• WinterX
Hey guys,
I'm living in the Netherlands for quite long, but still can't write in it.
Anyway, I'm customer of iPhone 4 from T-Mobile. Unfortunately, I've broken the screen on my own. I didn't send it for warranty, cause they wouldn't do anything about it. Instead I went to some shop in Gouda, which offered me to switch the screen for a new one (including tape) for 320 €. That's what I did. The phone worked fine until I realized that the battery is not charging! Now it's totally empty and the phone won't turn on, only when using USB cable connected to laptop or to electric plug.
My questions:
- is the battery really broken, can I fix it manually without paying?
- can I send the phone to T-Mobile so they fix it on my cost?
- what if I buy a new battery and maybe it helps?
  • dtech
  • Laatst online: 20-08 22:48
I don't think T-mobile would fix this as you've probably voided your warranty by sending it to the 3rd party repair shop.
Your best bet is to complain to the repair shop and ask them to fix this. They should do it for free as this is almost evidently a faulty repair (since you cannot access the battery on your own)
Also best place to ask if T-mobile would fix it (also with the screen problem you had before) is... suprise! T-Mobile, we do not know that.
Furthermore this is a Dutch forum, and I don't think English posts are allowed, although I couldn't find any specific rule in the FAQ and policy.
  • WinterX
I try in Dutch then :)
Ik wohne in Waddinxveen naast Gouda. De toestel was naar Scholten Telecom in Gouda gestuurd en ik heb de toestel na 2 weken terug gehaald (received back). De scherm doet wel, maar heb ik probleem met de batterij. Kann niet het opladen, ik zie allein de batterij icon op de scherm, nix meer. Ik heb niet de toestel geladen op, denk ik dat de batterij is kapott of de serviceman heeft fout gedaan - weet ik niet.
Daarom vraag ik jullie :)
Hope it was "understable" :D
  • WinterX
En nog een vraag. Heb ik te veel betaald voor de nieuwe scherm en digitizer? 320 € is beitje duur maar de man seht dat is de normal prijs.
  • dusty
  • Laatst online: 26-11 01:26
dusty
Celebrate Life!
WinterX schreef op vrijdag 12 november 2010 @ 02:31:
Dat is alles wat we verwachten, Het is verstaanbaar genoeg om te begrijpen wat je bedoeld, anders vrqagen onze users uiteraard netjes om een betere uitleg. (en als je niet zeker bent van de juiste vertaling kan je altijd de engelse tekst tussen haakjes erachter zetten.)
Back In Black!
"Je moet haar alleen aan de ketting leggen" - MueR
  • L490
  • Laatst online: 14-11 19:12
320 is indeed a bit on the expensive side
Here is it much cheaper
http://diensten.marktplaa...-3gs-4-ipad-glas-lcd.html
170 euro + LCD and digitizer assembly
  • RadioAir
  • Laatst online: 09:12
Zou het niet gewoon kunnen dat je oplader kapot is, of het snoertje? Kijk eens wat gebeurt als je een andere oplader of snoer gebruikt. Als het batterij symbool in beeld komt gewoon geduld hebben. Komt deze niet in beeld zal er wat mis zijn met je telefoon zelf.
  • sebastius
  • Laatst online: 25-11 07:07
sebastius
Laten we lekker link gaan doen
Maak hem open, ik denk dat er gewoon een draadje los zit binnen.
Just open it up, it's probably just a faulty wire inside.
  • WinterX
Ik heb de toestel terug gestuurd naar de reparatie service. Ik kom voor de toestel op woensdag. Ik hoop alles wordt OK. Probleem is dat de reparatie service seht ik heb de toestel self geopend en de batterij kapot gemaakt.
