Opstartgeluid Windows 7 wijzigen
Waarom, waarom, waarom... is het onder Windows 7 opeens niet meer mogelijk een ander opstartgeluid voor je PC te selecteren? Iemand enig idee? En heeft iemand een oplossing?
  • CodeCaster
CodeCaster
Stop AI Slop
Euh... is rechtsklikken op de speaker bij de klok, "Geluiden", "Windows", "Windows aanmelden" niet wat je zoekt?
Waar is de brand, meester?
"Windows aanmelden" is na het invullen van je wachtwoord, opstartgeluid is voordat je je wachtwoord intypt.
  • CodeCaster
CodeCaster
Stop AI Slop
Ah. Dan kijk je hier toch even? Het geluid staat in imgres.dll en die zul je moeten resourcehacken.
Hier: http://windows7forums.com...anging-startup-sound.html vond ik dit bericht:
How to Change Start up sound in Windows 7 This assumes you are using American English versuion of W-7 Language type 1033
All Windows 7 allows is for you check or un-check play start up sound in Windows 7 you have to do the following to change the default sound of your choice
1) Use the following beta program Reshacker from
Download Resource Hacker 3.5.0.82 Beta / 3.4.0.79 - Analyze, change, add, erase or extract resources in EXE and DLL files - Softpedia
2) Locate the file "imageres.dll" in C:\ Windows\System32 folder. For instance, C:\Windows\System32\imageres.dll. Copy that file into a different location, i.e. your desktop.
3) Download ResHacker .
4) Open ResHacker. Open the imageres.dll file in ResHacker.
5) Find the folder that reads "WAVE" and expand everything below that.
6) Right click 1033 (this could have a different name depending on your locale), and click Replace Resource. Click "Open file with new resource", and find the wave file you want to replace it with. Once you're done, in Resource Type, type "WAVE", in Resource Name type "5080", and under Resource Language type "1033" (or whatever number you have). Once done, click Replace.
7) Click File, then click Save. Now you can copy this file to Vista's System32 folder.
Keep the imageres_original.dll file ResHack left behind in case you want to revert back to the original sound.
8) For Windows 7 go back to C:\Windows\System32 directory rename the imageres.dll to Imageres.old then copy and paste the new hacked Imageres.dll into C:\windows\system32 directory
Dat klinkt allemaal wel leuk, maar ik mag van Ome Microsoft blijkbaar niet zomaar iets wijzigen aan mijn eigendom, want ik kan imageres.dll niet van naam veranderen en mag hem ook niet vervangen. Dan volgt de melding dat ik door TrustedInstaller gemachtigd moet worden...
