nieuwe aanwinst?
  • 250 views
CPU AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
Supports 45nm CPU
AMD® 140W CPU Support
AMD Cool 'n' Quiet™ Technology
Chipset AMD 880G/SB850
System Bus Up to 5200 MT/s ; HyperTransport™ 3.0
Memory 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
Expansion Slots 1 x PCIe 2.0 x16
2 x PCIe 2.0 x1
1 x PCI
VGA Integrated ATI Radeon™ HD 4250 GPU
- Supports HDMI™ Technology with max. resolution up to 1920 x 1080
- Supports Dual-link DVI with max. resolution up to 2560x1600 @60Hz
- Supports D-Sub with max. resolution 2048x1536 @85Hz
- Hybrid CrossFireX™ Support
- Dual independent displays support with HDMI / DVI and D-Sub
- Supports Microsoft® DirectX 10.1, OpenGL 2.0, Shader Model 4.1
- Hardware Decode Acceleration for H.264,VC-1, and MPEG-2
- Maximum shared memory of 1GB
Storage SB850 Chipset
6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
VIA VT6415 PATA controller
1 xUltraDMA 133/100 for up to 2 PATA devices
LAN Realtek® RTL8111E Gigabit LAN controller featuring AI NET 2
Audio ALC892 8-Channel High Definition Audio CODEC
- Supports 192kHz/ 24bit BD Lossless Sound
- Supports Jack-Detection, Multi-Streaming, and Front Panel Jack-Retasking (HD mode only)
- Optical S/PDIF Out ports at back I/O
USB - 2 x USB 3.0 ports (blue, at the back panel)
- 12 x USB 2.0/1.1 ports (8 ports at mid-board, 4 ports at back panel)
ASUS Unique Features ASUS Xtreme Design
ASUS Hybrid Processor -- TurboV EVO
- Turbo Unlocker, Auto Tuning, TurboV, CPU Level UP and GPU Boost
ASUS Hybrid Switch
- Core Unlocker
ASUS Hybrid OS -- Express Gate
ASUS Power Solutions
- 4+1 Phase Power Design
- ASUS Anti-Surge Protection
- ASUS EPU
ASUS Exclusive Features
- MemOK!
- Anti-surge protect
ASUS Quiet Thermal Solution
- ASUS Fanless Design: Heat sink solution
- ASUS Fan-Xpert
- ASUS Stack Cool 3
ASUS EZ DIY
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
Overclocking Features Precision Tweaker 2
- vCore: Adjustable CPU voltage at 0.003125V increment
- vChipset (VDDNB): Adjustable chipset voltage at 0.003125V increment
- vDIMM: Adjustable DRAM voltage at 0.015V increment
SFS (Stepless Frequency Selection)
- FSB tuning from 100MHz up to 550MHz at 1MHz increment
- PCI Express frequency tuning from 100MHz up to 150MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features 100% All High-quality Conductive Polymer Capacitors
Back Panel I/O Ports 1 x PS/2 Keyboard/Mouse Combo port
1 x DVI
1 x D-Sub
1 x HDMI
1 x S/PDIF Out
1 x LAN(RJ45) port
8 -Channel Audio I/O
2 x USB 3.0 ports (blue)
4 x USB 2.0/1.1 ports
Internal I/O Connectors 4 x USB 2.0 connectors (8 ports)
1 x COM connector
1 x IDE connector
6 x SATA 6Gb/s connectors
1 x CPU Fan connector
1 x Chassis Fan connectors
1 x Front panel audio connector
1 x S/PDIF Out Header
1 x Core Unlocker Switch
1 x MemOK! Button
1x LPT connector
24-pin ATX Power connector
4-pin ATX 12V Power connector
1 x System panel connector
BIOS 16 Mb Flash ROM , AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability WOL by PME,WOR by PME,WOR by Ring,PXE
Accessories 1 x Ultra DMA 133/100/66 cable
2 x Serial ATA 3 Gb/s cables
2 x Serial ATA 6 Gb/s cables
1 x Q-Connector (retail version only)
1 x Q-Shield
1 x User's manual
Support Disc Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities
Form Factor uATX Form Factor
9.6 inch x 9.6 inch ( 24.4 cm x 24.4 cm )
ATI HD 4250 grafische kaart tot 1024MB HDMI, VGA en DVI aansluiting
4GB (2x2GB) PC3-10666 1333Mhz DDR3 merk geheugen van Team
Seagate 1TB SATA3 ST31000524AS 7200 32mb harde schijf
LiteOn SATA black iHAS124 24x24x/DL8x8x/RAM - SATA - zwart- multi & dual layer DVD brander
geluidskaart
gigabit netwerkkaart
LC-Power Midi-Pro 909BSD display behuizing met een heel stille 220mm fan en een 600 watt voeding
Ik zit er over na te denken een nieuwe desktop pc aan te schaffen
laat jullie mening even weten :D O-) :*)
  • Staatslot
  • Laatst online: 11:38
Welkom op tweakers!
