Dat lijkt me de beste rom atm.
En dan de Android 4.0.3 (Ice Cream Sandwich) + Sense UI 3.6 + Beats Audio versie voor mijn XE?
Ben inmiddels S-off en heb Clockwork recovery geïnstalleerd.
En dan volg ik de tut van XDA?
You need:•
HTC Sensation or
HTC Sensation 4G or
HTC Sensation XE S-OFF - Guide to S-off, Installing ClockWork, PermRoot, SuperCID & Flashing
•4EXT Touch Recovery from here
•Download ROM and place it on your SD card
•Download "Super Wipe" script & place it on your SD card (optionally if coming from earlier version of my ROM, obligatory if coming from stock or other custom ROM)
•Boot your phone in recovery mode (vol down + power)
•In main menu, select "install zip from sdcard"
•Select "choose zip from sdcard" and browse to the location of "Super Wipe" script
•Once again select "choose zip from sdcard" and browse to the location of Android Revolution ROM
•After flashing process is complete, reboot the device
En dan heb ik een volledig werkende rom met de nieuwste Sense en NL taal?
-edit-
Stap 3 permroot is dit gedeelte?
Step 3. To permanently root your
Sensation - (This means you will NOT LOSE ROOT on rebooting)
1. Download the file su-2.3.6.3-ef-signed.zip from here: DOWNLOAD
2. Copy su-2.3.6.3-ef-signed.zip to your SD card root folder (main folder of your memory card)
3. Start clockworkmod recovery (instructions below. See To Start Clockwork recovery)
4. BACKUP YOUR ROM USING CWM BEFORE ATTEMPTING ROOT!
5. Navigate to "Backup & Restore" using the Volume Down button and press select (power button to select) then select "Backup"
6. Select "install zip from sdcard" after backing up
7. Then select "Choose zip from sdcard"
8. Then select "su-2.3.6.3-efgh-signed.zip"
9. Then select "Yes - install su-2.3.6.3-efgh-signed.zip" to confirm
10. Then go back
11. Then reboot.
12. You're rooted!
Voor 36% gewijzigd door
coob op 28-01-2012 16:18
