Fout bij exporteren database MS SQL 2008
  • llechtim
  • Laatst online: 17-07 12:34
Beste medetweakers ik heb een probleem,
het probleem is dat ik iedere keer een error krijg bij het exporteren van de ene database naar de andere heb ook al flink op internet zitten zoeken maar dat bood geen uitweg ik gebruik Microsoft® SQL 2008
hierbij de gegevens uit het rapport misschien dat jullie mij ermee kunnen helpen
- Initializing Data Flow Task (Success)
- Initializing Connections (Success)
- Setting SQL Command (Success)
- Setting Source Connection (Warning)
Messages
Warning 0x8020400d: Source 47 - G_AssetUdf [217]: The output "OLE DB Source Output" (227) references an external data type that cannot be mapped to a Data Flow task data type. The Data Flow task data type DT_WSTR will be used instead.
(SQL Server Import and Export Wizard)
Warning 0x8020400d: Source 47 - G_AssetUdf [217]: The output column "FieldValue" (240) references an external data type that cannot be mapped to a Data Flow task data type. The Data Flow task data type DT_WSTR will be used instead.
- Setting Destination Connection (Success)
- Validating (Error)
Messages
Warning 0x8020400d: Data Flow Task 10: The output "OLE DB Source Output" (227) references an external data type that cannot be mapped to a Data Flow task data type. The Data Flow task data type DT_WSTR will be used instead.
Error 0xc0047008: Data Flow Task 44: The package contains two objects with the duplicate name of "output column "ErrorCode" (149)" and "output column "ErrorCode" (190)".
Error 0xc0047008: Data Flow Task 44: The package contains two objects with the duplicate name of "output column "ErrorCode" (315)" and "output column "ErrorCode" (356)".
- Prepare for Execute (Success)
- Pre-execute (Success)
- Copying Rows (Warning)
Messages
Information 0x402090df: Data Flow Task 1: The final commit for the data insertion in "component "Destination 1 - G_ACCBANKIMPORT" (389)" has started.
Information 0x402090df: Data Flow Task 1: The final commit for the data insertion in "component "Destination 2 - G_ACCBANKRECON" (554)" has started.
Information 0x402090df: Data Flow Task 1: The final commit for the data insertion in "component "Destination 3 - G_ACCCASHVAT" (648)" has started.
Information 0x402090e0: Data Flow Task 1: The final commit for the data insertion in "component "Destination 1 - G_ACCBANKIMPORT" (389)" has ended.
Information 0x402090e0: Data Flow Task 1: The final commit for the data insertion in "component "Destination 2 - G_ACCBANKRECON" (554)" has ended.
Information 0x402090e0: Data Flow Task 1: The final commit for the data insertion in "component "Destination 3 - G_ACCCASHVAT" (648)" has ended.
Information 0x402090df: Data Flow Task 1: The final commit for the data insertion in "component "Destination 4 - G_ACCCODE" (739)" has started.
Information 0x402090e0: Data Flow Task 1: The final commit for the data insertion in "component "Destination 4 - G_ACCCODE" (739)" has ended.
Information 0x402090df: Data Flow Task 1: The final commit for the data insertion in "component "Destination - G_ACC" (139)" has started.
Information 0x402090e0: Data Flow Task 1: The final commit for the data insertion in "component "Destination - G_ACC" (139)" has ended.
Information 0x402090df: Data Flow Task 2: The final commit for the data insertion in "component "Destination 9 - g_ACCCOSTCENTER" (371)" has started.
Information 0x402090e0: Data Flow Task 2: The final commit for the data insertion in "component "Destination 9 - g_ACCCOSTCENTER" (371)" has ended.
Information 0x402090df: Data Flow Task 2: The final commit for the data insertion in "component "Destination 5 - G_ACCCODEGROUP" (40)" has started.
Information 0x402090df: Data Flow Task 2: The final commit for the data insertion in "component "Destination 6 - G_ACCCODEGROUPL" (116)" has started.
Information 0x402090e0: Data Flow Task 2: The final commit for the data insertion in "component "Destination 5 - G_ACCCODEGROUP" (40)" has ended.
Information 0x402090e0: Data Flow Task 2: The final commit for the data insertion in "component "Destination 6 - G_ACCCODEGROUPL" (116)" has ended.
Information 0x402090df: Data Flow Task 2: The final commit for the data insertion in "component "Destination 8 - G_ACCCODESYSTEM" (300)" has started.
Information 0x402090df: Data Flow Task 2: The final commit for the data insertion in "component "Destination 7 - G_ACCCODESTRUCTURE" (209)" has started.
Information 0x402090e0: Data Flow Task 2: The final commit for the data insertion in "component "Destination 8 - G_ACCCODESYSTEM" (300)" has ended.
Information 0x402090e0: Data Flow Task 2: The final commit for the data insertion in "component "Destination 7 - G_ACCCODESTRUCTURE" (209)" has ended.
Information 0x402090df: Data Flow Task 3: The final commit for the data insertion in "component "Destination 12 - G_ACCFACTCONT" (205)" has started.
Information 0x402090df: Data Flow Task 3: The final commit for the data insertion in "component "Destination 11 - G_ACCDELNUMBER" (110)" has started.
Information 0x402090df: Data Flow Task 3: The final commit for the data insertion in "component "Destination 10 - g_ACCCOSTCENTERL" (40)" has started.
Information 0x402090df: Data Flow Task 3: The final commit for the data insertion in "component "Destination 14 - G_ACCIDREF" (382)" has started.
Information 0x402090df: Data Flow Task 3: The final commit for the data insertion in "component "Destination 13 - G_ACCFILEARCHIVE" (303)" has started.
Information 0x402090e0: Data Flow Task 3: The final commit for the data insertion in "component "Destination 12 - G_ACCFACTCONT" (205)" has ended.
Information 0x402090e0: Data Flow Task 3: The final commit for the data insertion in "component "Destination 11 - G_ACCDELNUMBER" (110)" has ended.
Information 0x402090e0: Data Flow Task 3: The final commit for the data insertion in "component "Destination 10 - g_ACCCOSTCENTERL" (40)" has ended.
Information 0x402090e0: Data Flow Task 3: The final commit for the data insertion in "component "Destination 14 - G_ACCIDREF" (382)" has ended.
Information 0x402090e0: Data Flow Task 3: The final commit for the data insertion in "component "Destination 13 - G_ACCFILEARCHIVE" (303)" has ended.
Information 0x402090df: Data Flow Task 4: The final commit for the data insertion in "component "Destination 16 - G_ACCOCR" (112)" has started.
Information 0x402090e0: Data Flow Task 4: The final commit for the data insertion in "component "Destination 16 - G_ACCOCR" (112)" has ended.
Information 0x402090df: Data Flow Task 4: The final commit for the data insertion in "component "Destination 15 - G_ACCNUMBER" (43)" has started.
Information 0x402090df: Data Flow Task 4: The final commit for the data insertion in "component "Destination 17 - G_ACCPARAMETER" (205)" has started.
Information 0x402090df: Data Flow Task 4: The final commit for the data insertion in "component "Destination 18 - G_ACCPERIODTERMIN" (327)" has started.
Information 0x402090df: Data Flow Task 4: The final commit for the data insertion in "component "Destination 19 - G_ACCREG" (446)" has started.
Information 0x402090e0: Data Flow Task 4: The final commit for the data insertion in "component "Destination 17 - G_ACCPARAMETER" (205)" has ended.
Information 0x402090e0: Data Flow Task 4: The final commit for the data insertion in "component "Destination 15 - G_ACCNUMBER" (43)" has ended.
Information 0x402090e0: Data Flow Task 4: The final commit for the data insertion in "component "Destination 18 - G_ACCPERIODTERMIN" (327)" has ended.
Information 0x402090e0: Data Flow Task 4: The final commit for the data insertion in "component "Destination 19 - G_ACCREG" (446)" has ended.
Information 0x402090df: Data Flow Task 5: The final commit for the data insertion in "component "Destination 21 - G_ACCREMITSETUP" (179)" has started.
Information 0x402090df: Data Flow Task 5: The final commit for the data insertion in "component "Destination 24 - G_ACCSRU" (473)" has started.
Information 0x402090e0: Data Flow Task 5: The final commit for the data insertion in "component "Destination 21 - G_ACCREMITSETUP" (179)" has ended.
Information 0x402090e0: Data Flow Task 5: The final commit for the data insertion in "component "Destination 24 - G_ACCSRU" (473)" has ended.
Information 0x402090df: Data Flow Task 5: The final commit for the data insertion in "component "Destination 20 - G_ACCREGL" (40)" has started.
Information 0x402090df: Data Flow Task 5: The final commit for the data insertion in "component "Destination 22 - G_ACCRES" (305)" has started.
Information 0x402090df: Data Flow Task 5: The final commit for the data insertion in "component "Destination 23 - G_ACCSETUP" (390)" has started.
Information 0x402090e0: Data Flow Task 5: The final commit for the data insertion in "component "Destination 20 - G_ACCREGL" (40)" has ended.
Information 0x402090e0: Data Flow Task 5: The final commit for the data insertion in "component "Destination 22 - G_ACCRES" (305)" has ended.
Information 0x402090e0: Data Flow Task 5: The final commit for the data insertion in "component "Destination 23 - G_ACCSETUP" (390)" has ended.
Information 0x402090df: Data Flow Task 6: The final commit for the data insertion in "component "Destination 26 - G_ACCSUMMAIN" (122)" has started.
Information 0x402090df: Data Flow Task 6: The final commit for the data insertion in "component "Destination 25 - G_ACCSUM" (40)" has started.
Information 0x402090e0: Data Flow Task 6: The final commit for the data insertion in "component "Destination 26 - G_ACCSUMMAIN" (122)" has ended.
Information 0x402090e0: Data Flow Task 6: The final commit for the data insertion in "component "Destination 25 - G_ACCSUM" (40)" has ended.
Information 0x402090df: Data Flow Task 6: The final commit for the data insertion in "component "Destination 27 - G_ACCTEMPLATE" (213)" has started.
Information 0x402090e0: Data Flow Task 6: The final commit for the data insertion in "component "Destination 27 - G_ACCTEMPLATE" (213)" has ended.
Information 0x402090df: Data Flow Task 6: The final commit for the data insertion in "component "Destination 28 - G_ACCTEMPLATEGROUP" (291)" has started.
Information 0x402090df: Data Flow Task 6: The final commit for the data insertion in "component "Destination 29 - G_ACCTEMPLATELINE" (395)" has started.
Information 0x402090e0: Data Flow Task 6: The final commit for the data insertion in "component "Destination 28 - G_ACCTEMPLATEGROUP" (291)" has ended.
Information 0x402090e0: Data Flow Task 6: The final commit for the data insertion in "component "Destination 29 - G_ACCTEMPLATELINE" (395)" has ended.
