could not load OpenGL subsystem in Medal of Honor met HD5770
--- Common Initialization ---
Medal of Honor Allied Assault 1.11 win-x86 Mar 5 2002
----- FS_Startup -----
Current search path:
C:\Games\EA GAMES\MOHAA/main
C:\Games\EA GAMES\MOHAA\main\pak6.pk3 (104 files)
C:\Games\EA GAMES\MOHAA\main\Pak5.pk3 (259 files)
C:\Games\EA GAMES\MOHAA\main\Pak4.pk3 (593 files)
C:\Games\EA GAMES\MOHAA\main\Pak3.pk3 (669 files)
C:\Games\EA GAMES\MOHAA\main\Pak2.pk3 (4722 files)
C:\Games\EA GAMES\MOHAA\main\Pak1.pk3 (772 files)
C:\Games\EA GAMES\MOHAA\main\Pak0.pk3 (11175 files)
18294 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
execing configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 16
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' ): succeeded
...setting mode 9: 1600 1200 FS
...using colorsbits of 32
...calling CDS: failed, bad mode
...trying next higher resolution: failed, bad mode
...restoring display settings
...registered window class
...created window@0,0 (1606x1228)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...65 PFDs found
...hardware acceleration found
...PIXELFORMAT 2 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Dit probleem heb ik als ik Medal of Honor Allied Assault opstart. In alle andere resoluties werkt het gewoon wel, behalve in 1600x900.
Ik heb al sinds gister de nieuwste drivers erop staan maar deze game werkt niet. :'(
sorry maar wat is hier de bedoeling van? Misschien handig om wat meer informatie te geven? En wat heb je zelf al allemaal geprobeerd? Het wordt hier vaker aangegeven, we zijn geen advies bureau, je moet zelf ook wat proberen.
En de resolutie 1600x900 heb ik persoonlijk nog nooit van gehoord. Misschien handig om de resolutie op 1680x1050 te zetten? Wat kan je monitor aan?
  • rscheper
  • Laatst online: 13:54
Misschien wat meer informatie inderdaad? Windows versie? Welke resolutie staat je pc ingesteld & wat kan je monitor max aan?
EDIT: DirectX up to date? MoH geupdated? Ik zie een versie 1.11, maar ik heb het idee dat er ook een 1.2 is.
[ Voor 31% gewijzigd door rscheper op 06-02-2011 21:23 ]
-amd 965 64 bit
-windows 7 64 bit
-drivers opnieuw geïnstalleerd+nieuwste gedownload
-wou dus medal of honor spelen op m'n nieuwe 1920x1080 monitor
-snelkoppeling gemaakt kijken of dat misschien pakt
En op alle andere resoluties werkt het gewoon...
MOH 1.11 is de nieuwste bij mijn weten? Als er een nieuwe is hoor ik het graag zou natuurlijk graag native willen.
  • rscheper
je wil spelen op 1920bij1080.. en hij doet het alleen niet bij 1600x900...?
Ja dat klopt, ik wil dus het liefst spelen op 1080p maar de game is nogal oud en ondersteund dus max 1600x900 en dat is de enige die niet werkt.
Heb het eindelijk aan de praat gekregen... viaviaviavia google resultaten zeiden dat je in de config file een custom resolutie kon instellen... maar dat werkte niet.
Toen heb ik in de console getypt:
seta r_mode "-1"
seta customheight "1080"
seta customwidth "1920"
ik weet niet meer of het die volgorde was precies, maar dit maakt een custom mode aan genaamd -1 en dan werkt het :)
  • kipjr
  • Laatst online: 19-08 15:10
Ik heb dit probleem ook gehad bij Quake III Arena. Het probleem ligt bij je config file van je spel. Eventjes verwijderen en dan spel starten (dan wordt hij in default mode weer aangezet). Dit moet het oplossen. Maar je kan het ook helemaal doorspitten setting voor setting totdat je game het weer doet.
