/etc/wine.conf anyone?
  • Servowire
  • Laatst online: 08-09 17:42
Servowire
prutser:~#
Kan iemand een voorbeeld /etc/wine.ini geven?
( of /usr/local/etc/wine.ini
Op de wine site zijn die links dood.
Eventueel ICQ
met papier mache kun je alles maken!!
  • thunderbird2k
  • Laatst online: 11-03 05:55
Hier mijn configfile. Ik dacht dat er een script bij wine zat of een configfile (heette wine.ini), ik kan het zo snel niet vinden.
Vandaar hier mijn configfile
WINE REGISTRY Version 2
;; All keys relative to \\Machine\\Software\\Wine\\Wine\\Config
;; MS-DOS drives configuration
;; Each section has the following format:
;; [Drive X]
;; Path=xxx (Unix path for drive root)
;; Type=xxx (supported types are 'floppy', 'hd', 'cdrom' and 'network')
;; Label=xxx (drive label, at most 11 characters)
;; Serial=xxx (serial number, 8 characters hexadecimal number)
;; Filesystem=xxx (supported types are 'msdos'/'dos'/'fat', 'win95'/'vfat', 'unix')
;; This is the FS Wine is supposed to emulate on a certain
;; directory structure.
;; Recommended:
;; - "win95" for ext2fs, VFAT and FAT32
;; - "msdos" for FAT16 (ugly, upgrading to VFAT driver strongly recommended)
;; DON'T use "unix" unless you intend to port programs using Winelib !
;; Device=/dev/xx (only if you want to allow raw device access)
[Drive A]
"Path" = "/floppy"
"Type" = "floppy"
"Label" = "Floppy"
"Serial" = "87654321"
"Device" = "/dev/fd0"
[Drive C]
"Path" = "/wine"
"Type" = "hd"
"Label" = "MS-DOS"
"Filesystem" = "win95"
[Drive D]
"Path" = "/cdrom"
"Type" = "cdrom"
"Label" = "CD-Rom"
; make sure that device is correct and has proper permissions !
"Device" = "/dev/cdrom"
[Drive E]
"Path" = "/tmp"
"Type" = "hd"
"Label" = "Tmp Drive"
[Drive F]
"Path" = "${HOME}"
"Type" = "network"
"Label" = "Home"
[wine]
"Windows" = "c:\\windows"
"System" = "c:\\windows\\system"
"Temp" = "e:\\"
"Path" = "c:\\windows;c:\\windows\\system;e:\\;e:\\test;f:\\"
"Profile" = "c:\\windows\\Profiles\\Administrator"
"GraphicsDriver" = "x11drv"
; Wine doesn't pass directory symlinks to Windows programs by default.
; Enabling this may crash some programs that do recursive lookups of a whole
; subdir tree in case of a symlink pointing back to itself.
;ShowDirSymlinks=1
"ShellLinker" = "wineshelllink"
# <wineconf>
[DllDefaults]
"EXTRA_LD_LIBRARY_PATH" = "${HOME}/wine/cvs/lib"
"DefaultLoadOrder" = "native, builtin, so"
[DllOverrides]
"commdlg" = "builtin"
"comdlg32" = "builtin"
"ver" = "builtin, native"
"version" = "builtin, native"
"shell" = "builtin"
"shell32" = "builtin"
"lzexpand" = "builtin, native"
"lz32" = "builtin, native"
"comctl32" = "builtin"
"commctrl" = "builtin"
"wsock32" = "builtin"
"winsock" = "builtin"
"advapi32" = "builtin, native"
"crtdll" = "builtin, native"
"mpr" = "builtin, native"
"winspool.drv" = "builtin, native"
"ddraw" = "builtin, native"
"dinput" = "builtin, native"
"dsound" = "builtin, native"
"mmsystem" = "builtin"
"winmm" = "builtin"
"msvideo" = "builtin, native"
"msvfw32" = "builtin, native"
"mcicda.drv" = "builtin, native"
"mciseq.drv" = "builtin, native"
"mciwave.drv" = "builtin, native"
"mciavi.drv" = "native, builtin"
"mcianim.drv" = "native, builtin"
"msacm.drv" = "builtin, native"
"midimap.drv" = "builtin, native"
"wnaspi32" = "builtin"
"icmp" = "builtin"
"imm" = "builtin, native"
"imm32" = "builtin, native"
"msvcrt" = "native, builtin"
[x11drv]
; Number of colors to allocate from the system palette
"AllocSystemColors" = "100"
; Use a private color map
"PrivateColorMap" = "N"
; Favor correctness over speed in some graphics operations
"PerfectGraphics" = "N"
; Color depth to use on multi-depth screens
;;ScreenDepth = 16
; Name of X11 display to use
;;Display = :0.0
; Allow the window manager to manage created windows
"Managed" = "N"
; Use a desktop window of 640x480 for Wine
;Desktop = 640x480
; Use XFree86 DGA extension if present
"UseDGA" = "N"
; Use XShm extension if present
"UseXShm" = "Y"
; Enable DirectX mouse grab
"DXGrab" = "Y"
; Create the desktop window with a double-buffered visual
; (useful to play OpenGL games)
"DesktopDoubleBuffered" = "Y"
; Code page used for captions in managed mode
; 0 means default ANSI code page (CP_ACP == 0)
"TextCP" = "0"
; Use this if you have more than one port for video on your setup
; (Wine uses for now the first 'input image' it finds).
