• lbuysers
  • Laatst online: 01-09 21:01
De update naar Android 2.2 (froyo) voor de HTC Desire zal dit weekend beginnen. Dat weten Engadget en Gizmodo te melden. Ze hebben officieel bericht gehad van HTC.
"The Android 2.2 (FroYo) update for HTC Desire will start rolling out across Europe this weekend. As well as including the complete set of Android 2.2 features, the update will contain a few special additions of our own through the latest iteration of HTC Sense. The update will provide 720p video capture, HTC's App Share widget, as well as our enhanced HTC Caller ID, and improved multi-language keyboard. Also, through the update, HTC Sync will allow HTC Desire users to sync their music with iTunes.
HTC Desire users will be notified that the over-the-air update is available to download when their phone automatically checks for software updates. The update won't delete any of the phone's content. However, due to the size of the update, we would advise using a WiFi connection to download it wherever possible to avoid additional data charges.
This update will initially roll out to unlocked HTC Desire handsets. Operator specific versions of the update are undergoing testing and we expect to make them available in several weeks' time."
http://gizmodo.com/560039...0p-recording-this-weekend
http://www.engadget.com/2...nd-720p-video-capture-to/
  • SmiGueL
  • Laatst online: 09:35
Dit toevallig gelezen? ;) (laatste regel)
Maargoed hij mocht van mij wel open blijven hoor :)
Ben wel benieuwd hoe ze de nieuwe update gaan uitbrengen.
Zou iedereen 1x manueel kan updaten? of gaat dat ook per serienummer oid?
(Via de schedule doen we het waarschijnlijk sowieso verspreidt over enkele dagen/weken)
[ Voor 65% gewijzigd door SmiGueL op 30-07-2010 13:41 ]
Delidded 4770K 4.7GHz @ H220 || Gigabyte Z87X-UD4H || 16GB @ 2400MHz || Gigabyte GTX 760 || 2x128GB Samsung 830 @ RAID-0 & WD 3 TB || Iiyama XB2483HSU-B1 || Synology DS916+ 3x6TB + 120GB SSD Cache || Synology DS213+ 6TB backup
Ik vindt dat niet echt websites waar je op moet vertrouwen. Tot op heden heeft HTC via Twitter laten weten dat ze gisteren zijn begonnen met het uitrollen van froyo naar de desire toestellen.
Gewoon afwachten dus :)
  • siemo
  • Laatst online: 28-10 18:27
Dit zal toch wel snel gaan. Denken jullie dat HTC Froyo op de website zal plaatsen? Zal deze zonder problemen op een Vodafone branded Desire te zetten zijn?
  • naaitsab
  • Laatst online: 07:01
@TS dit gelezen?
RoD schreef op donderdag 29 juli 2010 @ 21:47:
De bron is gechecked. Scheen afkomstig te zijn van een of andere HTC Benelux-directeur. Leek wel betrouwbaar ;) HTC doet een mededeling, Tweakers bericht daar vervolgens over. Dat HTC vervolgens foute informatie geeft kan Tweakers.net niets aan doen. Ik snap dat je gefrustreerd bent, maar dit is onzin :)
En ik ga hier maar een slotje op gooien. Het niveau daalt per reply. Als de update er is mag er een nieuw topic geopend worden.
Volgens mij nog geen update maar dat kan aan mij liggen ;)
if (!coffee) {
Work = false; }
siemo schreef op vrijdag 30 juli 2010 @ 13:37:
Lees:
De branded toestellen komen wat later :)
  • RoD
RoD
Admin Mobile & FP PowerMod
Geen update = geen topic.
