet.microsoft.com/en-us/sysinternals/bb896645 daar kan ik he tniet vinden. Kun je het iets uitgebreider beschrijven? Thnx!
[ Voor 20% gewijzigd door mazz op 21-06-2011 14:37 ]
  • alt-92
alt-92
ye olde farte
Je kan van een proces wat je start (of probeert te starten) loggen & nakijken met welke privileges je dat proces laat lopen.
Ik ga geen complete cursus ProcMon geven, maar je zou op z'n minst eens de properties van een proces kunnen bekijken bij Security.
