Mijn eerste custom gaming rig
  • 391 views
  • dragonhaertt
  • Laatst online: 22:36
Ik heb dit stuk in het engels geschreven in verband met posten op engelstalige forums.
My First Custom Gaming PC
So yesterday i build my first gaming pc. I was trying to make a small (micro ATX), quiet but fast pc for around 1000 eruo’s, so i started looking for the components.
#ProductPrijsSubtotaal
1Samsung Spinpoint F3 HD103SJ, 1TB€ 44,99€ 44,99
1Sony Optiarc AD-7260S Zwart€ 16,75€ 16,75
1Lian Li PC-A04 (Zwart)€ 90,-€ 90,-
1Lian Li C-02B€ 5,85€ 5,85
1Noctua NH-U9B SE2€ 45,50€ 45,50
3Noiseblocker NB-Multiframe S-Series MF12-S1, 120mm€ 15,01€ 45,03
1Seasonic M12II 620W€ 79,90€ 79,90
1Corsair F60 60GB€ 102,65€ 102,65
1Corsair XMS CMX4GX3M2A1600C9€ 41,50€ 41,50
1Conceptronic Multifunction front panel with eSATA€ 18,56€ 18,56
1AMD Phenom II X6 1100T Black Edition€ 191,90€ 191,90
1MSI 890GXM-G65€ 100,48€ 100,48
1MSI R6950 Twin Frozr III Power Edition/OC€ 262,80€ 262,80
Bekijk collectie
Importeer producten
Totaal€ 1.045,91
When the parts finally arrived i started assembling.
Afbeeldingslocatie: http://img815.imageshack.us/img815/793/img1280c.jpg
Afbeeldingslocatie: http://img192.imageshack.us/img192/8444/img1281n.jpg
I started with taking the case apart so i had some room to work. Then i installed my fans (which are really quiet! A good buy) and my optical bays.
Afbeeldingslocatie: http://img153.imageshack.us/img153/9892/img1283a.jpg
Afbeeldingslocatie: http://img839.imageshack.us/img839/3568/img1284n.jpg
Then i installed the cpu to the motherboard and inserted the motherboard in the case, i inserted all the other parts and it was time to do some cable management!
Afbeeldingslocatie: http://img824.imageshack.us/img824/4733/img1286ra.jpg
And now it’s time to do my first start up :D
All went well, except that I couldn’t get into bios as the screen was not displaying correctly. I fixed this later by trying a different dvi output and it worked :D
Set my BIOS to AHCI and installed my windows, after this I only needed to put on some software.
After installing the proper drivers and updating windows I ran into a problem. I couldn’t install service pack 1, and I still can’t. I gave up after trying a few solutions and having to reinstall windows twice. So SP1 is still waiting for me to install.
Then I found out there is no proper BIOS for the x6 1100T on my motherboard. I don’t know if this is a problem or not, so I need you guys to help me. As this is my first custom computer I like to hear some tips to tweak/update/overclock my pc. I also think I need to overclock my mobo to support my 1600ghz RAM.
So any help would be appreciated.
Thanks,
Dragonhaertt
  • Kecin
Kecin
Je keek.
Wat wil je nu? Dat wij gaan helpen het probleem van SP1 op te lossen? Beetje vage post namelijk.
Je Engels klopt op sommige plekken niet helemaal. I is altijd met hoofdletter, build moet built zijn, etc.
-edit-
Of wil je hulp bij het overclocken, welke Windows gebruik je eigenlijk? Of wil je gewoon je nieuwe pc showen?
[ Voor 22% gewijzigd door Kecin op 29-03-2011 16:24 ]
I'm not a number, I'm a free man! Geld over? Check m'n V&A
  • dragonhaertt
Nee hulp met SP1 hoeft niet, ik ben zelf nog naar een oplossing aan het zoeken. ik draai win 7 64 bit. Het liefste wil ik hulp met het tweaken van mijn nieuwe systeem.
gr Dragonhaertt
  • tarlitz
dragonhaertt schreef op dinsdag 29 maart 2011 @ 16:27:
gr Dragonhaertt
Wat wil je tweaken? Sowieso is dit dan het verkeerde forum om het in te plaatsen, er is een speciaal forum voor overclocking en tweaking. Daar staan ook de nodige tutorials met handige links. Waarom daarvoor deze hele openingspost nodig is snap ik ook niet, en dan neem je nog niet eens de moeite om het te vertalen naar het Nederlands...
  • dragonhaertt
ik heb dit vooral gepost voor algemene reacties/ideën. aangezien dit mijn eerste custom build is.
  • M2M
  • Laatst online: 20:55
M2M
medicijnman
dragonhaertt schreef op dinsdag 29 maart 2011 @ 16:50:
Doe dan in ieder geval de moeite om het in het Nederlands te schrijven.
Enfin, zo te zien past alles prima bij elkaar. Check nog wel even reviews van de SSD.
-_-
Dat is dan duidelijk, GoT is een discussieforum, Ik zie hier geen discussie in.
Het feit dat je startpost in het engels is getuigt ook van niet bijster veel inzet.
Dit topic gaat dicht.
