CPu temp hoger na Bios upgrade
  • acidfever
  • Laatst online: 06-01-2024
acidfever
I am allready working!
Kan het dat mijn cpu temp 5 graden is gestegen na het updaten van mijn A7V133 Bios naar versie 1004.
iemand suggesties?
A.
Ja dat kan, na bios fixes voor onjuist aangeven temp bijvoorbeeld...
Hi there,
Can you please post some details?
board revision
CPU cooler
Temp before BIOS update
Temp after update
Which program you use to monitor temp
Let us know.
Good luck
  • acidfever
acidfever
board revision = 1.04
CPU cooler
Temp after update
  • acidfever
acidfever
woops....vorige post ging een beetje fout!
CPU cooler =thermaltake superorb
previous bios = 1003a
curretn bios = 1004
Temp b4 BIOS update = 45 degrees celcius idle
Temp after update = 50 degrees celcius idle
Which program you use to monitor temp= MBM 5
and bios temp monitor (both say 50 degrees)
A.
This is what I have:
A7V133 REV 1.05 (Raid 0, Raid 1)
Standard Spire CPU cooler
CPU TEMP before 1004 BIOS update = 49°C idle
CPU TEMP after 1004 BIOS update = 49°C idle
Program used: Hardware Sensors Monitor PRO 3.2.3.1 (also known as HMONITOR)
Note that I am basically NOT using any thermal compund since the one on the heatsink has completely dried out.
My suggestion is check the BIOS temperature inside the BIOS (usually the most accurate). Then flash back to 1003 and check the temp in the BIOS again. If there are no changes then you know it depends on your MB monitor program. DO NOT use ASUS Probe since that is the most inaccurate thermal utility I have ever seen.
Let me know how it goes.
Sorry forgot to add my CPU
TB 900MHz
One more important thing,
after having flashed the BIOS voltage settings go back on AUTO. Make sure you have that set to user define at 1.75V. The AUTO setting always sets it higher for some reasons.
ik weet nog van mn asus p5 a-b dat ik de bios upgrade en dat ie 20 graden lager was!
:P Heb je niet toevallig voordat je de 2e keer keek ff lekkah aan ju PIEL gezeten voor de PC zodat je PC het er ook warm van kreeg
  • acidfever
acidfever
Hey Knoop, wil je graag dat ik je persoonlijke informatie bekend maak zodat we je allemaal effe kunnen komen slopen in Den Haag.....hehe
  • acidfever
acidfever
Het vage is dat na de bios flash volgens MBM en de BIOS m'n case temp ook hoger is gebworden (3 graden)
A.
