Linq probleem
  • original4u
  • Laatst online: 24-11 20:06
Weet iemand het volgende probleem:
Onderstaande SQL query wil ik in LINQ maken.
SQL:
SELECT
  "Question"."QuestionText",
  "Answer"."AnswerText",
  "Professional"."FirstName",
  "Professional"."Surname",
  "Career"."JobTitle",
  "Answer"."InterviewFormID",
  "InterviewForm"."ProfessionalID"
FROM
  public."Answer",
  public."Professional",
  public."Question",
  public."InterviewForm",
  public."Career"
WHERE
  "Answer"."InterviewFormID" = "InterviewForm"."InterviewFormID" AND
  "Answer"."QuestionID" = "Question"."QuestionID" AND
  "InterviewForm"."ProfessionalID" = "Professional"."ProfessionalID" AND
  "Career"."CareerID" =  "Professional"."CareerID" AND
  "Question"."QuestionText" = '15. What do you like most about your job?'
ORDER BY
  "Question"."QuestionText" ASC,
  "Answer"."AnswerText" ASC;
C#:
            var queryQuestionaire =
                from q in _context.Question
                from c in _context.Career
                from i in _context.InterviewForm
                from p in _context.Professional
                join b in _context.Answer on i.InterviewFormID equals  b.InterviewForm.InterviewFormID
                join a in _context.Answer on q.QuestionID equals a.Question.QuestionID
                join l in _context.InterviewForm on p.ProfessionalID equals l.Professional.ProfessionalID
                join d in _context.Professional on c.CareerID equals d.Career.CareerID
                where q.QuestionText == "15. What do you like most about your job?"
                select new {q.QuestionText, a.AnswerText, p.FirstName, p.Surname};
Echter geeft de SQL query het gewenste resultaat, namelijk 1 regel. Maar de LINQ query geeft 200 keer dezelfde regel. Moet ik in LINQ anders joinen?
Ik hoop dat iemand dat kan bevestigen.
Ik weet niet echt veel van LINQ, maar volgens mij ligt het aan de regel : ' where q.QuestionText == "15. What do you like most about your job?"' ... deze zal (denk ik) maar één resultaat geven , gezien je een JOIN op de Question tabel doet.
ik denk dat de query had moeten zijn :
SQL:
29
30
31
32
33
SELECT
FROM
  public."Answer"
 LEFT JOIN
  public."Question"
 ON
 LEFT JOIN
 ON
 LEFT JOIN
 ON
 LEFT JOIN
  public."Career"
 ON
WHERE
    "Answer"."QuestionID" = <QUESTIONID>
ORDER BY
C#:
                (from q in _context.Question
                select new {q.QuestionText, a.AnswerText, p.FirstName, p.Surname}).First()
  • original4u
@BoeBoe. Thx je hebt me in de juiste richting geholpen. Het aanroepen van .First is niet de oplossing. Als er meerdere "rows" gevonden worden pakt hij altijd alleen de eerste. Wat ik nu doe is .Distinct(); aanroepen :) Al is de linq query nog steeds fout imho aangezien er meerdere dubbele rows uitkomen.
Maar ik heb nu iig het gewenste resultaat! Ga het nu nog even goed testen. Ik zal een update geven.
  • Wallie
  • Laatst online: 11:29
Wallie
Herr
Anders kijk eens met profiler wat er op de achtergrond voor SQL uit komt, kan je ook een hint geven wat je verkeerd doet.
...en dat kan op allerlei manieren Edgar, of "machen Sie um meinetwegen kein Pummel"
  • Grijze Vos
  • Laatst online: 21-02 23:50
Dit zijn de twee equivalenten in sql.
SQL:
select *
from a, b
where a.id = b.id;
select *
from a left join b
  on a.id = b.id;
Wat je nu doet is eerst 4x een cartesisch product nemen met al die froms, en dan ga je joinen. Je doet dus twee keer dezelfde tabel meenemen in je linq expressie.
