P67 Sabertooth Won't Boot.
  • 252 views
I recently used tweakers.net to buy all components for a new eyefinity system!
and I just put all the components together and now it doesn't work :(
This is what I got:
Processor: i5 2500k
Mobo: Asus P67 Sabertooth
Ram: G.Skill 8GB 1333
GPU Asus HD6950 x2
PSU: Corsair HX750W
SSD: Corsair Force 120GB
HDD: External 2TB WD Elements
Case: CM 690-ii Advanced (I know its a tight fit, had to cut cost for the triple monitors)
3x Samsung 2443BW
I tried building the mobo outside the case with only the essentials (1ram stick in the correct slot, 1 gpu, keyboard,mouse,screen.) connected but still nothing. I'm 100% sure all the cables and wires are correctly connected. I also tried to see if the psu might be faulty by testing it with a paperclip and a case fan but it worked fine.I tried to install a mobo speaker but could only get my hands on a 2 pin speaker while the mobo wants a 4 pin speaker. so now I am out of ideas!
the reason i post here is because I find it kinda hard to believe that a mobo that has military standards is dead on arrival. Could it perhaps be that the ram sticks are the problem? i'm asking you guys to share your experience if you have build a similar system and can give me any advice on what to do next!
  • thijszor
  • Laatst online: 30-08 13:51
what kind of ram do you use? what voltage does it have, is it specific SB mem?
  • Nelfrikandel
  • Laatst online: 16-08 22:52
Are you aware of the fact that the P67 chipset isn't working up to it's standards?!
http://event.asus.com/2011/SandyBridge/notice/
Maybe this is causing your problems!?
  • fsfikke
fsfikke
j3ffr3-y schreef op zondag 13 februari 2011 @ 16:13:
Dat heeft er dus echt totaal niets mee te maken. Net als dat het niet werken van de radio in een Toyota niets te maken zou hebben met een terugroepactie voor de gaspedalen.
@TS: The only way to figure out if some of the parts are DOA is by installing them one by one in a working system.
[ Voor 11% gewijzigd door fsfikke op 13-02-2011 16:23 ]
  • Edmin
  • Laatst online: 21:25
Edmin
Crew Council
get on my horse!
Hi there Kimambo.
Unfortunately, Dutch is mandatory on our forums. Postings in English are not allowed, since they can form a barrier for our local (Dutch) target audience. I'm sorry, but I have no choice but to close this thread.
