PS3 controller op PC crasht met vierkantje
  • MenaCeNL
  • Laatst online: 11-05 09:30
he,
ik heb geprobeerd ps3 controller op pc aan te sluiten. Heb getest met fifa11.
eerst alle knoppen proberen in te stellen maar bij het instellen van vierkantje crashte het programma met volgende foutmelding:
Iemand enige idee??
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at fifasetup_csharp.GameSettingsForm.Update(IntPtr inputManager)
at fifasetup_csharp.GameSettingsForm.timer1_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
fifaconfig
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/EA%20Sports/FIFA%2011/Game/fifasetup/fifaconfig.exe
System
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
FIFA11 draait in .NET met JIT debugging enabled?? :?
Iets zegt me dat je toch informatie achterhoudt :p
  • psychoclown
  • Laatst online: 28-08 23:24
psychoclown
Back in black
Van de users wordt verwacht dat ze inzet tonen en dat is hier ver te zoeken. Dus wat heb je zelf al gedaan om achter het probleem te komen?
Overigens hoort het ook niet in HSA maar in Spielerij - Problemen & Vragen.
  • MenaCeNL
sorry voor verkeerde plaats van posten.
Ik heb getest met PES2011 maar daar werkt hij wel gewoon.
PS3 controller is met usb aangesloten en geïnstalleerd.
Op internet staat niets over het gebruik van ps3 controller op pc vandaar dat ik het hier post.
  • rxs
  • Laatst online: 02-10 17:12
rxs
Een ps3 controller werkt normaal toch echt niet met een pc. Hiervoor moet je aangepaste drivers installeren. Google weet hier meer over.
Deze werkt overigens met bluetooth, dus als jij hem al via usb hebt aangesloten betekend waarschijnlijk dat je met libusb-win32-filter hebt lopen aanklooien.
[ Voor 37% gewijzigd door rxs op 05-10-2010 18:39 ]
  • MenaCeNL
Ja dat klopt ik heb libusb-win32-filter geinstalleerd. Is dit niet goed programma? Na het aansluiten van ps3 controller via usb zei windows meteen dat er geen drivers voor nodig waren (vond ik nogal vreemd maar oke).
Ik zou eens beginnen met zoeken op Google, dat geeft je meer kans. Overigens kun je ook contact opnemen met EA over je probleem.
  • MenaCeNL
fixed... crasht nu niet meer door op andere manier te installeren.. sorry dat het leek alsof ik niet zoveel research heb gedaan ik had het even druk ;)
kan dicht