@boeboe, First is geen oplossing als je query fout is. Dit soort "oplossingen" zijn geen oplossingen, alleen hackpogingen die niet alleen bugs verstoppen, maar ook nog eens je performance nekken op de lange termijn.
[ Voor 25% gewijzigd door Grijze Vos op 10-11-2010 11:27 ]
Op zoek naar een nieuwe collega, .NET webdev, voornamelijk productontwikkeling. DM voor meer info
  • original4u
@Grijze Vos
Je hebt gelijk ik zie dat ik nu waarden door elkaar te zien krijg in de rows. Een from kan je dus als een foreach zien in deze notatie. Alleen heb ik geen idee hoe ik het nu moet oplossen :/
Ik gebruik trouwens PostgreSQL. Zit daar ook een soort profiler bij? :)
[ Voor 16% gewijzigd door original4u op 10-11-2010 12:17 ]
  • Sebazzz
  • Laatst online: 12:28
Sebazzz
3dp
original4u schreef op woensdag 10 november 2010 @ 12:16:
Wat ik deed toen ik in ASP.NET ontwikkelde met Linq, is gewoon een breakpoint gooien na je Linq statement. "queryQuestionaire" is namelijk een IQueryable<T>, als je er in de debugger overheen hovert zie je wat voor query hij genereert. Mogelijk werkt een .ToString ook als je het wil loggen, maar dat moet je op MSDN opzoeken.
  • EfBe
Wat gebruik je trouwens? Entity Framework v4?
original4u schreef op woensdag 10 november 2010 @ 09:53:
SQL:
SELECT
FROM
  public."Answer",
  public."Question",
  public."Career"
WHERE
ORDER BY
Dit zijn inner joins, dus je kunt ze beter opschrijven als inner joins ipv een cross join from clause met een serie where clauses.
C#:
Dit klopt niet. je hebt nested 'from' clauses in de query, die vormen een cross join en daarna ga je met 'join' in de weer. Dit kan veel slimmer:
C#:
var q = from a in _context.Answer
          select new { a.AnswerText, a.Question.QuestionText, a.InterviewForm.Professional.FirstName, a.InterviewForm.Professional.SurName, a.InterviewForm.Professional.Career.JobTitle, a.InterviewForm.ProfessionalID, a.InterviewFormID};
mocht dit problemen opleveren doordat de Linq provider de mist ingaat met de navigation in de projectie, dan kun je ook joinen:
C#:
          join q in _context.Question on a.QuestionID equals q.QuestionID
          join i in _context.InterviewForm on a.InterviewFormID equals i.InterviewFormID
          join p in _context.Professional on i.ProfessionalID equals p.ProfessionalID
          join c in _context.Career on p.CareerID equals c.CareerID
          select new { q.QuestionText, a.AnswerText, p.FirstName, p.SurName, c.JobTitle, i.InterviewFormID, p.ProfessionalID};
Creator of: LLBLGen Pro | Camera mods for games
Photography portfolio: https://fransbouma.com
  • original4u
EfBe schreef op woensdag 10 november 2010 @ 13:22:
C#:
Holy &#($, it works!
Uiteindelijk heb ik er dit van gemaakt:
C#:
 var queryQuestionaire = from a in _context.Answer
                    join q in _context.Question on a.Question.QuestionID equals q.QuestionID
                    join i in _context.InterviewForm on a.InterviewForm.InterviewFormID equals i.InterviewFormID
                    join p in _context.Professional on i.Professional.ProfessionalID equals p.ProfessionalID
                    join c in _context.Career on p.Career.CareerID equals c.CareerID
                    select new { q.QuestionText, a.AnswerText, p.FirstName, p.Surname, c.JobTitle, i.InterviewFormID, p.ProfessionalID };
(Ik moest bij sommige nog wat toevoegen anders kon hij ze niet gelijk resolven.)
Uitgebreid getest en het werkt. Nu snap ik Linq wat beter. Thx iedereen. :)
En +1 voor "EfBe"! _/-\o_
  • EfBe
Tja, ik zie linq niet voor het eerst ;)