Information 0x402090df: Data Flow Task 7: The final commit for the data insertion in "component "Destination 33 - G_ACTION" (457)" has started.
Information 0x402090df: Data Flow Task 7: The final commit for the data insertion in "component "Destination 34 - G_ACTIONMONTH" (532)" has started.
Information 0x402090e0: Data Flow Task 7: The final commit for the data insertion in "component "Destination 33 - G_ACTION" (457)" has ended.
Information 0x402090e0: Data Flow Task 7: The final commit for the data insertion in "component "Destination 34 - G_ACTIONMONTH" (532)" has ended.
Information 0x402090df: Data Flow Task 7: The final commit for the data insertion in "component "Destination 31 - G_ACCVATREPORT" (193)" has started.
Information 0x402090e0: Data Flow Task 7: The final commit for the data insertion in "component "Destination 31 - G_ACCVATREPORT" (193)" has ended.
Information 0x402090df: Data Flow Task 7: The final commit for the data insertion in "component "Destination 30 - G_ACCTEMPLATELINK" (43)" has started.
Information 0x402090df: Data Flow Task 7: The final commit for the data insertion in "component "Destination 32 - G_ACCYEAR" (355)" has started.
Information 0x402090e0: Data Flow Task 7: The final commit for the data insertion in "component "Destination 30 - G_ACCTEMPLATELINK" (43)" has ended.
Information 0x402090e0: Data Flow Task 7: The final commit for the data insertion in "component "Destination 32 - G_ACCYEAR" (355)" has ended.
Information 0x402090df: Data Flow Task 8: The final commit for the data insertion in "component "Destination 35 - G_ACTIV" (121)" has started.
Information 0x402090df: Data Flow Task 8: The final commit for the data insertion in "component "Destination 37 - G_ACTIVL" (379)" has started.
Information 0x402090df: Data Flow Task 8: The final commit for the data insertion in "component "Destination 36 - G_ACTIVEX" (263)" has started.
Information 0x402090e0: Data Flow Task 8: The final commit for the data insertion in "component "Destination 35 - G_ACTIV" (121)" has ended.
Information 0x402090e0: Data Flow Task 8: The final commit for the data insertion in "component "Destination 37 - G_ACTIVL" (379)" has ended.
Information 0x402090e0: Data Flow Task 8: The final commit for the data insertion in "component "Destination 36 - G_ACTIVEX" (263)" has ended.
Information 0x402090df: Data Flow Task 8: The final commit for the data insertion in "component "Destination 39 - G_ACTTEMPLATEL" (619)" has started.
Information 0x402090df: Data Flow Task 8: The final commit for the data insertion in "component "Destination 38 - G_ACTTEMPLATE" (519)" has started.
Information 0x402090e0: Data Flow Task 8: The final commit for the data insertion in "component "Destination 39 - G_ACTTEMPLATEL" (619)" has ended.
Information 0x402090e0: Data Flow Task 8: The final commit for the data insertion in "component "Destination 38 - G_ACTTEMPLATE" (519)" has ended.
Information 0x402090df: Data Flow Task 9: The final commit for the data insertion in "component "Destination 44 - G_AssetFile" (584)" has started.
Information 0x402090df: Data Flow Task 9: The final commit for the data insertion in "component "Destination 43 - G_Asset" (444)" has started.
Information 0x402090e0: Data Flow Task 9: The final commit for the data insertion in "component "Destination 44 - G_AssetFile" (584)" has ended.
Information 0x402090e0: Data Flow Task 9: The final commit for the data insertion in "component "Destination 43 - G_Asset" (444)" has ended.
Information 0x402090df: Data Flow Task 9: The final commit for the data insertion in "component "Destination 41 - G_ACTTEMPLATEVALUE" (114)" has started.
Information 0x402090df: Data Flow Task 9: The final commit for the data insertion in "component "Destination 42 - G_ACTTYPE" (236)" has started.
Information 0x402090e0: Data Flow Task 9: The final commit for the data insertion in "component "Destination 41 - G_ACTTEMPLATEVALUE" (114)" has ended.
Information 0x402090e0: Data Flow Task 9: The final commit for the data insertion in "component "Destination 42 - G_ACTTYPE" (236)" has ended.
Information 0x402090df: Data Flow Task 9: The final commit for the data insertion in "component "Destination 40 - G_ACTTEMPLATELINK" (37)" has started.
Information 0x402090e0: Data Flow Task 9: The final commit for the data insertion in "component "Destination 40 - G_ACTTEMPLATELINK" (37)" has ended.
Information 0x402090df: Data Flow Task 10: The final commit for the data insertion in "component "Destination 45 - G_AssetLoanHistory" (52)" has started.
Information 0x402090df: Data Flow Task 10: The final commit for the data insertion in "component "Destination 49 - G_BANKACC" (464)" has started.
Information 0x402090df: Data Flow Task 10: The final commit for the data insertion in "component "Destination 47 - G_AssetUdf" (253)" has started.
Information 0x402090df: Data Flow Task 10: The final commit for the data insertion in "component "Destination 46 - G_AssetMusicScore" (163)" has started.
Information 0x402090e0: Data Flow Task 10: The final commit for the data insertion in "component "Destination 45 - G_AssetLoanHistory" (52)" has ended.
Information 0x402090e0: Data Flow Task 10: The final commit for the data insertion in "component "Destination 49 - G_BANKACC" (464)" has ended.
Information 0x402090e0: Data Flow Task 10: The final commit for the data insertion in "component "Destination 47 - G_AssetUdf" (253)" has ended.
Information 0x402090e0: Data Flow Task 10: The final commit for the data insertion in "component "Destination 46 - G_AssetMusicScore" (163)" has ended.
Information 0x402090df: Data Flow Task 10: The final commit for the data insertion in "component "Destination 48 - G_AssetUdfDef" (330)" has started.
Information 0x402090e0: Data Flow Task 10: The final commit for the data insertion in "component "Destination 48 - G_AssetUdfDef" (330)" has ended.
Information 0x402090df: Data Flow Task 11: The final commit for the data insertion in "component "Destination 50 - G_BUDGET" (163)" has started.
Information 0x402090df: Data Flow Task 11: The final commit for the data insertion in "component "Destination 51 - G_BUDGETACCID" (330)" has started.
Information 0x402090e0: Data Flow Task 11: The final commit for the data insertion in "component "Destination 50 - G_BUDGET" (163)" has ended.
Information 0x402090e0: Data Flow Task 11: The final commit for the data insertion in "component "Destination 51 - G_BUDGETACCID" (330)" has ended.
Information 0x402090df: Data Flow Task 11: The final commit for the data insertion in "component "Destination 53 - G_BUDGETFUNCTION" (547)" has started.
Information 0x402090e0: Data Flow Task 11: The final commit for the data insertion in "component "Destination 53 - G_BUDGETFUNCTION" (547)" has ended.
Information 0x402090df: Data Flow Task 11: The final commit for the data insertion in "component "Destination 54 - G_BUDGETIMPORT" (625)" has started.
Information 0x402090df: Data Flow Task 11: The final commit for the data insertion in "component "Destination 52 - G_BUDGETFORMULA" (447)" has started.
Information 0x402090e0: Data Flow Task 11: The final commit for the data insertion in "component "Destination 54 - G_BUDGETIMPORT" (625)" has ended.
Information 0x402090e0: Data Flow Task 11: The final commit for the data insertion in "component "Destination 52 - G_BUDGETFORMULA" (447)" has ended.
Information 0x402090df: Data Flow Task 12: The final commit for the data insertion in "component "Destination 55 - G_BUDGETL" (115)" has started.
Information 0x402090df: Data Flow Task 12: The final commit for the data insertion in "component "Destination 56 - G_BUDGETMAIN" (256)" has started.
Information 0x402090df: Data Flow Task 12: The final commit for the data insertion in "component "Destination 58 - G_BUDSALE" (553)" has started.
Information 0x402090df: Data Flow Task 12: The final commit for the data insertion in "component "Destination 59 - G_BUNT" (688)" has started.
Information 0x402090e0: Data Flow Task 12: The final commit for the data insertion in "component "Destination 55 - G_BUDGETL" (115)" has ended.
Information 0x402090e0: Data Flow Task 12: The final commit for the data insertion in "component "Destination 56 - G_BUDGETMAIN" (256)" has ended.
Information 0x402090e0: Data Flow Task 12: The final commit for the data insertion in "component "Destination 58 - G_BUDSALE" (553)" has ended.
Information 0x402090e0: Data Flow Task 12: The final commit for the data insertion in "component "Destination 59 - G_BUNT" (688)" has ended.
Information 0x402090df: Data Flow Task 12: The final commit for the data insertion in "component "Destination 57 - G_BUDGETTYPE" (374)" has started.
Information 0x402090e0: Data Flow Task 12: The final commit for the data insertion in "component "Destination 57 - G_BUDGETTYPE" (374)" has ended.
Information 0x402090df: Data Flow Task 13: The final commit for the data insertion in "component "Destination 60 - G_CASHFLOW" (67)" has started.
Information 0x402090df: Data Flow Task 13: The final commit for the data insertion in "component "Destination 61 - G_CASHFLOWCURRENT" (158)" has started.
Information 0x402090df: Data Flow Task 13: The final commit for the data insertion in "component "Destination 62 - G_CFIELD" (243)" has started.
Information 0x402090df: Data Flow Task 13: The final commit for the data insertion in "component "Destination 63 - G_CHANGELOG" (330)" has started.
Information 0x402090df: Data Flow Task 13: The final commit for the data insertion in "component "Destination 64 - G_CHANGELOGINVOICE" (407)" has started.
Information 0x402090e0: Data Flow Task 13: The final commit for the data insertion in "component "Destination 60 - G_CASHFLOW" (67)" has ended.
Information 0x402090e0: Data Flow Task 13: The final commit for the data insertion in "component "Destination 61 - G_CASHFLOWCURRENT" (158)" has ended.
Information 0x402090e0: Data Flow Task 13: The final commit for the data insertion in "component "Destination 63 - G_CHANGELOG" (330)" has ended.
Information 0x402090e0: Data Flow Task 13: The final commit for the data insertion in "component "Destination 64 - G_CHANGELOGINVOICE" (407)" has ended.
Information 0x402090e0: Data Flow Task 13: The final commit for the data insertion in "component "Destination 62 - G_CFIELD" (243)" has ended.
Information 0x402090df: Data Flow Task 14: The final commit for the data insertion in "component "Destination 65 - G_CHANGELOGJOURNAL" (40)" has started.
Information 0x402090df: Data Flow Task 14: The final commit for the data insertion in "component "Destination 69 - g_CompanyUser" (479)" has started.
