windows update[3.1]
  • 245 views
  • T.E.C.H.N.O
  • Laatst online: 14-10 07:01
ik heb een p1 150mhz met 128mb ram. :P
er staat nu win 3.1 op zou ik hem kunnen updaten naar 98?
  • sjaakwortel
  • Laatst online: 20:22
System requirements
[23]
* 486DX2/66 MHz or higher processor (Pentium processor recommended)
* 16 MB of RAM (24 MB recommended, it's possible to run on 8 MB machines with /nm option used during the installation process)
* At least 500 MB of space available on HDD. The amount of space required depends on the installation method and the components selected, but virtual memory and system utilities as well as drivers should be taken into consideration.
* Upgrading from Windows 95 (FAT16) or 3.1 (FAT): 140-400 MB (typically 205 MB).
* New installation (FAT32): 190-305 MB (typically 210 MB).
* Note 1: Both Windows 98 and Windows 98 SE can have significant problems associated with hard drives that are over 32 Gigabytes (GB) in size. This issue only occurs with certain Phoenix BIOS settings. A software update has been made available to fix this shortcoming.[24]
* Note 2: Also, both Windows 98 and Windows 98 SE are unable to handle hard drives that are over 137 GB in size with the default drivers, because of missing 48-bit LBA support - whole disc data corruption is likely. Third party patches are available to fix this shortcoming.[25]
* VGA or higher resolution monitor (640x480)
* CD-ROM or DVD-ROM drive (floppy install is possible but slow)
* Microsoft Mouse or compatible pointing device (optional).[26]
Like its predecessor, Windows 95, and its successor, Windows Millennium Edition (Me), users can bypass hardware requirement checks with the undocumented /im setup switch. This allows installation on computers with processors as old as the 80386.
Zou gewoon moeten werken, maar of het echt lekker werkt is een tweede.
  • Mit-46
  • Laatst online: 14-10 16:00
Ik zou zeggen, google de minimum specs van Win 98 en je weet het....
**Edit
Je hebt geluk met Sjaakwortel. :)
[ Voor 25% gewijzigd door Mit-46 op 23-02-2011 19:00 ]
  • Roytoch
  • Laatst online: 13-10 10:51
Roytoch
Nietes
Minimum Hardware Requirements for a Windows 98 Installation
Kort: Ja.
Lang: Wegkeilen man, oude troep :P
Welles
  • Henk007
  • Laatst online: 06-04-2025
Besteed niet teveel energie aan verouderde hardware inderdaad.
Kijk eventueel eens of er een magere Linux, bijvoorbeeld Damn Small Linux op draait, dan kun je er tenminste nof iets mee doen.
  • Nielson
peter13 schreef op woensdag 23 februari 2011 @ 18:57:
Daar kun je XP haast nog wel draaien met een beetje tweakwerk. Wat je echter ook kan proberen ipv 98, aangezien die niet echt veilig is, is een lichte linux distro, bv puppy
  • alt-92
alt-92
ye olde farte
Ja.
Maar topicstarts bestaande uit twee zinnen scoren hier niet zo hoog op de waarderingsmeter, dus ik stel voor dat je toch wat meer moeite gaat nemen bij het onderdeel eigen inzet alvorens je weer een topic opent.
In Het algemeen beleid staat uitgelegd waar een topic zo'n beetje aan moet voldoen, en ik denk dat je zelf ook wel inziet dat je huidige poging nou niet bepaald aansluit bij dat verwachtingspatroon :)
Hence een gratis hang/suitwerkvoorziening uit de voorraadkast.
