[FOOBAR]wil audio CD niet converteren naar FLAC
  • kevinvdw
  • Laatst online: 11-10 20:58
dag,
ik ben bezig mijn CD's te rippen naar FLAC, maar dit lukt niet(meer). Ik gebruik foobar om mijn muziek af te spelen, en zou graag hier de rips ook in doen. Dit is wat ik krijg:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
12 out of 12 tracks converted with major problems.
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\01. The Pretender.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "C:\Users\*\Music\[FLAC]CD's\_\_\01. The Pretender.flac"
  Additional information:
  Encoder stream format: 44100Hz / 2ch / 16bps
  Command line: "C:\Program Files (x86)\Exact Audio Copy\flac.exe" -s --ignore-chunk-sizes -5 - -o "01. The Pretender.flac"
  Working folder: C:\Users\*\Music\[FLAC]CD's\_\_\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\02. Let It Die.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "C:\Users\*\Music\[FLAC]CD's\_\_\02. Let It Die.flac"
  Command line: "C:\Program Files (x86)\Exact Audio Copy\flac.exe" -s --ignore-chunk-sizes -5 - -o "02. Let It Die.flac"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\03. Erase-Replace.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "C:\Users\*\Music\[FLAC]CD's\_\_\03. Erase-Replace.flac"
  Command line: "C:\Program Files (x86)\Exact Audio Copy\flac.exe" -s --ignore-chunk-sizes -5 - -o "03. Erase-Replace.flac"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\04. Long Road To Ruin.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "C:\Users\*\Music\[FLAC]CD's\_\_\04. Long Road To Ruin.flac"
  Command line: "C:\Program Files (x86)\Exact Audio Copy\flac.exe" -s --ignore-chunk-sizes -5 - -o "04. Long Road To Ruin.flac"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\05. Come Alive.wav"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\06. Stranger Things Have Happened.wav"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\07. Cheer Up, Boys (Your Make Up Is Running).wav"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\08. Summer's End.wav"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\09. Ballad Of The Beaconsfield Miners.wav"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\10. Statues.wav"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\11. But, Honestly.wav"
Source: "C:\Users\*\Music\[FLAC]CD's\Foo Fighters\12. Home.wav"
Afbeeldingslocatie: http://img88.imageshack.us/img88/7521/convertflac.png
Ik weet dat ik de vorige keer hetzelfde probleem had, en ik dacht dat het iets met de naamgeving te maken had(idd, ik had het moeten opschrijven). Ik weet nog dat het me na lang zoeken gelukt was, maar dat ik met een andere programma de tags moest aanvullen. Ik ben nu weer op zoek, maar google is blijkbaar mijn vriend niet meer, ik hoop dat iemand van jullie dat wel is ;)
edit: Na tientallen keren proberen lukt het natuurlijk wel net na ik dit bericht getypt had. Het is gelukt door de FLAC-map te hernoemen en dan naar flac.exe te verwijzen in die map. Weet iemand hoe dit komt? Of waar het probleem zit? Zou nero drive speed er voor iets tussen kunnen zitten, want die heb ik nu ook uitgezet?
Graag de vraag om dit topic nog even open te laten moest er iemand het probleem doorgrond hebben, want zou het graag weten.
edit2: bij sommige CD's heeft hij nog altijd het probleem, maar dan maar voor 1 track. Eens die track opnieuw rippen volstaat, maar leuker zou zijn als hij het direcht goed doet?
[ Voor 4% gewijzigd door kevinvdw op 18-01-2011 10:06 ]