Information 0x402090e0: Data Flow Task 14: The final commit for the data insertion in "component "Destination 65 - G_CHANGELOGJOURNAL" (40)" has ended.
Information 0x402090e0: Data Flow Task 14: The final commit for the data insertion in "component "Destination 69 - g_CompanyUser" (479)" has ended.
Information 0x402090df: Data Flow Task 14: The final commit for the data insertion in "component "Destination 68 - g_CompanyAccessGroup" (388)" has started.
Information 0x402090e0: Data Flow Task 14: The final commit for the data insertion in "component "Destination 68 - g_CompanyAccessGroup" (388)" has ended.
Information 0x402090df: Data Flow Task 14: The final commit for the data insertion in "component "Destination 66 - g_ClientSettings" (128)" has started.
Information 0x402090e0: Data Flow Task 14: The final commit for the data insertion in "component "Destination 66 - g_ClientSettings" (128)" has ended.
Information 0x402090df: Data Flow Task 14: The final commit for the data insertion in "component "Destination 67 - G_CLISYS" (268)" has started.
Information 0x402090e0: Data Flow Task 14: The final commit for the data insertion in "component "Destination 67 - G_CLISYS" (268)" has ended.
Information 0x402090df: Data Flow Task 15: The final commit for the data insertion in "component "Destination 70 - G_COMPLETEDMODULES" (43)" has started.
Information 0x402090df: Data Flow Task 15: The final commit for the data insertion in "component "Destination 71 - G_CONTAC" (430)" has started.
Information 0x402090df: Data Flow Task 15: The final commit for the data insertion in "component "Destination 73 - G_CONTGROUP" (812)" has started.
Information 0x402090df: Data Flow Task 15: The final commit for the data insertion in "component "Destination 72 - G_CONTACTAGREEMENT" (726)" has started.
Information 0x402090df: Data Flow Task 15: The final commit for the data insertion in "component "Destination 74 - G_CONTLOGG" (905)" has started.
Information 0x402090e0: Data Flow Task 15: The final commit for the data insertion in "component "Destination 70 - G_COMPLETEDMODULES" (43)" has ended.
Information 0x402090e0: Data Flow Task 15: The final commit for the data insertion in "component "Destination 71 - G_CONTAC" (430)" has ended.
Information 0x402090e0: Data Flow Task 15: The final commit for the data insertion in "component "Destination 73 - G_CONTGROUP" (812)" has ended.
Information 0x402090e0: Data Flow Task 15: The final commit for the data insertion in "component "Destination 72 - G_CONTACTAGREEMENT" (726)" has ended.
Information 0x402090e0: Data Flow Task 15: The final commit for the data insertion in "component "Destination 74 - G_CONTLOGG" (905)" has ended.
Information 0x402090df: Data Flow Task 16: The final commit for the data insertion in "component "Destination 79 - G_CSF" (649)" has started.
Information 0x402090e0: Data Flow Task 16: The final commit for the data insertion in "component "Destination 79 - G_CSF" (649)" has ended.
Information 0x402090df: Data Flow Task 16: The final commit for the data insertion in "component "Destination 78 - G_CPERS" (501)" has started.
Information 0x402090e0: Data Flow Task 16: The final commit for the data insertion in "component "Destination 78 - G_CPERS" (501)" has ended.
Information 0x402090df: Data Flow Task 16: The final commit for the data insertion in "component "Destination 75 - G_COSTS" (43)" has started.
Information 0x402090e0: Data Flow Task 16: The final commit for the data insertion in "component "Destination 75 - G_COSTS" (43)" has ended.
Information 0x402090df: Data Flow Task 16: The final commit for the data insertion in "component "Destination 77 - G_COUNTY" (295)" has started.
Information 0x402090df: Data Flow Task 16: The final commit for the data insertion in "component "Destination 76 - G_COUNTRY" (166)" has started.
Information 0x402090e0: Data Flow Task 16: The final commit for the data insertion in "component "Destination 77 - G_COUNTY" (295)" has ended.
Information 0x402090e0: Data Flow Task 16: The final commit for the data insertion in "component "Destination 76 - G_COUNTRY" (166)" has ended.
Information 0x402090df: Data Flow Task 17: The final commit for the data insertion in "component "Destination 83 - g_DbdBox" (331)" has started.
Information 0x402090df: Data Flow Task 17: The final commit for the data insertion in "component "Destination 82 - g_Dbd" (240)" has started.
Information 0x402090df: Data Flow Task 17: The final commit for the data insertion in "component "Destination 80 - G_CSSELEMENTS" (43)" has started.
Information 0x402090e0: Data Flow Task 17: The final commit for the data insertion in "component "Destination 83 - g_DbdBox" (331)" has ended.
Information 0x402090e0: Data Flow Task 17: The final commit for the data insertion in "component "Destination 82 - g_Dbd" (240)" has ended.
Information 0x402090e0: Data Flow Task 17: The final commit for the data insertion in "component "Destination 80 - G_CSSELEMENTS" (43)" has ended.
Information 0x402090df: Data Flow Task 17: The final commit for the data insertion in "component "Destination 84 - g_DbdBoxSubType" (409)" has started.
Information 0x402090df: Data Flow Task 17: The final commit for the data insertion in "component "Destination 81 - G_CURRENCY" (142)" has started.
Information 0x402090e0: Data Flow Task 17: The final commit for the data insertion in "component "Destination 84 - g_DbdBoxSubType" (409)" has ended.
Information 0x402090e0: Data Flow Task 17: The final commit for the data insertion in "component "Destination 81 - G_CURRENCY" (142)" has ended.
Information 0x402090df: Data Flow Task 18: The final commit for the data insertion in "component "Destination 87 - g_DbdChartPoint" (186)" has started.
Information 0x402090df: Data Flow Task 18: The final commit for the data insertion in "component "Destination 89 - g_DbdFinancials" (350)" has started.
Information 0x402090e0: Data Flow Task 18: The final commit for the data insertion in "component "Destination 87 - g_DbdChartPoint" (186)" has ended.
Information 0x402090e0: Data Flow Task 18: The final commit for the data insertion in "component "Destination 89 - g_DbdFinancials" (350)" has ended.
Information 0x402090df: Data Flow Task 18: The final commit for the data insertion in "component "Destination 85 - g_DbdChart" (43)" has started.
Information 0x402090df: Data Flow Task 18: The final commit for the data insertion in "component "Destination 86 - g_DbdChartDataSeries" (115)" has started.
Information 0x402090e0: Data Flow Task 18: The final commit for the data insertion in "component "Destination 85 - g_DbdChart" (43)" has ended.
Information 0x402090e0: Data Flow Task 18: The final commit for the data insertion in "component "Destination 86 - g_DbdChartDataSeries" (115)" has ended.
Information 0x402090df: Data Flow Task 18: The final commit for the data insertion in "component "Destination 88 - g_DbdEnumerators" (259)" has started.
Information 0x402090e0: Data Flow Task 18: The final commit for the data insertion in "component "Destination 88 - g_DbdEnumerators" (259)" has ended.
Information 0x402090df: Data Flow Task 19: The final commit for the data insertion in "component "Destination 92 - g_DbdMonitoredAccount" (293)" has started.
Information 0x402090df: Data Flow Task 19: The final commit for the data insertion in "component "Destination 90 - g_DbdKeyFigure" (55)" has started.
Information 0x402090e0: Data Flow Task 19: The final commit for the data insertion in "component "Destination 92 - g_DbdMonitoredAccount" (293)" has ended.
Information 0x402090e0: Data Flow Task 19: The final commit for the data insertion in "component "Destination 90 - g_DbdKeyFigure" (55)" has ended.
Information 0x402090df: Data Flow Task 19: The final commit for the data insertion in "component "Destination 91 - g_DbdKeyFigureLineType" (162)" has started.
Information 0x402090df: Data Flow Task 19: The final commit for the data insertion in "component "Destination 93 - g_DbdTemplate" (385)" has started.
Information 0x402090df: Data Flow Task 19: The final commit for the data insertion in "component "Destination 94 - g_DbdTemplateBox" (461)" has started.
Information 0x402090e0: Data Flow Task 19: The final commit for the data insertion in "component "Destination 91 - g_DbdKeyFigureLineType" (162)" has ended.
Information 0x402090e0: Data Flow Task 19: The final commit for the data insertion in "component "Destination 93 - g_DbdTemplate" (385)" has ended.
Information 0x402090e0: Data Flow Task 19: The final commit for the data insertion in "component "Destination 94 - g_DbdTemplateBox" (461)" has ended.
Information 0x402090df: Data Flow Task 20: The final commit for the data insertion in "component "Destination 96 - g_DeletedItems" (125)" has started.
Information 0x402090df: Data Flow Task 20: The final commit for the data insertion in "component "Destination 95 - g_DbdTopList" (49)" has started.
Information 0x402090df: Data Flow Task 20: The final commit for the data insertion in "component "Destination 98 - G_DISC" (404)" has started.
Information 0x402090df: Data Flow Task 20: The final commit for the data insertion in "component "Destination 99 - G_DOC" (572)" has started.
Information 0x402090e0: Data Flow Task 20: The final commit for the data insertion in "component "Destination 96 - g_DeletedItems" (125)" has ended.
Information 0x402090e0: Data Flow Task 20: The final commit for the data insertion in "component "Destination 95 - g_DbdTopList" (49)" has ended.
Information 0x402090e0: Data Flow Task 20: The final commit for the data insertion in "component "Destination 98 - G_DISC" (404)" has ended.
Information 0x402090e0: Data Flow Task 20: The final commit for the data insertion in "component "Destination 99 - G_DOC" (572)" has ended.
Information 0x402090df: Data Flow Task 20: The final commit for the data insertion in "component "Destination 97 - G_DELI" (259)" has started.
Information 0x402090e0: Data Flow Task 20: The final commit for the data insertion in "component "Destination 97 - G_DELI" (259)" has ended.
Information 0x402090df: Data Flow Task 21: The final commit for the data insertion in "component "Destination 101 - G_DOCL" (129)" has started.
Information 0x402090df: Data Flow Task 21: The final commit for the data insertion in "component "Destination 100 - G_DOCEX" (46)" has started.
Information 0x402090e0: Data Flow Task 21: The final commit for the data insertion in "component "Destination 101 - G_DOCL" (129)" has ended.
Information 0x402090e0: Data Flow Task 21: The final commit for the data insertion in "component "Destination 100 - G_DOCEX" (46)" has ended.
Information 0x402090df: Data Flow Task 21: The final commit for the data insertion in "component "Destination 103 - G_DOCTYPE" (338)" has started.
Information 0x402090df: Data Flow Task 21: The final commit for the data insertion in "component "Destination 104 - G_DOCTYPEL" (427)" has started.
Information 0x402090df: Data Flow Task 21: The final commit for the data insertion in "component "Destination 102 - G_DOCTEMPLATE" (227)" has started.
