PII 266 overklokken
  • 172 views sinds 30-01-2008
  • Ivke
  • Registratie: December 1999
  • Laatst online: 07-01-2003
Wat is max haalbaar?
Moederbord is p2b
Thanks,
"I'd change the world but God won't give me the source code"
  • php
php
Hoe hard kan mijn auto?
Het is allemaal afhankelijk van diverse omstandigheden, koeling, geheugen, timing, en geluk. Gewoon proberen, dus. Je merkt het gauw genoeg als het niet meer hoger kan.
  • Yigal76
  • Laatst online: 16-04 21:49
Jouw auto kan 100 kilometer per uur.
  • Mastermind
  • Laatst online: 02-08 20:09
Je kunt 696MHz halen...
Pentium II 266 Results....
Total Entries in Database for Pentium II 266 - 9
Average overclocked speed - 394 Mhz
<table width="450" Border="1" cellspacing="0" cellpadding="3">
<TR>
<TD>FPO/Batch #</TD>
<TD>Speed</TD>
<TD>Volts</TD>
<TD>S Code</TD>
<TD>Plant</TD>
<TD>Week</TD>
<TD>Motherboard</TD>
<TD>Notes</TD>
<td>ID</td>
</TR>
<TR>
<TD>18330107-0239</TD>
<TD>696</TD>
<TD>3.00</TD>
<TD>SL2W7</TD>
<TD>PHILIPPINES</TD>
<TD>33</TD>
<TD>ASUS P3c2000</TD>
<TD>4*174, Creative Riva TNT 2 Ultra (AGP in 87MHz)
CPU = 32C
Grafix = 20C
Chassi = AOPEN HX08
COOLING:
Custom made Watercooling
Dual 72Watt pletiers
on the CPU
Gfx with one 72 Watt
pletier and PPGA heatsink w.fan + 8 80x80 fans mounted around the box!
IŽm using 5,5ns SDRAM (181MHz)
The original power supply on 300 Watt gets help from a external 400 Watt power supply!
It goes 100% stable
I have also tryed 720MHz (180x4) but then I had to run the gfx in 60MHz, the computer would not boot
This projekt was sponsored by my school !!</TD>
<TD>3857</TD>
</TR>
<TR>
<TD>18330108-0272</TD>
<TD>448</TD>
<TD>2.00</TD>
<TD>SL2W7</TD>
<TD>33</TD>
<TD>  </TD>
<TD>AsusP2B.128 MB PS100 run at 112 FSB.Multiplier locked at 4.No boot at 133.MB temp 28C.Big heatsink w/3 fans and 9cm fan in front+1 on top of CPU.</TD>
<TD>3124</TD>
</TR>
<TR>
<TD>98310938-0302</TD>
<TD>400</TD>
<TD>2.05</TD>
<TD>SL2W7</TD>
<TD>Malay</TD>
<TD>31</TD>
<TD>  </TD>
<TD>Single Fan Heatsink Used, Still in Cartridge. Standard settings in BIOs 100mhz FSB. Runs flawless.</TD>
<TD>3173</TD>
</TR>
<TR>
<TD>98170694-0613</TD>
<TD>350</TD>
<TD>2.80</TD>
<TD>SL2QB</TD>
<TD>MALAY</TD>
<TD>41</TD>
<TD>  </TD>
<TD>set 3.5x100, would post but not load windows, set cach latency to 1 and booted to windows, now playing quake. these abit boards are real screamers. dont knw the actual week.</TD>
<TD>3193</TD>
</TR>
<TR>
<TD>R7310206-192</TD>
<TD>349</TD>
<TD>2.95</TD>
<TD>SL265</TD>
<TD>Phillipines</TD>
<TD>31</TD>
<TD>SOYO SY-6VBA-133</TD>
<TD>Klamath .35 micron chip.Dual fan w/ heatsink. Will not allow any more OC'ing.</TD>
<TD>3347</TD>
</TR>
<TR>
<TD>Y8200001-0821</TD>
<TD>333</TD>
<TD>2.80</TD>
<TD>SL2HC</TD>
<TD>Ireland</TD>
<TD>1</TD>
<TD>  </TD>
<TD>DMA off and 2 big fans. Runs 100%</TD>
<TD>3070</TD>
</TR>
<TR>
<TD>98150070-1007</TD>
<TD>333</TD>
<TD>2.90</TD>
<TD>SL2QB</TD>
<TD>Malay</TD>
<TD>15</TD>
<TD>Tekram P6L40-A4</TD>
<TD>Motherboard w/ Intel LX chipset, without hardware monitoring or voltage setting (fixed in 2.9 v). Push the bus speed to 83 MHz and keep the locked multiplier in 4x and you get it.Just for care, I added some coolers on the computer: one over the processor, another behind the processor & video board (i740 AGP), another on the video board and another in the front of the tower, intended to discharge the heat.</TD>
<TD>3383</TD>
</TR>
<TR>
<TD>R7360496-215</TD>
<TD>333</TD>
<TD>2.80</TD>
<TD>SL265</TD>
<TD>31</TD>
<TD>Abit BH6</TD>
<TD>Running@4*83,nogo@ 3.5*100 and 4.5*83.TNT(1)@130/120 and a stick of 64 meg pc100</TD>
<TD>3343</TD>
</TR>
<TR>
<TD>871188/82862</TD>
<TD>300</TD>
<TD>2.80</TD>
<TD>76372</TD>
<TD>MALAY</TD>
<TD>37</TD>
<TD>FIC KA6100</TD>
<TD>Running 3*100,nogo @3.5*100(Sysreg fault)Would try upping voltage if the piece of crap mobo would letme!</TD>
<TD>3315</TD>
</TR>
</table>
</td>
</tr>
</table>
