Wat is de oorzaak van deze brand fout?
  • 397 views
  • Emiel1|IA
  • Laatst online: 02-11-2022
Heeft iemand een idee waarom hij "Failed" met branden?
Hier het log van nero
Emiel
1C80-0000-19E5-MA2X-4006-3632-****
Windows XP 6.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
Recorder: <Optiarc DVD RW AD-7200A> Version: 1.06 - HA 1 TA 0 - 7.10.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <Optiarc DVD RW AD-7200A >Version: 1.06 - HA 1 TA 0 - 7.10.1.0
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
Optiarc DVD RW AD-7200A E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use : 35 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.9.2010
Burn DVD Image
16:59:19 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
16:59:19 #2 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
16:59:20 #3 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 2617193 (581:35.68, 5111MB)
16:59:20 #4 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
16:59:20 #5 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: Optiarc DVD RW AD-7200A, Media type: DVD+R9 Double Layer
Disc Manufacturer ID: RITEK, Media Type ID: S04, Product revision number: 66
Disc Application Code: 0, Extended Information Indicators: 3
16:59:20 #6 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
16:59:20 #7 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet)
2 indices, index0 (150) not provided
original disc pos #0 + 2617194 (2617194) = #2617194/581:35.69
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2617194 blocks [E: Optiarc DVD RW AD-7200A]
16:59:20 #8 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: Optiarc DVD RW AD-7200A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 5360013312, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2617194 | 2617194 | 0x00
2617194 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
16:59:20 #9 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
16:59:20 #10 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
16:59:20 #11 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
16:59:20 #12 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
16:59:20 #13 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
16:59:20 #14 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 6x (8.310 KB/s)
16:59:20 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
16:59:20 #16 Text 0 File DVDPlusDualLayer.cpp, Line 494
Disc finalized, LBA total Image size: 2617194 (5111MB), Last LBA L0: 1308607 (2555MB)
16:59:29 #17 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 00 00 00 00 00 00 21 08 04 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 00 00 C0 00 07
Buffer x06eef540: Len x804
16:59:29 #18 Text 0 File DVDPlusDualLayer.cpp, Line 659
L0 Data Zone Capacity set to 1308608 (13F7C0h, 2555MB) -> OK, confirmed setting
16:59:29 #19 CDR -1205 File DVDPlusDualLayer.cpp, Line 686
Burning Layer 1
16:59:29 #20 Text 0 File DVDPlusDualLayer.cpp, Line 696
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
16:59:29 #21 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-ROM (0), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 22D7FF h (LBN: 1FD7FF h, 4075 MB)
Data in Burst Cutting Area (BCA) does not exist
Media Specific [16..63]:
00 00 03 52 49 54 45 4B - 00 00 00 53 30 34 42 40 ...RITEK...S04B@
25 25 37 10 00 2C 6C 00 - 2C 6C 20 1F 0C 0C 14 14 %%7..,l.,l......
02 01 01 20 00 20 1F 0C - 0C 14 14 02 01 01 20 00 ................
16:59:29 #22 Text 0 File DVDR.cpp, Line 6783
Drive: Optiarc DVD RW AD-7200A
Book Type request [NEC]: DVD-ROM, write to RAM
select Book Type setting from RAM
Changing the Book Type was finished successfully, return code 0
16:59:29 #23 CDR -1207 File DVDR.cpp, Line 6477
Book Type automatically set to: DVD-ROM
16:59:29 #24 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
16:59:29 #25 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
17:05:17 #26 SPTI -1093 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1093)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x2A 00 00 0E EF E0 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 02
Buffer x0f5a2b80: Len x10000
0xD0 FC 17 15 A4 5A 00 41 EC 5A 0F A7 D2 A2 5F B1
0xD9 85 ED 56 2F 71 9F 09 FA EF 6C 5D 69 9E 7B 17
0x26 AB 2C A5 7B 37 49 CF CD 7F 0B E2 A0 24 84 75
17:05:17 #27 CDR -1093 File Writer.cpp, Line 303
No seek complete
17:05:17 #28 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
17:05:17 #29 SPTI -1176 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176)
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 72 03
17:05:17 #30 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 978912
17:05:18 #31 Text 0 File DVDR.cpp, Line 6783
17:05:18 #32 CDR -1176 File WriterStatus.cpp, Line 162
Session fixation error
17:05:18 #33 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
17:05:19 #34 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 6x (8.310 KB/s)
17:05:21 #35 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
17:05:25 #36 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
17:05:25 #37 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Ik heb hem geprobeerd te branden op een "platinum double layer/DVD+R 8.5 GB"
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
Je krijgt een Session fixation error, heb je al eens wat gedaan met de vele oplossingen die daarvoor zijn te vinden?
  • Emiel1|IA
Nee, heb wel met img burn proberen te branden alleen daar kreeg ik ook fouten.
Is het niet de kopieer beveiliging? Lijkt me niet dat het de bedoeling is dat je Windows kopieert.
  • Emiel1|IA
Windows kopieeren?? Hoe kom je daar bij?
  • TERW_DAN
TERW_DAN
Misschien handig om er eens naar te kijken dan.
En wat waren die fouten dan?
  • RaZ
RaZ
Funky Cold Medina
Ik heb een Samsung USB externe slimline fikker, en met diverse programma's krijg ik ook erros (op 5 pc's), waaronder ook met Nero.
Download eens deepburner (freeware), dat is de enige die waarbij ik kan branden (de rest failed allemaal). Voordeel van deepburner is dat je niets hoeft te installeren, dus wegmikken kan zonder dat er meuk overblijft.
Ey!! Macarena \o/
  • Emiel1|IA
  • dion_b
  • Laatst online: 21:09
dion_b
say Baah
1) Overige Hardware is voor (hardware)vragen die nergens anders op GoT thuishoren. CDs zijn overduidelijk Opslagmedia, dus hoort een vraag erover ook daar.
2) een enorme uitdraai van een of ander tool (ook al is het je brandprogramma) is geen topicstart :o
Op GoT verwachten we dat je zelf doet wat je kunt voor je een topic opent. Dat betekent dat je minimaal aangeeft waar je al gezocht hebt, op welke zoektermen, wat je vond (links!), wat je aan de hand daarvan geprobeerd hebt en wat toen gebeurde.
Daar is hier geen sprake van, je dumpt gewoon een uitdraai en vraagt of wij het oplossen. Zo werkt dat hier niet. Move naar OM en dicht.
Oslik, blyat! Oslik!