;; XVideoPort = 43
[fonts]
;Read documentation/fonts before adding aliases
"Resolution" = "96"
"Default" = "-adobe-times-"
[serialports]
"Com1" = "/dev/ttyS0"
"Com2" = "/dev/ttyS1"
"Com3" = "/dev/modem,38400"
"Com4" = "/dev/modem"
[parallelports]
"Lpt1" = "/dev/lp0"
[spooler]
"LPT1:" = "|lpr"
"LPT2:" = "|gs -sDEVICE=bj200 -sOutputFile=/tmp/fred -q -"
"LPT3:" = "/dev/lp3"
[ports]
;read=0x779,0x379,0x280-0x2a0
;write=0x779,0x379,0x280-0x2a0
[spy]
"Exclude" = "WM_SIZE;WM_TIMER;"
[registry]
; Paths must be given in /dir/dir/file.reg format.
; Wine will not understand dos file names here...
;These are all booleans. Y/y/T/t/1 are true, N/n/F/f/0 are false.
;Defaults are read all, write to Home
; Global registries (stored in /etc)
"LoadGlobalRegistryFiles" = "Y"
; Home registries (stored in ~user/.wine/)
"LoadHomeRegistryFiles" = "Y"
; Load Windows registries from the Windows directory
"LoadWindowsRegistryFiles" = "Y"
; TRY to write all changes to home registries
"WritetoHomeRegistryFiles" = "Y"
; Registry periodic save timeout in seconds
; PeriodicSave=600
; Save only modified keys
"SaveOnlyUpdatedKeys" = "Y"
[Tweak.Layout]
;; WineLook=xxx (supported styles are 'Win31'(default), 'Win95', 'Win98')
"WineLook" = "Win95"
[Console]
;Drivers=tty
;XtermProg=nxterm
;InitialRows=25
;InitialColumns=80
;TerminalType=nxterm
[Clipboard]
"ClearAllSelections" = "0"
"PersistentSelection" = "1"
# </wineconf>
  • KyD
  • Laatst online: 06-09-2022
KyD
Okee het is een beetje lang, want ik heb alle puntkomma's laten staan, misschien kun je er wat van leren? :?
iig, hiermee kan ik de meeste applicaties van windoze wel draaien
;; [Drive X]
;; Recommended:
[Drive A]
Path=/mnt/fd0
Type=floppy
Label=Floppy
Serial=87654321
Device=/dev/fd0
[Drive C]
Path=/mnt/win_c
Type=hd
Label=Neon
Filesystem=win95
[Drive D]
Path=/mnt/win_c2
Type=hd
Label=Genesis
Filesystem=win95
[Drive E]
Path=/mnt/win_d
Type=hd
Label=Evangelion
Filesystem=win95
[Drive F]
Path=/mnt/cdrom
Type=cdrom
Label=CD-Rom
Filesystem=win95
Device=/dev/cdrom
[Drive G]
Path=/tmp
Type=hd
Label=Tmp Drive
Filesystem=win95
[Drive G]
Path=${HOME}
Type=network
Label=Home
Filesystem=win95
[wine]
Windows=c:\windows
System=c:\windows\system
Temp=G:\
Path=c:\windows;c:\windows\system
Profile=c:\windows\Profiles\Ando
GraphicsDriver=x11drv
# <wineconf>
[DllDefaults]
EXTRA_LD_LIBRARY_PATH=/usr/lib/wine
DefaultLoadOrder = native, builtin, elfdll, so
[DllOverrides]
kernel32, gdi32, user32 = builtin
krnl386, gdi, user = builtin
toolhelp = builtin
comdlg32, commdlg = elfdll, builtin, native
version, ver = elfdll, builtin, native
shell32, shell = builtin, native
lz32, lzexpand = builtin, native
commctrl, comctl32 = builtin, native
wsock32, winsock = builtin
advapi32, crtdll, ntdll = builtin, native
mpr, winspool.drv = builtin, native
ddraw, dinput, dsound = builtin, native
winmm, mmsystem = builtin
msvideo, msvfw32 = builtin, native
mcicda.drv, mciseq.drv = builtin, native
mciwave.drv = builtin, native
mciavi.drv, mcianim.drv = native, builtin
msacm.drv, midimap.drv = builtin, native
w32skrnl = builtin
wnaspi32, wow32 = builtin
system, display, wprocs = builtin
wineps = builtin
icmp = builtin
[x11drv]
AllocSystemColors = 100
PrivateColorMap = N
PerfectGraphics = N
;;ScreenDepth = 16
;;Display = :0.0
Managed = N
UseDGA = Y
UseXShm = Y
DXGrab = N
DesktopDoubleBuffered = N
TextCP=0
; (Wine uses for now the first 'input image' it founds).
;; XVideoPort = 43
[fonts]
Resolution = 96
Default = -adobe-times-
[serialports]
Com1=/dev/ttyS0
Com2=/dev/ttyS1
Com3=/dev/modem,38400
Com4=/dev/modem
[parallelports]
Lpt1=/dev/lp0
[spooler]
LPT1:=|lpr
LPT2:=|gs -sDEVICE=bj200 -sOutputFile=/tmp/fred -q -
LPT3:=/dev/lp3
[ports]
[spy]
Exclude=WM_SIZE;WM_TIMER;
[registry]
LoadGlobalRegistryFiles=Y
LoadHomeRegistryFiles=Y
LoadWindowsRegistryFiles=Y
WritetoHomeRegistryFiles=Y
; Use new file format
UseNewFormat=Y
; PeriodicSave=600
SaveOnlyUpdatedKeys=Y
[Tweak.Layout]
WineLook=Win95
[programs]
Default=
Startup=
[Console]
;Drivers=tty
;XtermProg=nxterm
;InitialRows=25
;InitialColumns=80
[Clipboard]
ClearAllSelections=0
PersistentSelection=1
# </wineconf>