Information 0x402090e0: Data Flow Task 21: The final commit for the data insertion in "component "Destination 103 - G_DOCTYPE" (338)" has ended.
Information 0x402090e0: Data Flow Task 21: The final commit for the data insertion in "component "Destination 104 - G_DOCTYPEL" (427)" has ended.
Information 0x402090e0: Data Flow Task 21: The final commit for the data insertion in "component "Destination 102 - G_DOCTEMPLATE" (227)" has ended.
Information 0x402090df: Data Flow Task 22: The final commit for the data insertion in "component "Destination 106 - G_EDocDocument" (148)" has started.
Information 0x402090df: Data Flow Task 22: The final commit for the data insertion in "component "Destination 107 - G_EDocEventLog" (253)" has started.
Information 0x402090df: Data Flow Task 22: The final commit for the data insertion in "component "Destination 108 - G_EDocEventLogData" (334)" has started.
Information 0x402090df: Data Flow Task 22: The final commit for the data insertion in "component "Destination 109 - G_EDocKeyValue" (407)" has started.
Information 0x402090df: Data Flow Task 22: The final commit for the data insertion in "component "Destination 105 - G_EDocContactOnNetwork" (43)" has started.
Information 0x402090e0: Data Flow Task 22: The final commit for the data insertion in "component "Destination 106 - G_EDocDocument" (148)" has ended.
Information 0x402090e0: Data Flow Task 22: The final commit for the data insertion in "component "Destination 107 - G_EDocEventLog" (253)" has ended.
Information 0x402090e0: Data Flow Task 22: The final commit for the data insertion in "component "Destination 108 - G_EDocEventLogData" (334)" has ended.
Information 0x402090e0: Data Flow Task 22: The final commit for the data insertion in "component "Destination 109 - G_EDocKeyValue" (407)" has ended.
Information 0x402090e0: Data Flow Task 22: The final commit for the data insertion in "component "Destination 105 - G_EDocContactOnNetwork" (43)" has ended.
Information 0x402090df: Data Flow Task 23: The final commit for the data insertion in "component "Destination 114 - G_EMPAAMSG" (812)" has started.
Information 0x402090df: Data Flow Task 23: The final commit for the data insertion in "component "Destination 113 - G_EMPAA" (688)" has started.
Information 0x402090df: Data Flow Task 23: The final commit for the data insertion in "component "Destination 112 - G_EMP" (500)" has started.
Information 0x402090e0: Data Flow Task 23: The final commit for the data insertion in "component "Destination 114 - G_EMPAAMSG" (812)" has ended.
Information 0x402090e0: Data Flow Task 23: The final commit for the data insertion in "component "Destination 113 - G_EMPAA" (688)" has ended.
Information 0x402090e0: Data Flow Task 23: The final commit for the data insertion in "component "Destination 112 - G_EMP" (500)" has ended.
Information 0x402090df: Data Flow Task 23: The final commit for the data insertion in "component "Destination 110 - G_EINVSETTINGS" (94)" has started.
Information 0x402090e0: Data Flow Task 23: The final commit for the data insertion in "component "Destination 110 - G_EINVSETTINGS" (94)" has ended.
Information 0x402090df: Data Flow Task 23: The final commit for the data insertion in "component "Destination 111 - G_EMAIL" (242)" has started.
Information 0x402090e0: Data Flow Task 23: The final commit for the data insertion in "component "Destination 111 - G_EMAIL" (242)" has ended.
Information 0x402090df: Data Flow Task 24: The final commit for the data insertion in "component "Destination 118 - G_EMPCAR" (352)" has started.
Information 0x402090df: Data Flow Task 24: The final commit for the data insertion in "component "Destination 115 - G_EMPABS" (79)" has started.
Information 0x402090df: Data Flow Task 24: The final commit for the data insertion in "component "Destination 119 - G_EMPCODE" (449)" has started.
Information 0x402090e0: Data Flow Task 24: The final commit for the data insertion in "component "Destination 118 - G_EMPCAR" (352)" has ended.
Information 0x402090e0: Data Flow Task 24: The final commit for the data insertion in "component "Destination 115 - G_EMPABS" (79)" has ended.
Information 0x402090e0: Data Flow Task 24: The final commit for the data insertion in "component "Destination 119 - G_EMPCODE" (449)" has ended.
Information 0x402090df: Data Flow Task 24: The final commit for the data insertion in "component "Destination 116 - G_EMPABSSTATUS" (181)" has started.
Information 0x402090df: Data Flow Task 24: The final commit for the data insertion in "component "Destination 117 - G_EMPABSTYPE" (259)" has started.
Information 0x402090e0: Data Flow Task 24: The final commit for the data insertion in "component "Destination 116 - G_EMPABSSTATUS" (181)" has ended.
Information 0x402090e0: Data Flow Task 24: The final commit for the data insertion in "component "Destination 117 - G_EMPABSTYPE" (259)" has ended.
Information 0x402090df: Data Flow Task 25: The final commit for the data insertion in "component "Destination 121 - G_EMPEX" (467)" has started.
Information 0x402090df: Data Flow Task 25: The final commit for the data insertion in "component "Destination 120 - G_EMPCOMPETENCE" (58)" has started.
Information 0x402090df: Data Flow Task 25: The final commit for the data insertion in "component "Destination 122 - G_EMPNOTES" (768)" has started.
Information 0x402090df: Data Flow Task 25: The final commit for the data insertion in "component "Destination 123 - G_EMPRATES" (861)" has started.
Information 0x402090df: Data Flow Task 25: The final commit for the data insertion in "component "Destination 124 - G_EMPTAXCARD" (972)" has started.
Information 0x402090e0: Data Flow Task 25: The final commit for the data insertion in "component "Destination 121 - G_EMPEX" (467)" has ended.
Information 0x402090e0: Data Flow Task 25: The final commit for the data insertion in "component "Destination 120 - G_EMPCOMPETENCE" (58)" has ended.
Information 0x402090e0: Data Flow Task 25: The final commit for the data insertion in "component "Destination 122 - G_EMPNOTES" (768)" has ended.
Information 0x402090e0: Data Flow Task 25: The final commit for the data insertion in "component "Destination 123 - G_EMPRATES" (861)" has ended.
Information 0x402090e0: Data Flow Task 25: The final commit for the data insertion in "component "Destination 124 - G_EMPTAXCARD" (972)" has ended.
Information 0x402090df: Data Flow Task 26: The final commit for the data insertion in "component "Destination 125 - G_EMPTREKK" (70)" has started.
Information 0x402090df: Data Flow Task 26: The final commit for the data insertion in "component "Destination 126 - G_EMPUNION" (190)" has started.
Information 0x402090df: Data Flow Task 26: The final commit for the data insertion in "component "Destination 127 - G_EXCHANGETASK" (299)" has started.
Information 0x402090df: Data Flow Task 26: The final commit for the data insertion in "component "Destination 128 - G_EXTERNALSWOT" (387)" has started.
Information 0x402090df: Data Flow Task 26: The final commit for the data insertion in "component "Destination 129 - G_File" (465)" has started.
Information 0x402090e0: Data Flow Task 26: The final commit for the data insertion in "component "Destination 125 - G_EMPTREKK" (70)" has ended.
Information 0x402090e0: Data Flow Task 26: The final commit for the data insertion in "component "Destination 126 - G_EMPUNION" (190)" has ended.
Information 0x402090e0: Data Flow Task 26: The final commit for the data insertion in "component "Destination 127 - G_EXCHANGETASK" (299)" has ended.
Information 0x402090e0: Data Flow Task 26: The final commit for the data insertion in "component "Destination 128 - G_EXTERNALSWOT" (387)" has ended.
Information 0x402090e0: Data Flow Task 26: The final commit for the data insertion in "component "Destination 129 - G_File" (465)" has ended.
Information 0x402090df: Data Flow Task 27: The final commit for the data insertion in "component "Destination 130 - G_FILTER" (73)" has started.
Information 0x402090df: Data Flow Task 27: The final commit for the data insertion in "component "Destination 134 - G_IMPORT" (587)" has started.
Information 0x402090df: Data Flow Task 27: The final commit for the data insertion in "component "Destination 133 - G_GOAL" (366)" has started.
Information 0x402090df: Data Flow Task 27: The final commit for the data insertion in "component "Destination 132 - G_FILTERSTATIC" (294)" has started.
Information 0x402090df: Data Flow Task 27: The final commit for the data insertion in "component "Destination 131 - G_FILTERL" (198)" has started.
Information 0x402090e0: Data Flow Task 27: The final commit for the data insertion in "component "Destination 130 - G_FILTER" (73)" has ended.
Information 0x402090e0: Data Flow Task 27: The final commit for the data insertion in "component "Destination 134 - G_IMPORT" (587)" has ended.
Information 0x402090e0: Data Flow Task 27: The final commit for the data insertion in "component "Destination 133 - G_GOAL" (366)" has ended.
Information 0x402090e0: Data Flow Task 27: The final commit for the data insertion in "component "Destination 132 - G_FILTERSTATIC" (294)" has ended.
Information 0x402090e0: Data Flow Task 27: The final commit for the data insertion in "component "Destination 131 - G_FILTERL" (198)" has ended.
Information 0x402090df: Data Flow Task 28: The final commit for the data insertion in "component "Destination 137 - G_INTRASTAT" (213)" has started.
Information 0x402090df: Data Flow Task 28: The final commit for the data insertion in "component "Destination 136 - G_INTERNALSWOT" (126)" has started.
Information 0x402090df: Data Flow Task 28: The final commit for the data insertion in "component "Destination 135 - G_IMPRABATT" (46)" has started.
Information 0x402090df: Data Flow Task 28: The final commit for the data insertion in "component "Destination 138 - G_INTRASTATL" (345)" has started.
Information 0x402090e0: Data Flow Task 28: The final commit for the data insertion in "component "Destination 137 - G_INTRASTAT" (213)" has ended.
Information 0x402090e0: Data Flow Task 28: The final commit for the data insertion in "component "Destination 136 - G_INTERNALSWOT" (126)" has ended.
Information 0x402090e0: Data Flow Task 28: The final commit for the data insertion in "component "Destination 135 - G_IMPRABATT" (46)" has ended.
Information 0x402090e0: Data Flow Task 28: The final commit for the data insertion in "component "Destination 138 - G_INTRASTATL" (345)" has ended.
Information 0x402090df: Data Flow Task 28: The final commit for the data insertion in "component "Destination 139 - G_INVCONST" (440)" has started.
Information 0x402090e0: Data Flow Task 28: The final commit for the data insertion in "component "Destination 139 - G_INVCONST" (440)" has ended.
Information 0x402090df: Data Flow Task 29: The final commit for the data insertion in "component "Destination 141 - G_KEYFIGURECACHE" (115)" has started.
