De Abit KA7, een mobo om je vingers bij af te likken!
  • 107 views sinds 30-01-2008
  • JackBol
JackBol
Security is not an option!
[ KA7 ] - AMD Athlon Slot A Mainboard With 4 DIMM, 6 Data Buffers, 6 PCI & SoftMenuTMIII Technology
[English]
[ ABIT KA7 AMD Athlon Slot A Mainboard With 4 DIMM, 6 Data Buffers, 6 PCI & SOFT MENUTMIII Technology ]
ABIT's highly anticipated Athlon motherboard has arrived. With 4 DIMM, 6 Data Buffers and 6 PCI technology, the KA7 has everything you could want in a top-of-the-line mainboard. If that isn't enough, add in UDMA 66 support, 200 MHz FSB Processor support and ABIT's SoftMenuTM technology. Your demands were heard, met and then surpassed with the KA7.
[ Specifications ]
CPU
1. Supports AMD-K7 Athlon 200MHz FSB Processors
Chipset
1. VIA VT8371(KX133) /VIA 686A
2. Supports Advanced Configuration and Power Management Interface (ACPI)
3. Supports AGP 2X/4X (Sideband) 3.3V device
4. Supports 100/133MHz Memory Bus Settings
Memory
1. Four 168-pin DIMM sockets support PC100/PC133 SDRAM module
2. Supports up to 2 GB MAX. (8, 16, 32, 64, 128, 256, 512MB SDRAM)
3. 6 chip Data Buffer Set
4. Supports ECC
System BIOS
1. SOFTMENUTM III Technology
2. Award Plug and Play BIOS
3. Write-Protect Anti-Virus function by AWARD BIOS
4. Year 2000 Compliant
Multi I/O Functions
1. On board Bus Master IDE Ports supporting UDMA 33/66
2. PS/2 Keyboard and PS/2 Mouse Connectors
3. 1x Floppy Port (up to 2.88MB)
4. 1x Parallel Port (EPP/ECP)
5. 2x Serial Ports
6. 2x USB Connectors
7. On board USB header for Two extra USB channels
Miscellaneous
1. ATX form factor
2. 1 AGP slot, 6 PCI slots and 1 ISA slots
3. Built-in Wake on LAN/Wake on Modem
4. Built-in IrDA TX/RX header
5. One Thermal Sensor Cable Included
Klinkt allemaal wel leuk maarre ik wil een P3 coppermine erop kan dat anders is dit weer eens zooi P3 roeleerd !! <---- mijn mening!!
De Athlon is pas weer echt leuk als de Thunderbird er is, nu is een Coppermine de beste keus, vooral als je nog een BX plank in je machine hebt.
  • Crazyhorse
  • Laatst online: 08-09 16:27
Echt een gaaf mobo maar ik heb geen geduld om te wachten tot hij uitkomt dus ik heb alvast maar een aopen ak72 besteld.
Als hij echt goed getest wordt zal ik hem waarschijnlijk alsnog gaan kopen.