Mijn mening, wat wil je precies horen?
Knap dat je gespaard hebt en iets gaat kopen?
Wil je advies over een bepaald onderdeel of enkele onderdelen, dan is een onderbouwing wel zo gewenst.. En het belangrijkste van alles, wat ben je van plan met het systeem, wat moet het kunnen en wat heb je zelf al gezocht of overwogen?
Ten slotte een kleine tip, maak eens een wenslijst via de pricewatch met alle onderdelen erin en klik op "genereer rml" in die wenslijst. Als je dat op het forum plaatst, krijg je een mooi lijstje te zien dat bovendien aanklikbaar is. Dat voorkomt een hoop vervuiling en onoverzichtelijke informatie.
Succes!
Welkom op GoT.
Lees om te beginnen de *LET OP* - Wat moet ik kopen. Zodra je dat hebt gedaan en een wat uitgebreidere openingspost hebt getikt kun je in het volgende topic terecht: [BBG aanschaf] Gamesysteem (of een van de vele anderen).
Voor welke doeleinden wil je de pc bijvoorbeeld gaan gebruiken en wat is je budget? Als je de onboard graphics gaat gebruiken dan is een voeding van 600 watt bijvoorbeeld totaal niet zinvol. Het is sowieso verstandiger om te kiezen voor een kwaliteitsvoeding. Echter alles is weer afhankelijk van je budget.
Bekijk ook eens de BBG van deze en eventueel vorige maanden. reviews: Tweakers.net Best Buy Guide: editie mei 2011
[ Voor 16% gewijzigd door Verwijderd op 06-05-2011 22:49 ]
Ik zou eigenlijk gelijk 8GB nemen en een SSD. En die videokaart is ook nog niet echt goed voor games.
[ Voor 38% gewijzigd door Verwijderd op 06-05-2011 22:43 ]
Welkom op GoT :w
Losse "welke moet ik kopen?" topics zijn niet meer toegestaan op GoT, lees hiervoor *LET OP* - Wat moet ik kopen.
Dit betekent niet dat de vraag niet is toegestaan, je bent vrij om advies te vragen in de daarvoor bestemde (N)BBG topics, deze kun je vinden in Best Buy Guide overzichtstopic.
Dit topic gaat dicht. Maar zoals hierboven aangegeven ben je vrij om je vraag te stellen in de daarvoor bestemde topics
Verwijderd schreef op vrijdag 06 mei 2011 @ 22:41:
Zodra je dat hebt gedaan en een wat uitgebreidere openingspost hebt getikt kun je in het volgende topic terecht: [...]
Correctie: beperk je de volgende keer tot de relevante opties. Het zal mij een worst wezen wat de maximale resolutie van de VGA poort is, dat kunnen wij zelf ook wel afleiden aan een linkje naar de pricewatch :)