Information 0x402090df: Data Flow Task 29: The final commit for the data insertion in "component "Destination 142 - G_LOGG" (189)" has started.
Information 0x402090df: Data Flow Task 29: The final commit for the data insertion in "component "Destination 144 - G_MailSubscription" (328)" has started.
Information 0x402090e0: Data Flow Task 29: The final commit for the data insertion in "component "Destination 141 - G_KEYFIGURECACHE" (115)" has ended.
Information 0x402090e0: Data Flow Task 29: The final commit for the data insertion in "component "Destination 142 - G_LOGG" (189)" has ended.
Information 0x402090e0: Data Flow Task 29: The final commit for the data insertion in "component "Destination 144 - G_MailSubscription" (328)" has ended.
Information 0x402090df: Data Flow Task 29: The final commit for the data insertion in "component "Destination 143 - G_MAILBOX" (264)" has started.
Information 0x402090e0: Data Flow Task 29: The final commit for the data insertion in "component "Destination 143 - G_MAILBOX" (264)" has ended.
Information 0x402090df: Data Flow Task 29: The final commit for the data insertion in "component "Destination 140 - G_INVCONSTL" (43)" has started.
Information 0x402090e0: Data Flow Task 29: The final commit for the data insertion in "component "Destination 140 - G_INVCONSTL" (43)" has ended.
Information 0x402090df: Data Flow Task 30: The final commit for the data insertion in "component "Destination 146 - G_MAINL" (374)" has started.
Information 0x402090df: Data Flow Task 30: The final commit for the data insertion in "component "Destination 145 - G_MAIN" (94)" has started.
Information 0x402090df: Data Flow Task 30: The final commit for the data insertion in "component "Destination 149 - G_MAINLMATCH" (812)" has started.
Information 0x402090df: Data Flow Task 30: The final commit for the data insertion in "component "Destination 148 - G_MAINLINTEREST" (682)" has started.
Information 0x402090df: Data Flow Task 30: The final commit for the data insertion in "component "Destination 147 - G_MAINLCUST" (579)" has started.
Information 0x402090e0: Data Flow Task 30: The final commit for the data insertion in "component "Destination 146 - G_MAINL" (374)" has ended.
Information 0x402090e0: Data Flow Task 30: The final commit for the data insertion in "component "Destination 145 - G_MAIN" (94)" has ended.
Information 0x402090e0: Data Flow Task 30: The final commit for the data insertion in "component "Destination 149 - G_MAINLMATCH" (812)" has ended.
Information 0x402090e0: Data Flow Task 30: The final commit for the data insertion in "component "Destination 148 - G_MAINLINTEREST" (682)" has ended.
Information 0x402090e0: Data Flow Task 30: The final commit for the data insertion in "component "Destination 147 - G_MAINLCUST" (579)" has ended.
Information 0x402090df: Data Flow Task 31: The final commit for the data insertion in "component "Destination 150 - G_MAINLREPORT" (79)" has started.
Information 0x402090df: Data Flow Task 31: The final commit for the data insertion in "component "Destination 151 - G_MAINLREPORTL" (202)" has started.
Information 0x402090df: Data Flow Task 31: The final commit for the data insertion in "component "Destination 152 - G_MAINLVEND" (309)" has started.
Information 0x402090df: Data Flow Task 31: The final commit for the data insertion in "component "Destination 153 - G_MOTIONVOUCHERLINK" (388)" has started.
Information 0x402090df: Data Flow Task 31: The final commit for the data insertion in "component "Destination 154 - G_NELFODISC" (469)" has started.
Information 0x402090e0: Data Flow Task 31: The final commit for the data insertion in "component "Destination 150 - G_MAINLREPORT" (79)" has ended.
Information 0x402090e0: Data Flow Task 31: The final commit for the data insertion in "component "Destination 151 - G_MAINLREPORTL" (202)" has ended.
Information 0x402090e0: Data Flow Task 31: The final commit for the data insertion in "component "Destination 152 - G_MAINLVEND" (309)" has ended.
Information 0x402090e0: Data Flow Task 31: The final commit for the data insertion in "component "Destination 153 - G_MOTIONVOUCHERLINK" (388)" has ended.
Information 0x402090e0: Data Flow Task 31: The final commit for the data insertion in "component "Destination 154 - G_NELFODISC" (469)" has ended.
Information 0x402090df: Data Flow Task 32: The final commit for the data insertion in "component "Destination 155 - G_NELFOGROUP" (46)" has started.
Information 0x402090df: Data Flow Task 32: The final commit for the data insertion in "component "Destination 156 - G_NELFOPROD" (183)" has started.
Information 0x402090df: Data Flow Task 32: The final commit for the data insertion in "component "Destination 158 - G_ORDER" (860)" has started.
Information 0x402090df: Data Flow Task 32: The final commit for the data insertion in "component "Destination 159 - G_ORDERALTTOTAL" (1273)" has started.
Information 0x402090e0: Data Flow Task 32: The final commit for the data insertion in "component "Destination 155 - G_NELFOGROUP" (46)" has ended.
Information 0x402090e0: Data Flow Task 32: The final commit for the data insertion in "component "Destination 156 - G_NELFOPROD" (183)" has ended.
Information 0x402090e0: Data Flow Task 32: The final commit for the data insertion in "component "Destination 158 - G_ORDER" (860)" has ended.
Information 0x402090e0: Data Flow Task 32: The final commit for the data insertion in "component "Destination 159 - G_ORDERALTTOTAL" (1273)" has ended.
Information 0x402090df: Data Flow Task 32: The final commit for the data insertion in "component "Destination 157 - G_NUMBER" (290)" has started.
Information 0x402090e0: Data Flow Task 32: The final commit for the data insertion in "component "Destination 157 - G_NUMBER" (290)" has ended.
Information 0x402090df: Data Flow Task 33: The final commit for the data insertion in "component "Destination 162 - G_ORDEREX" (192)" has started.
Information 0x402090df: Data Flow Task 33: The final commit for the data insertion in "component "Destination 161 - G_ORDEREDOC" (98)" has started.
Information 0x402090df: Data Flow Task 33: The final commit for the data insertion in "component "Destination 164 - G_ORDERLINK" (695)" has started.
Information 0x402090df: Data Flow Task 33: The final commit for the data insertion in "component "Destination 163 - G_ORDERL" (483)" has started.
Information 0x402090e0: Data Flow Task 33: The final commit for the data insertion in "component "Destination 162 - G_ORDEREX" (192)" has ended.
Information 0x402090e0: Data Flow Task 33: The final commit for the data insertion in "component "Destination 161 - G_ORDEREDOC" (98)" has ended.
Information 0x402090e0: Data Flow Task 33: The final commit for the data insertion in "component "Destination 164 - G_ORDERLINK" (695)" has ended.
Information 0x402090e0: Data Flow Task 33: The final commit for the data insertion in "component "Destination 163 - G_ORDERL" (483)" has ended.
Information 0x402090df: Data Flow Task 33: The final commit for the data insertion in "component "Destination 160 - G_ORDERCREATORS" (31)" has started.
Information 0x402090e0: Data Flow Task 33: The final commit for the data insertion in "component "Destination 160 - G_ORDERCREATORS" (31)" has ended.
Information 0x402090df: Data Flow Task 34: The final commit for the data insertion in "component "Destination 167 - G_PAYROLL" (499)" has started.
Information 0x402090df: Data Flow Task 34: The final commit for the data insertion in "component "Destination 168 - G_PAYROLLL" (737)" has started.
Information 0x402090df: Data Flow Task 34: The final commit for the data insertion in "component "Destination 169 - G_PAYROLLLTAXCODE" (884)" has started.
Information 0x402090e0: Data Flow Task 34: The final commit for the data insertion in "component "Destination 167 - G_PAYROLL" (499)" has ended.
Information 0x402090e0: Data Flow Task 34: The final commit for the data insertion in "component "Destination 168 - G_PAYROLLL" (737)" has ended.
Information 0x402090e0: Data Flow Task 34: The final commit for the data insertion in "component "Destination 169 - G_PAYROLLLTAXCODE" (884)" has ended.
Information 0x402090df: Data Flow Task 34: The final commit for the data insertion in "component "Destination 165 - G_ORDERNUMBER" (37)" has started.
Information 0x402090e0: Data Flow Task 34: The final commit for the data insertion in "component "Destination 165 - G_ORDERNUMBER" (37)" has ended.
Information 0x402090df: Data Flow Task 34: The final commit for the data insertion in "component "Destination 166 - G_ORDERSTATUS" (234)" has started.
Information 0x402090e0: Data Flow Task 34: The final commit for the data insertion in "component "Destination 166 - G_ORDERSTATUS" (234)" has ended.
Information 0x402090df: Data Flow Task 35: The final commit for the data insertion in "component "Destination 172 - G_PICTURE" (397)" has started.
Information 0x402090df: Data Flow Task 35: The final commit for the data insertion in "component "Destination 174 - G_POST" (575)" has started.
Information 0x402090e0: Data Flow Task 35: The final commit for the data insertion in "component "Destination 172 - G_PICTURE" (397)" has ended.
Information 0x402090e0: Data Flow Task 35: The final commit for the data insertion in "component "Destination 174 - G_POST" (575)" has ended.
Information 0x402090df: Data Flow Task 35: The final commit for the data insertion in "component "Destination 170 - G_PAYTERM" (82)" has started.
Information 0x402090df: Data Flow Task 35: The final commit for the data insertion in "component "Destination 173 - G_POCKETPCFIELDS" (489)" has started.
Information 0x402090e0: Data Flow Task 35: The final commit for the data insertion in "component "Destination 170 - G_PAYTERM" (82)" has ended.
Information 0x402090e0: Data Flow Task 35: The final commit for the data insertion in "component "Destination 173 - G_POCKETPCFIELDS" (489)" has ended.
Information 0x402090df: Data Flow Task 35: The final commit for the data insertion in "component "Destination 171 - G_PAYTERML" (264)" has started.
Information 0x402090e0: Data Flow Task 35: The final commit for the data insertion in "component "Destination 171 - G_PAYTERML" (264)" has ended.
Information 0x402090df: Data Flow Task 36: The final commit for the data insertion in "component "Destination 176 - G_PRICEJUST" (211)" has started.
Information 0x402090df: Data Flow Task 36: The final commit for the data insertion in "component "Destination 175 - G_PRICE" (70)" has started.
Information 0x402090df: Data Flow Task 36: The final commit for the data insertion in "component "Destination 178 - G_PRODDESC" (905)" has started.
Information 0x402090df: Data Flow Task 36: The final commit for the data insertion in "component "Destination 177 - G_PROD" (622)" has started.
