• mazz
  • Laatst online: 07-10 20:22
Hi!
Ik heb een probleempje met exim i.c.m directadmin.
Exim geeft een 550 authentication required melding als ik mail stuur naar domeinen die op die server staan.
Spamd wil ook niet meer draaien en geeft
/usr/bin/perl: symbol lookup error: /usr/local/lib/perl/5.10.0/auto/Net/DNS/DNS.so: undefined symbol: Perl_Tstack_sp_ptr
Exim draait wel maar accept geen mail. Als ik vanuit localhost mail werkt het wel.
In de panic log krijg ik veel
2011-05-04 06:29:09 queue run: process 31253 crashed with signal 11 while delivering 1PzZFd-0001te-9Q
2011-05-04 06:44:09 queue run: process 32739 crashed with signal 11 while delivering 1Q2PTY-0007wX-7H
2011-05-04 06:44:09 queue run: process 32743 crashed with signal 11 while delivering 1Q86UB-00081o-TQ
2011-05-04 06:44:09 queue run: process 32744 crashed with signal 11 while delivering 1Q77ci-0004TZ-E2
2011-05-04 06:44:09 queue run: process 32745 crashed with signal 11 while delivering 1PvWVy-0006oI-74
2011-05-04 06:44:09 queue run: process 32747 crashed with signal 11 while delivering 1Q2Pgx-00008d-QP
2011-05-04 06:44:09 queue run: process 32748 crashed with signal 11 while delivering 1Pwv9e-0000rM-DM
2011-05-04 06:44:09 queue run: process 32749 crashed with signal 11 while delivering 1Q9F0U-0007Dr-0q
2011-05-04 06:44:09 queue run: process 32750 crashed with signal 11 while delivering 1PxGk5-0001FR-Nb
2011-05-04 06:44:09 queue run: process 32751 crashed with signal 11 while delivering 1PxL1Y-0003rC-Al
2011-05-04 06:44:09 queue run: process 32752 crashed with signal 11 while delivering 1QBozt-0007jd-GE
2011-05-04 06:44:09 queue run: process 32753 crashed with signal 11 while delivering 1Q110b-0003Fd-TR
2011-05-04 06:44:09 queue run: process 32756 crashed with signal 11 while delivering 1Q10zX-0003DF-Kb
2011-05-04 06:44:09 queue run: process 32757 crashed with signal 11 while delivering 1Q2Pi2-0000BD-BV
Iemand enig idee?
20 jaar, en wat had ik bereikt?
  • deadinspace
  • Laatst online: 22:06
deadinspace
The what goes where now?
Euh, undefined symbols, signal 11s, perl in /usr/local... Wat voor installatie is dat? En wat is er recentelijk aan veranderd?
  • CAPSLOCK2000
  • Laatst online: 23-10 12:22
CAPSLOCK2000
zie teletekst pagina 888
Ik gok dat je vanaf localhost niet langs de spamcheck hoeft en dat het daarom werkt.
Ik ben het helemaal eens met deadinspace dat dit geen standaard-installatie is.
Beheer je deze machine helemaal zelf of huur je het systeem kant-en-klaar?
Ik vermoed het tweede en dat je beheerder in zal moeten schakelen om dit probleem te verhelpen.
(Dit lijkt me geen configuratiefoutje aan jouw kant).
This post is warranted for the full amount you paid me for it.
  • Rainmaker
  • Laatst online: 14-07-2024
Rainmaker
RHCDS
Standard Signals
Signal Value Action Comment
SIGHUP 1 Term Hangup detected on controlling terminal
or death of controlling process
SIGINT 2 Term Interrupt from keyboard
SIGQUIT 3 Core Quit from keyboard
SIGILL 4 Core Illegal Instruction
SIGABRT 6 Core Abort signal from abort(3)
SIGFPE 8 Core Floating point exception
SIGKILL 9 Term Kill signal
SIGSEGV 11 Core Invalid memory reference
SIGPIPE 13 Term Broken pipe: write to pipe with no readers
Een segfault bij het afleveren van mail? Dan is inderdaad iets corrupt in je install, of je hebt brak geheugen. Gezien de "losse" perl installatie (is waarschijnlijk niet gecompiled voor de distro die je draait, bijvoorbeeld Mandrake RPM op Centos gezet), denk ik het 1e.
Eventueel kun je met strace -p eens kijken wat ervoor zorgt dat er een sigsegv optreed.
We are pentium of borg. Division is futile. You will be approximated.
  • Boudewijn
Boudewijn
omdat het kan
Hij heeft spamassassin enzo via DirectAdmin geinstalleerd met allemaal fijne custom scriptjes.
op deze manier http://help.directadmin.com/item.php?id=36 dus.
Ik vermoed dat er 2 perl versies naast elkaar leven op die bak ;).
