Linksys WRVS4400N als repeater of range-extender
  • Spacecowboy
  • Laatst online: 12-10 15:14
Spacecowboy
XBL: Biggmans
Heb bedraad en draadloos netwerk, router is Apple Airport Extreme. Wil TV via Ethernet aansluiten, echter bedraad haal ik dat niet (moeilijk). Heb nog Linksys router. Is deze in te zetten als repeater? Wat ik zou willen is dat de Linksys het draadloze router signaal oppikt en ik de switchpoorten gebruik om mijn TV aan te sluiten. Weet iemand waar een handleiding om dit voor elkaar te krijgen is te vinden?
HENG HENG
  • chim0
  • Laatst online: 13:59
Google is je vriend! :+
http://cisco.biz/en/US/pr...tem09186a0080a39097.shtml
Q. What is Wireless Distribution System (WDS), and what is it used for?
A. The WDS feature only works with the first SSID that is setup in the WRVS4400N. Make sure that the channel and security settings are the same for all WDS enabled devices. WDS allows a wireless signal to be repeated by a repeater. This mode allows a wireless client to connect to the Router through a repeater, such as WAP4400N, WAP54GP, WAP54GPE, when it operates in Repeater Mode. This mode allows you to extend the coverage of the Router with up to three repeaters. Select Auto in order to enable the remote access point when in Repeater Mode or select Manual and enter the MAC address of the repeater.
Q. Does WDS work with any other SSID except SSID1?
A. No, it only works with wireless SSID1.
Q. How many repeaters allow repeating the wireless signal of the Router?
A. A maximum of three repeaters are allowed to repeat the wireless signal from the WRVS4400N.
