Mac plots traag, ligt aan opstartprocessen?
Op mijn mac het Adobe pakket met Photoshop, Dreamweaver geinstalleerd. Dacht; daar ligt het aan. Maar mijn log zegt iets anders. Maar de software uit mijn log heb ik allang niet meer op de Mac. Hoe kan ik die paden/bestanden verwijderen? (Macbook Pro november 2010)
10-12-10 12:03:17 com.apple.launchd[1] *** launchd[1] has started up. ***
10-12-10 12:03:56 com.vmware.launchd.vmware[45] VMware Fusion 282344: Starting VMware Fusion:
10-12-10 12:04:01 com.vmware.launchd.vmware[45] 2010-12-10 12:04:01.018 repair_packages[84:907] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac QuickTime Components.pkg
10-12-10 12:04:02 com.vmware.launchd.vmware[45] 2010-12-10 12:04:02.304 repair_packages[84:907] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac Web Plugins.pkg
10-12-10 12:04:05 com.apple.launchd[1] (com.parallels.vm.prl_naptd) Unknown key for boolean: SuccessfulExit
10-12-10 12:04:05 com.vmware.launchd.vmware[45] Verifying files from package 'com.vmware.fusion.application' on '/'.
10-12-10 12:04:05 com.vmware.launchd.vmware[45] Finished verifying files from package 'com.vmware.fusion.application' on '/'.
10-12-10 12:04:06 com.vmware.launchd.vmware[45] Started network services
10-12-10 12:04:07 com.vmware.launchd.vmware[45] Verifying and re-installing files from /Library/Application Support/VMware Fusion/thnuclnt
10-12-10 12:04:08 com.parallels.vm.prl_naptd[263] QKqueueFileSystemWatcherEngine::addPaths: open: No such file or directory
10-12-10 12:04:08 com.parallels.vm.prl_naptd[263] QFileSystemWatcher: failed to add paths: /Library/Managed Preferences
10-12-10 12:04:08 com.apple.launchctl.Aqua[704] launchctl: Please convert the following to launchd: /etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist
10-12-10 12:04:08 com.apple.launchd.peruser.501[702] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-12-10 12:04:10 com.apple.SystemStarter[22] ls: /Applications/VirtualBox.app/Contents/MacOS/*-x86: No such file or directory
10-12-10 12:04:10 com.apple.SystemStarter[22] Loading VBoxDrv.kext
10-12-10 12:04:10 com.apple.SystemStarter[22] Loading VBoxUSB.kext
10-12-10 12:04:10 com.apple.SystemStarter[22] Loading VBoxNetFlt.kext
10-12-10 12:04:11 com.apple.SystemStarter[22] Loading VBoxNetAdp.kext
10-12-10 12:04:12 com.apple.launchd.peruser.501[702] (com.parallels.desktop.client.launch[802]) posix_spawn("/Applications/Parallels Desktop.app/Contents/PlugIns/PD_Starter.app/Contents/MacOS/prl_client_app", ...): No such file or directory
10-12-10 12:04:12 com.apple.launchd.peruser.501[702] (com.parallels.desktop.client.launch[802]) Exited with exit code: 1
10-12-10 12:04:12 com.apple.launchd.peruser.501[702] (com.apple.Kerberos.renew.plist[797]) Exited with exit code: 1
10-12-10 12:04:12 com.parallels.vm.prl_pcproxy[801] QKqueueFileSystemWatcherEngine::addPaths: open: No such file or directory
10-12-10 12:04:12 com.parallels.vm.prl_pcproxy[801] QFileSystemWatcher: failed to add paths: /Library/Managed Preferences
10-12-10 12:04:12 com.apple.launchd.peruser.501[702] (0x1002043c0.mach_init.switchboard.sh) Failed to check-in!
10-12-10 12:04:12 SIMBL Agent[812] installing into launchd
10-12-10 12:04:12 [0x0-0xc00c].net.culater.SIMBL_Agent[812] net.culater.SIMBL.Agent: Already loaded
10-12-10 12:04:13 VMware Fusion Helper[811] Could not connect the action buttonPressed: to target of class NSApplication
10-12-10 12:04:14 VMware Fusion Start Menu[815] Could not connect the action buttonPressed: to target of class NSApplication
Mm. Goed om te weten: niet alle software is weg bij het gooien in de prullenbak. Er zijn nog altijd softwarestukjes die een offiele uninstall nodig hebben. Nieuwe opstartlog:
10-12-10 12:30:19 com.apple.launchd[1] *** launchd[1] has started up. ***
10-12-10 12:30:49 com.apple.launchd[1] (com.parallels.vm.prl_naptd) Unknown key for boolean: SuccessfulExit
10-12-10 12:30:51 com.parallels.vm.prl_naptd[611] QKqueueFileSystemWatcherEngine::addPaths: open: No such file or directory
10-12-10 12:30:51 com.parallels.vm.prl_naptd[611] QFileSystemWatcher: failed to add paths: /Library/Managed Preferences
10-12-10 12:30:52 com.apple.launchctl.Aqua[719] launchctl: Please convert the following to launchd: /etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist
10-12-10 12:30:52 com.apple.launchd.peruser.501[717] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-12-10 12:30:55 com.apple.launchd.peruser.501[717] (com.parallels.desktop.client.launch[746]) posix_spawn("/Applications/Parallels Desktop.app/Contents/PlugIns/PD_Starter.app/Contents/MacOS/prl_client_app", ...): No such file or directory
10-12-10 12:30:55 com.apple.launchd.peruser.501[717] (com.parallels.desktop.client.launch[746]) Exited with exit code: 1
10-12-10 12:30:55 com.apple.launchd.peruser.501[717] (com.apple.Kerberos.renew.plist[741]) Exited with exit code: 1
10-12-10 12:30:55 com.parallels.vm.prl_pcproxy[745] QKqueueFileSystemWatcherEngine::addPaths: open: No such file or directory
10-12-10 12:30:55 com.parallels.vm.prl_pcproxy[745] QFileSystemWatcher: failed to add paths: /Library/Managed Preferences
10-12-10 12:30:55 com.apple.launchd.peruser.501[717] (0x100402ce0.mach_init.switchboard.sh) Failed to check-in!
10-12-10 12:30:55 SIMBL Agent[755] installing into launchd
10-12-10 12:30:55 [0x0-0xb00b].net.culater.SIMBL_Agent[755] net.culater.SIMBL.Agent: Already loaded
10-12-10 12:31:00 com.apple.WindowServer[143] Fri Dec 10 12:31:00 Macbook.local WindowServer[143] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
  • aramdin
  • Laatst online: 24-07-2024
Check ook de site van de softwar fabrikant of er een aangepaste deinstall procedure bestaat, zoals bijvoorbeeld bij Little Snitch. Zelf gebruik ik Appcleaner (gratis) die ook kan detecteren of er stray files blijven bestaan als je een programma delete.
Daarnaast kan je voor startup items ook kijken bij je Account, daar kan je namelijk startup items definieren.
Instagram / YouTube
  • aramdin
En, probleem opgelost of...?
Instagram / YouTube
