Ubuntu 10.10 Cd drive doet raar
Hallo
Mijn cd drive doet nogal raar nadat ik ubuntu geinstalleerd heb. Hij gaf aan dat alle CD's die ik erin deed leeg waren.
Nu had ik met brasero een cd gebrand en dat werkte gewoon.
De Cd drive is zichtbaar in 'places' maar zodra ik er nu een cd (audio,data) in doe verdwijnt ie uit 'places'.
Als ik dan vervolgens Dmesg intyp krijg ik dit:
77.724004] [drm:intel_prepare_page_flip] *ERROR* Prepared flip multiple times
[ 77.724031] [drm:intel_prepare_page_flip] *ERROR* Prepared flip multiple times
[ 77.724041] [drm:intel_prepare_page_flip] *ERROR* Prepared flip multiple times
[ 77.724051] [drm:intel_prepare_page_flip] *ERROR* Prepared flip multiple times
[ 80.607031] lib80211_crypt: registered algorithm 'WEP'
[ 266.394635] sr 1:0:0:0: [sr0] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 266.394644] sr 1:0:0:0: [sr0] Sense Key : Illegal Request [current]
[ 266.394651] sr 1:0:0:0: [sr0] Add. Sense: Logical block address out of range
[ 266.394659] sr 1:0:0:0: [sr0] CDB: Read(10): 28 00 00 00 00 00 00 00 01 00
[ 266.394672] end_request: I/O error, dev sr0, sector 0
[ 266.394679] Buffer I/O error on device sr0, logical block 0
[ 266.397981] sr 1:0:0:0: [sr0] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 266.397987] sr 1:0:0:0: [sr0] Sense Key : Illegal Request [current]
[ 266.397993] sr 1:0:0:0: [sr0] Add. Sense: Logical block address out of range
[ 266.398000] sr 1:0:0:0: [sr0] CDB: Read(10): 28 00 00 00 00 00 00 00 01 00
[ 266.398011] end_request: I/O error, dev sr0, sector 0
[ 266.398015] Buffer I/O error on device sr0, logical block 0
[ 266.401284] sr 1:0:0:0: [sr0] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 266.401291] sr 1:0:0:0: [sr0] Sense Key : Illegal Request [current]
[ 266.401298] sr 1:0:0:0: [sr0] Add. Sense: Logical block address out of range
[ 266.401305] sr 1:0:0:0: [sr0] CDB: Read(10): 28 00 00 00 00 00 00 00 01 00
[ 266.401316] end_request: I/O error, dev sr0, sector 0
[ 266.401320] Buffer I/O error on device sr0, logical block 0
[ 266.404692] sr 1:0:0:0: [sr0] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 266.404699] sr 1:0:0:0: [sr0] Sense Key : Illegal Request [current]
[ 266.404705] sr 1:0:0:0: [sr0] Add. Sense: Logical block address out of range
[ 266.404713] sr 1:0:0:0: [sr0] CDB: Read(10): 28 00 00 00 00 00 00 00 01 00
wat te doen?
Weet niet zeker maar probeer eens in /etc/X11/xorg.conf.d/--.intel.conf
Option "DRI" "false"
Dat is voor je xorg , maar misschien heeft het met elkaar te maken.
In ieder geval heb je een probleem met je dri (Direct Rendering Infrastructure)
Die page flipping error, dat is een verbeteraar voor 2/3D.
Heb er niet veel verstand van ofzo, dat je dat niet denkt :+
Dankjewel voor de reactie.
Ik probeer windows xp er weer op te krijgen, maar dat is nu dus niet mogelijk ivm met de cd drive problemen, enig advies hoe ik het anders kan doen?
Wil windows ook niet booten vanaf cd?
Miischien in de bios de opstart-volgorde veranderen!
Cd als eerste, alhoewel lijkt mij dat het goed staat.
Even nakijken kan geen kwaad.
  • mace
  • Laatst online: 23-10 16:57
mace
Sapere Aude
Als je windows CD het ook niet doet is je cdromdrive w.s. gewoon stuk, of zit er een kabeltje los o.i.d.
Verwijderd schreef op donderdag 10 februari 2011 @ 19:49:
Nuttig, maar dat heeft dus totaal niks te maken met de cdrom. ;)
[ Voor 73% gewijzigd door mace op 11-02-2011 00:31 ]
mace schreef op vrijdag 11 februari 2011 @ 00:30:
Ja, je hebt gelijk.
De reden dat ik dat schreef was omdat ik de foutmelding zag staan.
Omdat Djonkman al melde
dacht ik misschien hebben die 2 met elkaar te maken, de DRI fout en het niet starten van de cd.
Misschien erg kort door de bocht 8)7
Cd volgorde staat goed in de bios.
Waarom zou ik een cd kunnen branden op deze laptop, die cd kunnen gebruiken op andere systemen zonder problemen als de cd drive stuk is? of mis ik iets?
Maar er is nu dus geen manier om XP hierop te krijgen? want ik heb dit probleem pas sinds ik ubuntu installeerde
Verwijderd schreef op vrijdag 11 februari 2011 @ 13:24:
Ja het is mogelijk dat je 2 lasers hebt, 1 om te branden en 1 om te lezen.
Als de laser om te lezen kapot is kun je soms nog gewoon branden, en in jouw geval lijkt het daarop!
opties:
Brander eruit, testen op een ander systeem.
Brander vervangen door nieuw exemplaar.
heb hem aan me ma der desktop gehangen, werkt perfect, de cd drive. Audio cd's, data cd's alles pakt ie.
  • Big Womly
  • Laatst online: 22-10 07:45
Big Womly
Live forever, or die trying
Als je boot vanaf een CD, dan heeft je huidig OS er toch niets met te maken? Dat is nog niet eens opgestart.
Als de CD-ROM het wel doet in een andere PC, en bij jou niet, nog voor dat je OS geladen wordt, zou ik denken aan kabel of moederbord.
When you talk to God it's called prayer, but when God talks to you it's called schizophrenia
^^ inderdaad en anders zou ik het ook zo niet weten!
  • Room42
Is het een IDE of SATA drive (ik weet even niet meer wat een srX-device is ;))? Want ik wilde voorstellen om hem eens aan een andere controller te hangen.
Room42 schreef op vrijdag 11 februari 2011 @ 17:12:
Hij valt onder de IDE controller, en als connection type staat er SCSI
  • mace
mace
Sapere Aude
Je kan helemaal niet XP installeren vanuit ubuntu. Je moet opstarten vanaf de XP cd.
Dat probeer ik ook...
  • mace
mace
Sapere Aude
Maar dat heeft dus geen zak met ubuntu te maken.