Information 0x402090e0: Data Flow Task 36: The final commit for the data insertion in "component "Destination 176 - G_PRICEJUST" (211)" has ended.
Information 0x402090e0: Data Flow Task 36: The final commit for the data insertion in "component "Destination 175 - G_PRICE" (70)" has ended.
Information 0x402090e0: Data Flow Task 36: The final commit for the data insertion in "component "Destination 178 - G_PRODDESC" (905)" has ended.
Information 0x402090e0: Data Flow Task 36: The final commit for the data insertion in "component "Destination 177 - G_PROD" (622)" has ended.
Information 0x402090df: Data Flow Task 36: The final commit for the data insertion in "component "Destination 179 - G_PRODGROUP" (988)" has started.
Information 0x402090e0: Data Flow Task 36: The final commit for the data insertion in "component "Destination 179 - G_PRODGROUP" (988)" has ended.
Information 0x402090df: Data Flow Task 37: The final commit for the data insertion in "component "Destination 183 - G_PROJ" (606)" has started.
Information 0x402090df: Data Flow Task 37: The final commit for the data insertion in "component "Destination 182 - G_PRODVEND" (317)" has started.
Information 0x402090df: Data Flow Task 37: The final commit for the data insertion in "component "Destination 181 - G_PRODTAX" (159)" has started.
Information 0x402090df: Data Flow Task 37: The final commit for the data insertion in "component "Destination 180 - G_PRODONWEB" (64)" has started.
Information 0x402090df: Data Flow Task 37: The final commit for the data insertion in "component "Destination 184 - G_PROJLNK" (799)" has started.
Information 0x402090e0: Data Flow Task 37: The final commit for the data insertion in "component "Destination 183 - G_PROJ" (606)" has ended.
Information 0x402090e0: Data Flow Task 37: The final commit for the data insertion in "component "Destination 182 - G_PRODVEND" (317)" has ended.
Information 0x402090e0: Data Flow Task 37: The final commit for the data insertion in "component "Destination 181 - G_PRODTAX" (159)" has ended.
Information 0x402090e0: Data Flow Task 37: The final commit for the data insertion in "component "Destination 180 - G_PRODONWEB" (64)" has ended.
Information 0x402090e0: Data Flow Task 37: The final commit for the data insertion in "component "Destination 184 - G_PROJLNK" (799)" has ended.
Information 0x402090df: Data Flow Task 38: The final commit for the data insertion in "component "Destination 186 - G_PROJSTATUS" (123)" has started.
Information 0x402090df: Data Flow Task 38: The final commit for the data insertion in "component "Destination 185 - G_PROJPLAN" (46)" has started.
Information 0x402090df: Data Flow Task 38: The final commit for the data insertion in "component "Destination 189 - G_PURCLOG" (977)" has started.
Information 0x402090df: Data Flow Task 38: The final commit for the data insertion in "component "Destination 187 - G_PURC" (358)" has started.
Information 0x402090df: Data Flow Task 38: The final commit for the data insertion in "component "Destination 188 - G_PURCL" (740)" has started.
Information 0x402090e0: Data Flow Task 38: The final commit for the data insertion in "component "Destination 186 - G_PROJSTATUS" (123)" has ended.
Information 0x402090e0: Data Flow Task 38: The final commit for the data insertion in "component "Destination 185 - G_PROJPLAN" (46)" has ended.
Information 0x402090e0: Data Flow Task 38: The final commit for the data insertion in "component "Destination 189 - G_PURCLOG" (977)" has ended.
Information 0x402090e0: Data Flow Task 38: The final commit for the data insertion in "component "Destination 187 - G_PURC" (358)" has ended.
Information 0x402090e0: Data Flow Task 38: The final commit for the data insertion in "component "Destination 188 - G_PURCL" (740)" has ended.
Information 0x402090df: Data Flow Task 39: The final commit for the data insertion in "component "Destination 194 - G_REMINDER" (375)" has started.
Information 0x402090df: Data Flow Task 39: The final commit for the data insertion in "component "Destination 193 - G_REGION" (297)" has started.
Information 0x402090df: Data Flow Task 39: The final commit for the data insertion in "component "Destination 190 - G_PURCSALESLINK" (49)" has started.
Information 0x402090e0: Data Flow Task 39: The final commit for the data insertion in "component "Destination 194 - G_REMINDER" (375)" has ended.
Information 0x402090e0: Data Flow Task 39: The final commit for the data insertion in "component "Destination 193 - G_REGION" (297)" has ended.
Information 0x402090e0: Data Flow Task 39: The final commit for the data insertion in "component "Destination 190 - G_PURCSALESLINK" (49)" has ended.
Information 0x402090df: Data Flow Task 39: The final commit for the data insertion in "component "Destination 192 - g_Queries" (221)" has started.
Information 0x402090df: Data Flow Task 39: The final commit for the data insertion in "component "Destination 191 - G_PURCSTATUS" (140)" has started.
Information 0x402090e0: Data Flow Task 39: The final commit for the data insertion in "component "Destination 192 - g_Queries" (221)" has ended.
Information 0x402090e0: Data Flow Task 39: The final commit for the data insertion in "component "Destination 191 - G_PURCSTATUS" (140)" has ended.
Information 0x402090df: Data Flow Task 40: The final commit for the data insertion in "component "Destination 195 - G_REMIT" (85)" has started.
Information 0x402090df: Data Flow Task 40: The final commit for the data insertion in "component "Destination 197 - G_REPORTFAV" (300)" has started.
Information 0x402090df: Data Flow Task 40: The final commit for the data insertion in "component "Destination 196 - G_REMLOG" (206)" has started.
Information 0x402090df: Data Flow Task 40: The final commit for the data insertion in "component "Destination 199 - G_REVENUES" (470)" has started.
Information 0x402090df: Data Flow Task 40: The final commit for the data insertion in "component "Destination 198 - G_REPORTFAVL" (388)" has started.
Information 0x402090e0: Data Flow Task 40: The final commit for the data insertion in "component "Destination 195 - G_REMIT" (85)" has ended.
Information 0x402090e0: Data Flow Task 40: The final commit for the data insertion in "component "Destination 197 - G_REPORTFAV" (300)" has ended.
Information 0x402090e0: Data Flow Task 40: The final commit for the data insertion in "component "Destination 196 - G_REMLOG" (206)" has ended.
Information 0x402090e0: Data Flow Task 40: The final commit for the data insertion in "component "Destination 199 - G_REVENUES" (470)" has ended.
Information 0x402090e0: Data Flow Task 40: The final commit for the data insertion in "component "Destination 198 - G_REPORTFAVL" (388)" has ended.
Information 0x402090df: Data Flow Task 41: The final commit for the data insertion in "component "Destination 203 - G_STOREITEM" (350)" has started.
(SQL Server Import and Export Wizard)
Information 0x402090df: Data Flow Task 41: The final commit for the data insertion in "component "Destination 204 - G_STORELINK" (498)" has started.
Information 0x402090e0: Data Flow Task 41: The final commit for the data insertion in "component "Destination 203 - G_STOREITEM" (350)" has ended.
Information 0x402090e0: Data Flow Task 41: The final commit for the data insertion in "component "Destination 204 - G_STORELINK" (498)" has ended.
Information 0x402090df: Data Flow Task 41: The final commit for the data insertion in "component "Destination 202 - G_STORECAT" (237)" has started.
Information 0x402090e0: Data Flow Task 41: The final commit for the data insertion in "component "Destination 202 - G_STORECAT" (237)" has ended.
Information 0x402090df: Data Flow Task 41: The final commit for the data insertion in "component "Destination 200 - G_STDREG" (55)" has started.
Information 0x402090df: Data Flow Task 41: The final commit for the data insertion in "component "Destination 201 - G_STORE" (150)" has started.
Information 0x402090e0: Data Flow Task 41: The final commit for the data insertion in "component "Destination 200 - G_STDREG" (55)" has ended.
Information 0x402090e0: Data Flow Task 41: The final commit for the data insertion in "component "Destination 201 - G_STORE" (150)" has ended.
Information 0x402090df: Data Flow Task 42: The final commit for the data insertion in "component "Destination 207 - G_STOREMIN" (328)" has started.
Information 0x402090df: Data Flow Task 42: The final commit for the data insertion in "component "Destination 206 - g_StoreMBalanceLog" (141)" has started.
Information 0x402090df: Data Flow Task 42: The final commit for the data insertion in "component "Destination 208 - G_STOREMINFO" (544)" has started.
Information 0x402090df: Data Flow Task 42: The final commit for the data insertion in "component "Destination 209 - G_STOREMOUT" (763)" has started.
Information 0x402090e0: Data Flow Task 42: The final commit for the data insertion in "component "Destination 207 - G_STOREMIN" (328)" has ended.
Information 0x402090e0: Data Flow Task 42: The final commit for the data insertion in "component "Destination 206 - g_StoreMBalanceLog" (141)" has ended.
Information 0x402090e0: Data Flow Task 42: The final commit for the data insertion in "component "Destination 208 - G_STOREMINFO" (544)" has ended.
Information 0x402090e0: Data Flow Task 42: The final commit for the data insertion in "component "Destination 209 - G_STOREMOUT" (763)" has ended.
Information 0x402090df: Data Flow Task 42: The final commit for the data insertion in "component "Destination 205 - G_STORELOC" (46)" has started.
Information 0x402090e0: Data Flow Task 42: The final commit for the data insertion in "component "Destination 205 - G_STORELOC" (46)" has ended.
Information 0x402090df: Data Flow Task 43: The final commit for the data insertion in "component "Destination 210 - G_STRUC" (46)" has started.
Information 0x402090df: Data Flow Task 43: The final commit for the data insertion in "component "Destination 214 - G_SYNCLOG" (340)" has started.
Information 0x402090df: Data Flow Task 43: The final commit for the data insertion in "component "Destination 213 - g_syncConstraint" (268)" has started.
Information 0x402090df: Data Flow Task 43: The final commit for the data insertion in "component "Destination 212 - G_SYNCCONFLICTL" (195)" has started.
Information 0x402090df: Data Flow Task 43: The final commit for the data insertion in "component "Destination 211 - G_SYNCCONFLICT" (117)" has started.
Information 0x402090e0: Data Flow Task 43: The final commit for the data insertion in "component "Destination 210 - G_STRUC" (46)" has ended.
Information 0x402090e0: Data Flow Task 43: The final commit for the data insertion in "component "Destination 214 - G_SYNCLOG" (340)" has ended.
Information 0x402090e0: Data Flow Task 43: The final commit for the data insertion in "component "Destination 213 - g_syncConstraint" (268)" has ended.
Information 0x402090e0: Data Flow Task 43: The final commit for the data insertion in "component "Destination 212 - G_SYNCCONFLICTL" (195)" has ended.
