Vraagje over Reflection in vb.net.
  • MasterTweaker
  • Laatst online: 11-11 21:03
Ik heb een klein vraagje over reflectie in VB.net. Aangezien ik de vraag elders op een Engels forum ook al gesteld heb heb ik het even in de Engels gelaten. Ik hoop dat dit geen probleem is.
I'm making a little program in where i'm trying to invoke a method from a class dynamically with so called Reflection.
The class I'm trying to call is called ContactList and i try to invoke the property in this class called count. The assembly itself is called Contact.Exe
Now I have the following code where I make an instance of the ContactList class using reflection:
 Public
 Function
 InvokeContacts() As
 Integer
  Dim
 ContactsAssembly As
 Assembly
 = Assembly
.LoadFrom("Contacts.exe"
  Dim
 Mycontactlist As
 Type = ContactsAssembly.GetType
("_windowsapplication.ContactList"
  Dim
 argumentTypes() As
 Type = Type.EmptyTypes
  Dim
 MycontaclistConstructor As
 ConstructorInfo = Mycontactlist.GetConstructor(argumentTypes)
  Dim
 ContactList As
 Object
 = Activator.CreateInstance(Mycontactlist)
But Now I want to assign this instance to a value in a module in the Contacts.exe assembly. This module is called module1. This is because if I invoke an object of this class of ContactList, the ContactList is empty again and I need to have it the current value. So in the module1 is a public value which i need to assign to the empty ContactList object. This value is called:
  Public mycontacts As ContactList
(This value is assigned in a module called Module1 in the Contacts.exe assembly)
Now I want to assign this value to the object of type ContactList. So I expanded the code as seen below:
Dim ContactsAssembly As Assembly = Assembly.LoadFrom("Contacts.exe")
    Dim mymodule As [Module] = ContactsAssembly.GetModule("_windowsapplication.Module1")
    Dim Mycontactlist As Type = ContactsAssembly.GetType("_windowsapplication.ContactList")
    Dim argumentTypes() As Type = Type.EmptyTypes
    Dim MycontaclistConstructor As ConstructorInfo = Mycontactlist.GetConstructor(argumentTypes)
    Dim ContactList As Object = Activator.CreateInstance(Mycontactlist)
    Dim myfield As FieldInfo = mymodule.GetField("mycontacts")
    ContactList = myfield.GetValue(myfield)
    Dim count As PropertyInfo = ContactList.GetProperty("Count")
    Dim CountCL As Integer = count.GetValue(ContactList, Nothing)
    Return CountCL
But now I get a Nullexception in this line of code:
So is it possible anyway to assign a public value in a module to a dynamically created object like the way I tried to do it? :
  • CoolGamer
  • Laatst online: 22-11 14:13
CoolGamer
What is it? Dragons?
Je zal die NullReferenceException krijgen, omdat mymodule null teruggeeft. Maar daar had je waarschijnlijk met even debuggen ook wel achter kunnen komen. GetModule geeft niet de modules terug uit een VB.net project, maar module staat daar voor iets anders (zie http://msdn.microsoft.com/en-us/library/c405shex.aspx). Dus hiermee kan je zelf wel even verder zoeken naar het probleem.
Het vertalen van de vraag naar het Nederlands is wel zo netjes. Zo laat je zien dat je ook wat moeite doet om de vraag beantwoord te krijgen.
¸.·´¯`·.¸.·´¯`·.¸><(((º>¸.·´¯`·.¸><(((º>¸.·´¯`·.¸.·´¯`·.¸.·´¯`·.¸<º)))><¸.·´¯`·.¸.·´¯`·.¸.·´¯`·.¸
  • MasterTweaker
Oke thnx maar hoe krijg je dan wel de module met daarin de mycontacts variabele? Doe je dat gewoon met de Gettype methode?
[ Voor 20% gewijzigd door MasterTweaker op 16-10-2010 21:59 ]
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
MasterTweaker schreef op zaterdag 16 oktober 2010 @ 21:02:
Probleem is een groot woord en het gros (zo niet alle) programmeurs spreken best Engels. Echter; we hebben op GoT afgesproken Nederlands te hanteren en dan doen we dus ook allemaal. Het is helemaal niet erg als je je topic elders ook plaatst maar we verwachten op GoT dat je in ieder geval even de moeite neemt je topic te vertalen naar Nederlands. Dat is gewoon wel zo netjes en een kleine moeite. Ik laat 't topic staan maar wil je er dus even op wijzen dat we voortaan van je verwachten dat je die moeite neemt.
Verder: Waar hoort mijn topic?
Dit is een concreet implementatieprobleem en dus SEA >> PRG
En what's up met dat eerste codeblok? Dat is echt compleet onleesbaar zo...
[ Voor 12% gewijzigd door RobIII op 17-10-2010 13:57 ]
Je eigen tweaker.me redirect
Over mij
  • keesdewit
  • Laatst online: 28-10 18:16
Lees je even Feedback op moderatie binnen de Devschuur?
[ Voor 92% gewijzigd door RobIII op 17-10-2010 17:29 ]
