Lightbox 2 werkt niet
  • 275 views
Ik ben bezig met de website van me vader.
Helaas loop ik vast bij lightbox 2
Ik wil in een div lightbox2 afbeeldingen album zetten.
Ik heb nageleeft wat op de lightbox site staat:
How to Use
Part 1 - Setup
1.Lightbox 2 uses the Prototype Framework and Scriptaculous Effects Library. You will need to include these three Javascript files in your header (in this order).
<script type="text/javascript" src="js/prototype.js"></script>
<script type="text/javascript" src="js/scriptaculous.js?load=effects,builder"></script>
<script type="text/javascript" src="js/lightbox.js"></script>
2.Include the Lightbox CSS file (or append your active stylesheet with the Lightbox styles).
<link rel="stylesheet" href="css/lightbox.css" type="text/css" media="screen" />
3.Check the CSS and make sure the referenced prev.gif and next.gif files are in the right location. Also, make sure the loading.gif and close.gif files as referenced near the top of the lightbox.js file are in the right location.
Part 2 - Activate
1.Add a rel="lightbox" attribute to any link tag to activate the lightbox. For example:
<a href="images/image-1.jpg" rel="lightbox" title="my caption">image #1</a>
Optional: Use the title attribute if you want to show a caption.
2.If you have a set of related images that you would like to group, follow step one but additionally include a group name between square brackets in the rel attribute. For example:
<a href="images/image-1.jpg" rel="lightbox[roadtrip]">image #1</a>
<a href="images/image-2.jpg" rel="lightbox[roadtrip]">image #2</a>
<a href="images/image-3.jpg" rel="lightbox[roadtrip]">image #3</a>
No limits to the number of image sets per page or how many images are allowed in each set. Go nuts!
Maar ik krijg het niet werkend in die website. Het script staat in de website. Maar als ik de afbeelding aanklik activeerd die niet lightbox.
Als ik een nieuw index.html bestand aanmaak dan krijg ik hem wel werkend.
Ik hoop dat iemand mij kan helpen: *knip* (hier kan je de website vinden)
[ Voor 2% gewijzigd door MueR op 13-02-2011 20:03 ]
  • MueR
  • Laatst online: 20:57
MueR
Admin Devschuur® & Discord
is niet lief
Zoals RobIII in "Hulp script" vertelde, zo werken we hier niet. Lees die topics die RobIII je gaf nou eens goed door.
Anyone who gets in between me and my morning coffee should be insecure.