Information 0x402090e0: Data Flow Task 43: The final commit for the data insertion in "component "Destination 211 - G_SYNCCONFLICT" (117)" has ended.
Information 0x402090df: Data Flow Task 44: The final commit for the data insertion in "component "Destination 217 - G_SYNCRECORD" (200)" has started.
Information 0x402090df: Data Flow Task 44: The final commit for the data insertion in "component "Destination 218 - G_SYNCRECORDSNAPSHOT" (277)" has started.
Information 0x402090df: Data Flow Task 44: The final commit for the data insertion in "component "Destination 219 - G_SYNCRECORDTEMPSTORAGE" (366)" has started.
Information 0x402090e0: Data Flow Task 44: The final commit for the data insertion in "component "Destination 217 - G_SYNCRECORD" (200)" has ended.
Information 0x402090e0: Data Flow Task 44: The final commit for the data insertion in "component "Destination 218 - G_SYNCRECORDSNAPSHOT" (277)" has ended.
Information 0x402090e0: Data Flow Task 44: The final commit for the data insertion in "component "Destination 219 - G_SYNCRECORDTEMPSTORAGE" (366)" has ended.
Information 0x402090df: Data Flow Task 44: The final commit for the data insertion in "component "Destination 216 - G_SYNCNUMBER" (105)" has started.
Information 0x402090df: Data Flow Task 44: The final commit for the data insertion in "component "Destination 215 - G_SYNCMAPPINGCONSTANT" (37)" has started.
Information 0x402090e0: Data Flow Task 44: The final commit for the data insertion in "component "Destination 216 - G_SYNCNUMBER" (105)" has ended.
Information 0x402090e0: Data Flow Task 44: The final commit for the data insertion in "component "Destination 215 - G_SYNCMAPPINGCONSTANT" (37)" has ended.
Warning 0x80019002: Data Flow Task 44: SSIS Warning Code DTS_W_MAXIMUMERRORCOUNTREACHED. The Execution method succeeded, but the number of errors raised (2) reached the maximum allowed (1); resulting in failure. This occurs when the number of errors reaches the number specified in MaximumErrorCount. Change the MaximumErrorCount or fix the errors.
- Post-execute (Success)
Messages
Information 0x4004300b: Data Flow Task 1: "component "Destination - G_ACC" (139)" wrote 138 rows.
Information 0x4004300b: Data Flow Task 1: "component "Destination 1 - G_ACCBANKIMPORT" (389)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 1: "component "Destination 2 - G_ACCBANKRECON" (554)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 1: "component "Destination 3 - G_ACCCASHVAT" (648)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 1: "component "Destination 4 - G_ACCCODE" (739)" wrote 46 rows.
Information 0x4004300b: Data Flow Task 2: "component "Destination 5 - G_ACCCODEGROUP" (40)" wrote 51 rows.
Information 0x4004300b: Data Flow Task 2: "component "Destination 6 - G_ACCCODEGROUPL" (116)" wrote 50 rows.
Information 0x4004300b: Data Flow Task 2: "component "Destination 7 - G_ACCCODESTRUCTURE" (209)" wrote 52 rows.
Information 0x4004300b: Data Flow Task 2: "component "Destination 8 - G_ACCCODESYSTEM" (300)" wrote 12 rows.
Information 0x4004300b: Data Flow Task 2: "component "Destination 9 - g_ACCCOSTCENTER" (371)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 3: "component "Destination 10 - g_ACCCOSTCENTERL" (40)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 3: "component "Destination 11 - G_ACCDELNUMBER" (110)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 3: "component "Destination 12 - G_ACCFACTCONT" (205)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 3: "component "Destination 13 - G_ACCFILEARCHIVE" (303)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 3: "component "Destination 14 - G_ACCIDREF" (382)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 4: "component "Destination 15 - G_ACCNUMBER" (43)" wrote 13 rows.
Information 0x4004300b: Data Flow Task 4: "component "Destination 16 - G_ACCOCR" (112)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 4: "component "Destination 17 - G_ACCPARAMETER" (205)" wrote 9 rows.
Information 0x4004300b: Data Flow Task 4: "component "Destination 18 - G_ACCPERIODTERMIN" (327)" wrote 13 rows.
Information 0x4004300b: Data Flow Task 4: "component "Destination 19 - G_ACCREG" (446)" wrote 13 rows.
Information 0x4004300b: Data Flow Task 5: "component "Destination 20 - G_ACCREGL" (40)" wrote 3 rows.
Information 0x4004300b: Data Flow Task 5: "component "Destination 21 - G_ACCREMITSETUP" (179)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 5: "component "Destination 22 - G_ACCRES" (305)" wrote 3 rows.
Information 0x4004300b: Data Flow Task 5: "component "Destination 23 - G_ACCSETUP" (390)" wrote 1 rows.
Information 0x4004300b: Data Flow Task 5: "component "Destination 24 - G_ACCSRU" (473)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 6: "component "Destination 25 - G_ACCSUM" (40)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 6: "component "Destination 26 - G_ACCSUMMAIN" (122)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 6: "component "Destination 27 - G_ACCTEMPLATE" (213)" wrote 3 rows.
Information 0x4004300b: Data Flow Task 6: "component "Destination 28 - G_ACCTEMPLATEGROUP" (291)" wrote 1 rows.
Information 0x4004300b: Data Flow Task 6: "component "Destination 29 - G_ACCTEMPLATELINE" (395)" wrote 6 rows.
Information 0x4004300b: Data Flow Task 7: "component "Destination 30 - G_ACCTEMPLATELINK" (43)" wrote 3 rows.
Information 0x4004300b: Data Flow Task 7: "component "Destination 31 - G_ACCVATREPORT" (193)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 7: "component "Destination 32 - G_ACCYEAR" (355)" wrote 1 rows.
Information 0x4004300b: Data Flow Task 7: "component "Destination 33 - G_ACTION" (457)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 7: "component "Destination 34 - G_ACTIONMONTH" (532)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 8: "component "Destination 35 - G_ACTIV" (121)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 8: "component "Destination 36 - G_ACTIVEX" (263)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 8: "component "Destination 37 - G_ACTIVL" (379)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 8: "component "Destination 38 - G_ACTTEMPLATE" (519)" wrote 95 rows.
Information 0x4004300b: Data Flow Task 8: "component "Destination 39 - G_ACTTEMPLATEL" (619)" wrote 22 rows.
Information 0x4004300b: Data Flow Task 9: "component "Destination 40 - G_ACTTEMPLATELINK" (37)" wrote 239 rows.
Information 0x4004300b: Data Flow Task 9: "component "Destination 41 - G_ACTTEMPLATEVALUE" (114)" wrote 109 rows.
Information 0x4004300b: Data Flow Task 9: "component "Destination 42 - G_ACTTYPE" (236)" wrote 30 rows.
Information 0x4004300b: Data Flow Task 9: "component "Destination 43 - G_Asset" (444)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 9: "component "Destination 44 - G_AssetFile" (584)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 10: "component "Destination 45 - G_AssetLoanHistory" (52)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 10: "component "Destination 46 - G_AssetMusicScore" (163)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 10: "component "Destination 47 - G_AssetUdf" (253)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 10: "component "Destination 48 - G_AssetUdfDef" (330)" wrote 6 rows.
Information 0x4004300b: Data Flow Task 10: "component "Destination 49 - G_BANKACC" (464)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 11: "component "Destination 50 - G_BUDGET" (163)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 11: "component "Destination 51 - G_BUDGETACCID" (330)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 11: "component "Destination 52 - G_BUDGETFORMULA" (447)" wrote 1 rows.
Information 0x4004300b: Data Flow Task 11: "component "Destination 53 - G_BUDGETFUNCTION" (547)" wrote 6 rows.
Information 0x4004300b: Data Flow Task 11: "component "Destination 54 - G_BUDGETIMPORT" (625)" wrote 6 rows.
Information 0x4004300b: Data Flow Task 12: "component "Destination 55 - G_BUDGETL" (115)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 12: "component "Destination 56 - G_BUDGETMAIN" (256)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 12: "component "Destination 57 - G_BUDGETTYPE" (374)" wrote 12 rows.
Information 0x4004300b: Data Flow Task 12: "component "Destination 58 - G_BUDSALE" (553)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 12: "component "Destination 59 - G_BUNT" (688)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 13: "component "Destination 60 - G_CASHFLOW" (67)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 13: "component "Destination 61 - G_CASHFLOWCURRENT" (158)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 13: "component "Destination 62 - G_CFIELD" (243)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 13: "component "Destination 63 - G_CHANGELOG" (330)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 13: "component "Destination 64 - G_CHANGELOGINVOICE" (407)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 14: "component "Destination 65 - G_CHANGELOGJOURNAL" (40)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 14: "component "Destination 66 - g_ClientSettings" (128)" wrote 448 rows.
Information 0x4004300b: Data Flow Task 14: "component "Destination 67 - G_CLISYS" (268)" wrote 457 rows.
Information 0x4004300b: Data Flow Task 14: "component "Destination 68 - g_CompanyAccessGroup" (388)" wrote 7 rows.
Information 0x4004300b: Data Flow Task 14: "component "Destination 69 - g_CompanyUser" (479)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 15: "component "Destination 70 - G_COMPLETEDMODULES" (43)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 15: "component "Destination 71 - G_CONTAC" (430)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 15: "component "Destination 72 - G_CONTACTAGREEMENT" (726)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 15: "component "Destination 73 - G_CONTGROUP" (812)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 15: "component "Destination 74 - G_CONTLOGG" (905)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 16: "component "Destination 75 - G_COSTS" (43)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 16: "component "Destination 76 - G_COUNTRY" (166)" wrote 240 rows.
Information 0x4004300b: Data Flow Task 16: "component "Destination 77 - G_COUNTY" (295)" wrote 580 rows.
Information 0x4004300b: Data Flow Task 16: "component "Destination 78 - G_CPERS" (501)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 16: "component "Destination 79 - G_CSF" (649)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 17: "component "Destination 80 - G_CSSELEMENTS" (43)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 17: "component "Destination 81 - G_CURRENCY" (142)" wrote 71 rows.
Information 0x4004300b: Data Flow Task 17: "component "Destination 82 - g_Dbd" (240)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 17: "component "Destination 83 - g_DbdBox" (331)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 17: "component "Destination 84 - g_DbdBoxSubType" (409)" wrote 23 rows.
Information 0x4004300b: Data Flow Task 18: "component "Destination 85 - g_DbdChart" (43)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 18: "component "Destination 86 - g_DbdChartDataSeries" (115)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 18: "component "Destination 87 - g_DbdChartPoint" (186)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 18: "component "Destination 88 - g_DbdEnumerators" (259)" wrote 92 rows.
