JMicron JMB36x RAID/AHCI 1.17.59 WHQL
  • 104 views
  • Cobalt
  • Laatst online: 06-10 14:46
De ontwikkelaars van JMicron hebben een nieuwe driver uitgebracht voor de JMB36x raid/ahci-controllers, die op verschillende moederborden en uitbreidingskaarten zijn terug te vinden. Deze controllers maken gebruik van één pci-express-kanaal en bieden afhankelijk van het gekozen model eS-ATA, S-ATA en P-ATA-mogelijkheden aan. De nieuwe driver, welke pas uitgebracht is op 04-10-2010, waarvan het versienummer 1.17.59 WHQL is geworden, is van de volgende lijst met aanpassingen voorzien:
Release note:
R1.17.59WHQL (09/20/2010)
  1. Fix issue:
    • Fix the issue that the performance will suffer for JMB36X C.
    • SATA ODD (Samsung TSS-TS-H353) can not be detected normally.
      • Samsung TSS-TS-H353 (ODD) will not send D2H FIS for first COMRESET.
      • If driver fails to receive D2H FIS, issue COMRESET again.
R1.17.58WHQL (08/20/2010)
  1. Fix issue:
    • Driver and BIOS sometimes can not detect inconsistent RAID1 after reboot.
      • When one device is plugged out, RAID segment info can not be updated since channel is occupied.
      • Release all corresponding channels when plug-out occurs during data transferring.
      • Add a mechanism to retry to update RAID segment info if error occurs.
    • Fix the issue that PMP can not be recognized (freeze and crash).
    • Update RAID segment info every 1 GB to speed up RAID rebuilding process.
R1.17.57WHQL (07/28/2010)
  1. Fix issue:
    • Hog-plug fails for the first time after S3 resume.
      • If device is unplugged during sleep, hot-plug will fail for the first time after resume.
      • After resume, rescan devices and clear database if device does not exist.
R1.17.56WHQL (06/10/2010)
  1. Fix issue:
    • Windows will freeze when device remains busy abnormally (by LeCroy Infusion and a hammer).
    • Modify command error and timeout handling (Command timeout handling is only for READ and WRITE commands). Disconnect the abnormal disk if error or timeout continues.
Website:
www.jmicron.com.tw
Downloads:
ftp://driver.jmicron.com...._WinDrv_R1.17.59_WHQL.zip
ftp://driver.jmicron.com....v_R1.17.59_WHQL_eSATA.zip
Waarom ik dit hier plaats? Ik heb het al gesubmit naar de meuktracker maar het wordt niet toegevoegd aan de meuktracker, ook de vorige release niet omdat de moderators van mening zijn dat als het al een paar dagen uit is dat het dan niet meer nuttig is. Dit hebben ze geschreven in een eerder topic. Ik ben het daar niet eens. De laaste versie is nu uit maart 2010. Door het niet bijhouden van nieuwe versies wordt de meuktracker volkomen overbodig en moet je als nog zelf de sites af gaan. Daarnaast ben ik niet van plan de sites van de fabrikanten te pollen om direct dezelfde dag een update te submitten.
Ik zie dat dit vandaag aan de meuktracker is toegevoegd:
meuk: JMicron JMB36x RAID/AHCI 1.17.59 WHQL
Daarnaast is Geachte Redactie een betere plaats als je klachten hebt over de FP.
