Wat is: ntkrnlpa.exe (veroorzaker bluescreens)
  • stftweaker
  • Laatst online: 12-10 22:11
Beste medetweakers,
op deze vista laptop komen constant bluescreens hieronder kort overzichtje:
crash dump file: C:\Windows\Minidump\Mini052811-04.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x4DFD9)
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFFFFF81CC96A4)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\Minidump\Mini052511-16.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0x16FB0)
Bugcheck code: 0xE3 (0xFFFFFFFF895DA6C8, 0xFFFFFFFF847267B8, 0xFFFFFFFF895D9938, 0x3)
Error: RESOURCE_NOT_OWNED
file path: C:\Windows\system32\drivers\ntfs.sys
product: Besturingssysteem Microsoft® Windows®
company: Microsoft Corporation
description: NT-bestandssysteemstuurprogramma
Bug check description: This indicates that a thread tried to release a resource it did not own.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
even een korte greep is dit uit de 30 minidumps. Mijn vraag is welke drivers kunnen dit zijn? google geeft veel topics maar helaas geen uitsluitsel welke driver het is. misschien iemand met ervaring? of tips? memtest is al gedraaid en de hardeschijf is vervangen. gaat om verse installatie.
Heb zelf al memtest gedraaid hardeschijf vervangen gegoogled, drivers geupdate.
Alvast bedankt voor lezen/meedenken/posten :) en fijn weekend.
How are you doing?
  • Rupie
  • Laatst online: 07-10 15:12
Misschien dat het handig is als je ook even aangeeft wat voor Windows versie je gebruikt en dat je wat meer specs van je systeem geeft. ntkrnlpa.exe kan crashen door een slechte driver, aangezien het een verse installatie is zou dat natuurlijk kunnen. Er staan geen uitroeptekens in het apparaatbeheer?
Desktop | Server | Laptop
  • bloody
  • Laatst online: 08:31
bloody
0.000 KB!!
Ik had dit probleem laatst sinds een nieuwe versie van Avast (virusscanner). Na vervanging door security essentials van MS had ik geen dergelijke BSOD's meer.
Wat ik in jouw geval zou doen is even de Driver Verifier laten meelopen.
Bij de volgende BSOD krijg je zo (waarschijnlijk) meer informatie over de root cause :)
nope