Information 0x4004300b: Data Flow Task 18: "component "Destination 89 - g_DbdFinancials" (350)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 19: "component "Destination 90 - g_DbdKeyFigure" (55)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 19: "component "Destination 91 - g_DbdKeyFigureLineType" (162)" wrote 44 rows.
Information 0x4004300b: Data Flow Task 19: "component "Destination 92 - g_DbdMonitoredAccount" (293)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 19: "component "Destination 93 - g_DbdTemplate" (385)" wrote 3 rows.
Information 0x4004300b: Data Flow Task 19: "component "Destination 94 - g_DbdTemplateBox" (461)" wrote 48 rows.
Information 0x4004300b: Data Flow Task 20: "component "Destination 95 - g_DbdTopList" (49)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 20: "component "Destination 96 - g_DeletedItems" (125)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 20: "component "Destination 97 - G_DELI" (259)" wrote 1 rows.
Information 0x4004300b: Data Flow Task 20: "component "Destination 98 - G_DISC" (404)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 20: "component "Destination 99 - G_DOC" (572)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 21: "component "Destination 100 - G_DOCEX" (46)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 21: "component "Destination 101 - G_DOCL" (129)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 21: "component "Destination 102 - G_DOCTEMPLATE" (227)" wrote 241 rows.
Information 0x4004300b: Data Flow Task 21: "component "Destination 103 - G_DOCTYPE" (338)" wrote 11 rows.
Information 0x4004300b: Data Flow Task 21: "component "Destination 104 - G_DOCTYPEL" (427)" wrote 392 rows.
Information 0x4004300b: Data Flow Task 22: "component "Destination 105 - G_EDocContactOnNetwork" (43)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 22: "component "Destination 106 - G_EDocDocument" (148)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 22: "component "Destination 107 - G_EDocEventLog" (253)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 22: "component "Destination 108 - G_EDocEventLogData" (334)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 22: "component "Destination 109 - G_EDocKeyValue" (407)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 23: "component "Destination 110 - G_EINVSETTINGS" (94)" wrote 1 rows.
Information 0x4004300b: Data Flow Task 23: "component "Destination 111 - G_EMAIL" (242)" wrote 20 rows.
Information 0x4004300b: Data Flow Task 23: "component "Destination 112 - G_EMP" (500)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 23: "component "Destination 113 - G_EMPAA" (688)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 23: "component "Destination 114 - G_EMPAAMSG" (812)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 24: "component "Destination 115 - G_EMPABS" (79)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 24: "component "Destination 116 - G_EMPABSSTATUS" (181)" wrote 3 rows.
Information 0x4004300b: Data Flow Task 24: "component "Destination 117 - G_EMPABSTYPE" (259)" wrote 50 rows.
Information 0x4004300b: Data Flow Task 24: "component "Destination 118 - G_EMPCAR" (352)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 24: "component "Destination 119 - G_EMPCODE" (449)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 25: "component "Destination 120 - G_EMPCOMPETENCE" (58)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 25: "component "Destination 121 - G_EMPEX" (467)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 25: "component "Destination 122 - G_EMPNOTES" (768)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 25: "component "Destination 123 - G_EMPRATES" (861)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 25: "component "Destination 124 - G_EMPTAXCARD" (972)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 26: "component "Destination 125 - G_EMPTREKK" (70)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 26: "component "Destination 126 - G_EMPUNION" (190)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 26: "component "Destination 127 - G_EXCHANGETASK" (299)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 26: "component "Destination 128 - G_EXTERNALSWOT" (387)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 26: "component "Destination 129 - G_File" (465)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 27: "component "Destination 130 - G_FILTER" (73)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 27: "component "Destination 131 - G_FILTERL" (198)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 27: "component "Destination 132 - G_FILTERSTATIC" (294)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 27: "component "Destination 133 - G_GOAL" (366)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 27: "component "Destination 134 - G_IMPORT" (587)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 28: "component "Destination 135 - G_IMPRABATT" (46)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 28: "component "Destination 136 - G_INTERNALSWOT" (126)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 28: "component "Destination 137 - G_INTRASTAT" (213)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 28: "component "Destination 138 - G_INTRASTATL" (345)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 28: "component "Destination 139 - G_INVCONST" (440)" wrote 323 rows.
Information 0x4004300b: Data Flow Task 29: "component "Destination 140 - G_INVCONSTL" (43)" wrote 2170 rows.
Information 0x4004300b: Data Flow Task 29: "component "Destination 141 - G_KEYFIGURECACHE" (115)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 29: "component "Destination 142 - G_LOGG" (189)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 29: "component "Destination 143 - G_MAILBOX" (264)" wrote 5 rows.
Information 0x4004300b: Data Flow Task 29: "component "Destination 144 - G_MailSubscription" (328)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 30: "component "Destination 145 - G_MAIN" (94)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 30: "component "Destination 146 - G_MAINL" (374)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 30: "component "Destination 147 - G_MAINLCUST" (579)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 30: "component "Destination 148 - G_MAINLINTEREST" (682)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 30: "component "Destination 149 - G_MAINLMATCH" (812)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 31: "component "Destination 150 - G_MAINLREPORT" (79)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 31: "component "Destination 151 - G_MAINLREPORTL" (202)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 31: "component "Destination 152 - G_MAINLVEND" (309)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 31: "component "Destination 153 - G_MOTIONVOUCHERLINK" (388)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 31: "component "Destination 154 - G_NELFODISC" (469)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 32: "component "Destination 155 - G_NELFOGROUP" (46)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 32: "component "Destination 156 - G_NELFOPROD" (183)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 32: "component "Destination 157 - G_NUMBER" (290)" wrote 117 rows.
Information 0x4004300b: Data Flow Task 32: "component "Destination 158 - G_ORDER" (860)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 32: "component "Destination 159 - G_ORDERALTTOTAL" (1273)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 33: "component "Destination 160 - G_ORDERCREATORS" (31)" wrote 3 rows.
Information 0x4004300b: Data Flow Task 33: "component "Destination 161 - G_ORDEREDOC" (98)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 33: "component "Destination 162 - G_ORDEREX" (192)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 33: "component "Destination 163 - G_ORDERL" (483)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 33: "component "Destination 164 - G_ORDERLINK" (695)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 34: "component "Destination 165 - G_ORDERNUMBER" (37)" wrote 5 rows.
Information 0x4004300b: Data Flow Task 34: "component "Destination 166 - G_ORDERSTATUS" (234)" wrote 18 rows.
Information 0x4004300b: Data Flow Task 34: "component "Destination 167 - G_PAYROLL" (499)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 34: "component "Destination 168 - G_PAYROLLL" (737)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 34: "component "Destination 169 - G_PAYROLLLTAXCODE" (884)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 35: "component "Destination 170 - G_PAYTERM" (82)" wrote 4 rows.
Information 0x4004300b: Data Flow Task 35: "component "Destination 171 - G_PAYTERML" (264)" wrote 11 rows.
Information 0x4004300b: Data Flow Task 35: "component "Destination 172 - G_PICTURE" (397)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 35: "component "Destination 173 - G_POCKETPCFIELDS" (489)" wrote 54 rows.
Information 0x4004300b: Data Flow Task 35: "component "Destination 174 - G_POST" (575)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 36: "component "Destination 175 - G_PRICE" (70)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 36: "component "Destination 176 - G_PRICEJUST" (211)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 36: "component "Destination 177 - G_PROD" (622)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 36: "component "Destination 178 - G_PRODDESC" (905)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 36: "component "Destination 179 - G_PRODGROUP" (988)" wrote 2 rows.
Information 0x4004300b: Data Flow Task 37: "component "Destination 180 - G_PRODONWEB" (64)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 37: "component "Destination 181 - G_PRODTAX" (159)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 37: "component "Destination 182 - G_PRODVEND" (317)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 37: "component "Destination 183 - G_PROJ" (606)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 37: "component "Destination 184 - G_PROJLNK" (799)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 38: "component "Destination 185 - G_PROJPLAN" (46)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 38: "component "Destination 186 - G_PROJSTATUS" (123)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 38: "component "Destination 187 - G_PURC" (358)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 38: "component "Destination 188 - G_PURCL" (740)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 38: "component "Destination 189 - G_PURCLOG" (977)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 39: "component "Destination 190 - G_PURCSALESLINK" (49)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 39: "component "Destination 191 - G_PURCSTATUS" (140)" wrote 5 rows.
Information 0x4004300b: Data Flow Task 39: "component "Destination 192 - g_Queries" (221)" wrote 1 rows.
Information 0x4004300b: Data Flow Task 39: "component "Destination 193 - G_REGION" (297)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 39: "component "Destination 194 - G_REMINDER" (375)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 40: "component "Destination 195 - G_REMIT" (85)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 40: "component "Destination 196 - G_REMLOG" (206)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 40: "component "Destination 197 - G_REPORTFAV" (300)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 40: "component "Destination 198 - G_REPORTFAVL" (388)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 40: "component "Destination 199 - G_REVENUES" (470)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 41: "component "Destination 200 - G_STDREG" (55)" wrote 67 rows.
Information 0x4004300b: Data Flow Task 41: "component "Destination 201 - G_STORE" (150)" wrote 1 rows.
Information 0x4004300b: Data Flow Task 41: "component "Destination 202 - G_STORECAT" (237)" wrote 15 rows.
Information 0x4004300b: Data Flow Task 41: "component "Destination 203 - G_STOREITEM" (350)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 41: "component "Destination 204 - G_STORELINK" (498)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 42: "component "Destination 205 - G_STORELOC" (46)" wrote 1 rows.
Information 0x4004300b: Data Flow Task 42: "component "Destination 206 - g_StoreMBalanceLog" (141)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 42: "component "Destination 207 - G_STOREMIN" (328)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 42: "component "Destination 208 - G_STOREMINFO" (544)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 42: "component "Destination 209 - G_STOREMOUT" (763)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 43: "component "Destination 210 - G_STRUC" (46)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 43: "component "Destination 211 - G_SYNCCONFLICT" (117)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 43: "component "Destination 212 - G_SYNCCONFLICTL" (195)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 43: "component "Destination 213 - g_syncConstraint" (268)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 43: "component "Destination 214 - G_SYNCLOG" (340)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 44: "component "Destination 215 - G_SYNCMAPPINGCONSTANT" (37)" wrote 287 rows.
Information 0x4004300b: Data Flow Task 44: "component "Destination 216 - G_SYNCNUMBER" (105)" wrote 6 rows.
Information 0x4004300b: Data Flow Task 44: "component "Destination 217 - G_SYNCRECORD" (200)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 44: "component "Destination 218 - G_SYNCRECORDSNAPSHOT" (277)" wrote 0 rows.
Information 0x4004300b: Data Flow Task 44: "component "Destination 219 - G_SYNCRECORDTEMPSTORAGE" (366)" wrote 0 rows.
Met Vriendelijke Groet
Mitchell
