Cisco packet tracer EIGRP Probleem
Ik probeer virtueel een netwerk te maken met packet tracer door 3 routers met elkaar te verbinden met het EIGRP protocol, en aan de buiten kanten een pc. Nu is mijn doel van de ene pc naar de andere pingen maar dat wil niet lukken.
Hier de packettracer: http://bit.ly/asDrnZ
Router 1:
Current configuration : 858 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
no service password-encryption
hostname R1
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
enable password cisco
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
ip address 192.169.0.1 255.255.255.0
ip summary-address eigrp 100 0.0.0.0 0.0.0.0 250
clock rate 9600
interface Serial3/0
no ip address
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
router eigrp 100
network 192.169.0.0
network 192.170.0.0
auto-summary
ip classless
line con 0
line vty 0 4
password cisco
login
end
Router 2:
Current configuration : 891 bytes
version 12.2
hostname R2
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
ip address 192.169.0.2 255.255.255.0
interface Serial3/0
ip address 192.170.0.1 255.255.255.0
no ip address
shutdown
no ip address
shutdown
router eigrp 100
network 192.169.0.0
network 192.170.0.0
auto-summary
ip classless
line con 0
line vty 0 4
password cisco
login
end
Router 3:
Current configuration : 856 bytes
version 12.2
hostname R3
ip address 192.171.0.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial3/0
ip address 192.170.0.2 255.255.255.0
ip summary-address eigrp 100 0.0.0.0 0.0.0.0 5
clock rate 9600
no ip address
shutdown
no ip address
shutdown
router eigrp 100
network 192.169.0.0
network 192.170.0.0
auto-summary
ip classless
line con 0
line vty 0 4
password cisco
login
end
  • Uberprutser
  • Laatst online: 14:09
Edit: Geen Packettracer ATM
[ Voor 86% gewijzigd door Uberprutser op 27-09-2010 20:47 ]
As you may already have guessed, following the instructions may break your system and you are on your own to fix it again.
  • plizz
  • Laatst online: 12-10 20:29
Je bent in router 1 het network 192.168.0.0 vergeten in het eigrp 100 en network 192.171.0.0 in router 3. Dan heeft router 1 niet de route naar 192.171.0.0 netwerk en andersom.
[ Voor 3% gewijzigd door plizz op 27-09-2010 20:46 ]
@plizz Aangepast, dat ziet er inderdaad logisch uit. Alleen nu werkt het nog steeds niet.
  • plizz
Hoe ziet de route tabel van de 3 routers (show ip route)? Ziet router 1 wel het netwerk van 192.171.0.0 en router 3 wel het netwerk van 192.168.0.0. Hebben de routers neighbor relatie met elkaar (show ip eigrp neighbors
Router 1:
Gateway of last resort is 192.169.0.2 to network 0.0.0.0
C 192.168.0.0/24 is directly connected, FastEthernet0/0
C 192.169.0.0/24 is directly connected, Serial2/0
D* 0.0.0.0/0 [90/21024000] via 192.169.0.2, 00:00:03, Serial2/0
Router 2:
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
C 192.170.0.0/24 is directly connected, Serial3/0
D* 0.0.0.0/0 [5/20512000] via 0.0.0.0, 00:00:56, Null0
Router 3:
Gateway of last resort is 192.170.0.1 to network 0.0.0.0
C 192.171.0.0/24 is directly connected, FastEthernet0/0
D* 0.0.0.0/0 [90/21024000] via 192.170.0.1, 00:01:26, Serial3/0
Nee dat hebben ze niet, is dit nodig ?
  • Uberprutser
Verwijderd schreef op maandag 27 september 2010 @ 22:08:
Als je dat antwoord geeft; waar ben je dan überhaupt mee bezig?!
Ik snap ook je hele IP adressen keuze niet echt, waarom niet gewoon 192.168.x.x ?
Je hebt ook geen geldige summary's gemaakt die maak je niet op die manier, zorg er eerst is voor dat je routers met elkaar willen praten.
Is dit overigens een schoolopdracht of gewoon hobbymatig?
edit: IP-EIGRP 100: Neighbor 192.170.0.1 (Serial3/0) is up: new adjacency
[ Voor 13% gewijzigd door Uberprutser op 27-09-2010 22:41 ]
  • plizz
Ja, in eigrp is een neighbor relatie tussen twee routers nodig om elkaars route te leren. Router 2 heeft geen netwerk naar 192.168.0.0 en 192.171.0.0. Anders zie je een D met het netwerk. Dus router2 heeft geen neighbor relatie met router 1 en 3.
Je bent het clock rate commando op router 2 of 3 vergeten waardoor een het protocol down blijft op beide poorten.
Misschien kabel zit DTE en DCE verwisseld? DCE moet in Router 1 en Router 2 of 3 en DTE in Router 2 of 3. Met show controller s0/2 kan je zien welke kabel op het serial poort is aangesloten. De DCE moet de Clock geven.
[ Voor 3% gewijzigd door plizz op 27-09-2010 23:17 ]
