Hands-on: Brink
  • Spaiker
  • Laatst online: 29-09 13:38
Geachte Redactie :)
Eerste post hier, maar in dit nieuwsbericht staat dat Brink geen voip ondersteund. Voor zover ik lees op de fora van SD, is dit wel ondersteund, maar staat het enkel niet standaard geactiveerd. Ik kan mis zijn, maar ik ben er zelf 95% van overtuigd.
Het staat zelfs in een recente Q&A met Steve Hassel
When Rahdo recently talked about fireteams, he seems to imply that they are made up of 2 players, by saying things like "you can see either your friend or that player who is really good, and you can click on them and issue them an invite into your fireteam," and "the system is always looking behind the scenes for a map which has two slots." My question is, are 2 players the max limit a fireteam can be, or can it be larger? Also will it be possible to spawn on people from your fireteam like we've seen in other titles?
Fireteams in Brink support up to eight members, so theoretically the entire team could be in the same one. There are several ways to get a fireteam started. If you invite one of your friends to your match, Brink will automatically try to put them in the same fireteam as you. Similarly, if you join a friend on a server via the friends list, the game will try and do the same. You can also invite people who are in your match, or request to be invited to an existing fireteam via the scoreboard.
The biggest advantage of fireteams is that Brink will automatically enable VoIP chat for all of the members in it. Spawning on other members of your fireteam is something we explored early on, but ultimately decided against.
Bron:
http://www.brinkaddict.co...icts-qa-with-splashdamage
Spaiker
[ Voor 71% gewijzigd door Spaiker op 13-03-2011 16:58 ]
  • Tweakjur
  • Laatst online: 11:22
Tweakjur
Redacteur
Het niet aanwezig zijn van VoiP in algemene zin werd letterlijk gezegd op een event onlangs in Londen. Daarom staat het ook zo in de review.
Het zou inderdaad kunnen dat er wat onderscheid is tussen algemene voip, en voip in fireteams. Ik sluit niet uit dat het in die vorm inderdaad wel in het spel zit. Ik zie echter onvoldoende aanleiding om de tekst aan te passen, temeer omdat dit een preview is. Het antwoord zal pas met zekerheid gegeven kunnen worden als we een review-versie hebben en het zelf kunnen controleren.
(was voorheen JJJur, nickchange 4-8-2014)
