IPChains - IPTables
ik draai nu een mooie en vooral werkende IPChains firewall op een 2.2.x kernel
nu zou ik omwille van hardware redenen naar 2.4.x kernel willen overschakelen
maar ik zit met die firewall in mijn maag, is de 2.4.x kernel backward compatible met IPChains?
of is er al een config script te downloaden voor IPTables ( ik gebruik pmfirewall voor de IPChains)
  • shadax
Je kan gewoon ipchains blijven gebruiken met kernel 2.4.x, maar dan moet je het wel ff mee bakken.
  • leander
  • Laatst online: 02-03-2025
http://netfilter.kernelnotes.org/unreliable-guides/packet-filtering-HOWTO/packet-filtering-HOWTO.linuxdoc-8.html
8. Using ipchains and ipfwadm
There are modules in the netfilter distribution called ipchains.o and ipfwadm.o. Insert one of these in your kernel (NOTE: they are incompatible with ip_tables.o!). Then you can use ipchains or ipfwadm just like the good old days.
This will be supported for some time yet. I think a reasonable formula is 2 * [notice of replacement - initial stable release], beyond the date that a stable release of the replacement is available.
This means that for ipfwadm, the end of support is:
2 * [October 1997 (2.1.102 release) - March 1995 (ipfwadm 1.0)]
+ January 1999 (2.2.0 release)
= March 2004.
This means that for ipchains, the end of support is (FIXME: get real dates):
2 * [August 1999 (2.3.15 release) - October 1997 (2.2.0 release)]
+ July 2000 (2.4.0 release?)
= March 2004.
So you don't have to worry until 2004.
