Draytek 2130 VPN connectie werkt niet met log
Goedendag allen,
Ik heb mijn altijd goedwerkende D-Link router vervangen door een iets professionelere Draytek 2130N!
Alles werkt prima, behalve de VPN PPTP connectie.
Al 2x de router gerestored, maar helaas.
De iPhone en de laptop geven aan dat de verbinding is mislukt.
Dit zijn de system logs van de router:
Vanaf mijn iphone (GPRS)
Time Level Type Message
Jul 15 21:37:49 info daemon pptpd[32512]: CTRL: Client 188.91.86.7 control connection finished
Jul 15 21:37:49 info daemon pppd[32532]: Exit.
Jul 15 21:37:49 info daemon pppd[32532]: Sent 36 bytes, received 10 bytes.
Jul 15 21:37:49 info daemon pppd[32532]: Connect time 0.1 minutes.
Jul 15 21:37:49 notice daemon pppd[32532]: Connection terminated.
Jul 15 21:37:49 notice daemon pppd[32532]: Modem hangup
Jul 15 21:37:49 debug daemon pptpd[32512]: CTRL: Reaping child PPP[32532]
Jul 15 21:37:49 err daemon pptpd[32512]: CTRL: CTRL read failed
Jul 15 21:37:49 err daemon pptpd[32512]: CTRL: couldn't read packet header (exit)
Jul 15 21:37:49 err daemon pptpd[32512]: CTRL: EOF or bad error reading ctrl packet length.
Jul 15 21:37:48 info daemon pppd[32532]: LCP terminated by peer (MPPE required but peer negotiation failed)
Jul 15 21:37:43 notice daemon pppd[32532]: Connect: ppp10 <--> /dev/pts/0
Jul 15 21:37:43 info daemon pppd[32532]: Using interface ppp10
Jul 15 21:37:43 warn user kernel: register netdev : ppp10^M
Jul 15 21:37:43 notice daemon pppd[32532]: pppd 2.4.4 started by root, uid 0
Jul 15 21:37:43 info daemon pppd[32532]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Jul 15 21:37:42 debug daemon pptpd[32532]: [Get PPP_Num] : Assign ppp_num 10 for in-coming call
Jul 15 21:37:42 debug daemon pptpd[32532]: [Get PPP_Num] : used ...
Jul 15 21:37:42 info daemon pptpd[32512]: CTRL: Starting call (launching pppd, opening GRE)
Jul 15 21:37:42 info daemon pptpd[32512]: CTRL: Client 188.91.86.7 control connection started
Vanaf mijn Windows 7 laptop (draadloos van de buren)
Jul 15 21:39:29 info daemon pptpd[2193]: CTRL: Client 84.106.163.24 control connection finished
Jul 15 21:39:29 info daemon pppd[2194]: Exit.
Jul 15 21:39:29 notice daemon pppd[2194]: Connection terminated.
Jul 15 21:39:29 notice daemon pppd[2194]: Modem hangup
Jul 15 21:39:29 debug daemon pptpd[2193]: CTRL: Reaping child PPP[2194]
Jul 15 21:39:29 err daemon pptpd[2193]: CTRL: GRE read or PTY write failed (gre,pty)=(10,9)
Jul 15 21:39:29 err daemon pptpd[2193]: GRE: read(fd=10,buffer=18598,len=8260) from network failed: status = -1 error = Protocol not available
Jul 15 21:39:29 notice daemon pppd[2194]: Connect: ppp10 <--> /dev/pts/0
Jul 15 21:39:29 info daemon pppd[2194]: Using interface ppp10
Jul 15 21:39:29 warn user kernel: register netdev : ppp10^M
Jul 15 21:39:29 notice daemon pppd[2194]: pppd 2.4.4 started by root, uid 0
Jul 15 21:39:29 info daemon pppd[2194]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Jul 15 21:39:29 debug daemon pptpd[2194]: [Get PPP_Num] : Assign ppp_num 10 for in-coming call
Jul 15 21:39:29 debug daemon pptpd[2194]: [Get PPP_Num] : used ...
Jul 15 21:39:29 info daemon pptpd[2193]: CTRL: Starting call (launching pppd, opening GRE)
Jul 15 21:39:29 info daemon pptpd[2193]: CTRL: Client 84.106.163.24 control connection started
Wie kan mij helpen...
L2TP/IPSEC werkt ook niet.
Die geeft met Windows 7 notebook
Jul 15 21:49:52 warn authpriv pluto[11365]: "l2tp_psk"[4] 84.106.163.24 #2: sending encrypted notification INVALID_MESSAGE_ID to 84.106.163.24:4500
Jul 15 21:49:52 warn authpriv pluto[11365]: "l2tp_psk"[4] 84.106.163.24 #2: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x01000000 (perhaps this is a duplicated packet)
  • Gizz
  • Laatst online: 19:48
Gizz
Dunder-Mifflin, Inc.
Ik wil je niet ontmoedigen, maar mij is het op een Draytek 2820 nooit gelukt: Draytek 2820 VPN + Vista/7
Mijn instellingen staan wel deels daar, misschien kun je er wat mee (voor zover de 2820 en 2130 daarin hetzelfde zijn). Zoals je ziet ben ik destijds overspoelt met reacties van anderen :P Blijkbaar gebruikt niemand deze functies of zijn ze er ook nooit uitgekomen.
Ik heb niet zo veel instellingen, maar komt op het zelfde neer.
Ik heb volgens mij alle mogelijke instellingen geprobeerd, maar inderdaad helaas.
Maar misschien iemand die de logs kan uitlezen.
Ik heb hier overigens ZIGGO 120Mbit
Ik heb net even een virtuele XP machine geprobeerd, en dat werkt gewoon... Wel op L2TP!
Overigens weer met een bak warnings... maar hij doet het wel...
Nu nog mijn iPhone en W7
