NFS mount Ubuntu 10.04 --> Slackware 13
  • MacLinux
  • Laatst online: 27-03-2024
Dit is een vervolg van NFS mount MAC --> Linux Geplaatst op woensdag 20 januari 2010 13:49.
Ik heb mij laptop nieuw geïnstalleerd met Ubuntu 10.04 voor mijn dochter en nu kan ik onmogelijk een NFS mount krijgen met de server.
Even de bestanden:
/etc/exports# See exports(5) for a description.
# This file contains a list of all directories exported to other computers.
# It is used by rpc.nfsd and rpc.mountd.
/home/jeannette 192.168.0.0/255.255.0.0(rw,no_subtree_check)
/home/marcel 192.168.0.0/255.255.0.0(rw,insecure,no_subtree_check)
/home/eline 192.168.0.0/255.255.0.0(rw,insecure,no_subtree_check)
/media/muziek/mp3 192.168.0.0/255.255.0.0(rw,no_subtree_check)
/home/partimag 192.168.0.0/255.255.0.0(rw,no_subtree_check)
/home/arnout 192.168.0.0/255.255.0.0(rw,insecure,no_subtree_check)
/etc/hosts.allow
# hosts.allow This file describes the names of the hosts which are
# allowed to use the local INET services, as decided by
# the '/usr/sbin/tcpd' server.
# Version: @(#)/etc/hosts.allow 1.00 05/28/93
# Author: Fred N. van Kempen, <waltje@uwalt.nl.mugnet.org
portmap: 192.168.0.0/255.255.0.0
lockd:ALL
mountd:ALL
rquotad:ALL
statd:ALL
# End of hosts.allow.
/etc/hosts.deny
# hosts.deny This file describes the names of the hosts which are
# *not* allowed to use the local INET services, as decided
# by the '/usr/sbin/tcpd' server.
# Version: @(#)/etc/hosts.deny 1.00 05/28/93
# End of hosts.deny.
ls -l /home
root@vlinder:/var/log# ls -l /home
total 24
drwxrwxr-x 8 arnout users 4096 2010-01-20 14:25 arnout/
drwxrwxr-x 3 eline users 4096 2010-01-20 14:05 eline/
drwxr-xr-x 2 root root 4096 2009-06-06 22:37 ftp/
drwxrwxr-x 31 jeannette users 4096 2010-01-16 23:24 jeannette/
drwxrwxr-x 49 marcel users 4096 2009-12-29 15:20 marcel/
drwxrwxrwx 5 root root 4096 2009-11-30 10:52 partimag/
total 24
# /etc/fstab: static file system information.
# Use 'blkid -o value -s UUID' to print the universally unique identifier
# for a device; this may be used with UUID= as a more robust way to name
# devices that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc nodev,noexec,nosuid 0 0
# / was on /dev/sda5 during installation
UUID=b5722c4d-a335-418f-a2a2-34b890130db8 / ext4 errors=remount-ro 0 1
# swap was on /dev/sda6 during installation
UUID=f7465c68-efad-4f6e-8d3c-b4877814f81b none swap sw 0 0
vlinder:/home/eline /home/eline/vlinder nfs rw,rsize=4096,wsize=4096,hard,intr,async,nodev,nosuid 0 0
Op de server:
id eline:
uid=1003(eline) gid=100(users) groups=100(users)
Op de laptop:
id eline:
uid=1003(eline) gid=100(users) groepen=100(users),4(adm),20(dialout),24(cdrom),29(audio),44(video),46(plugdev),104(fuse),105(lpadmin),112(netdev),119(admin),122(sambashare)
Als de laptop opstart begint hij al te mekkeren dat de mount niet gevonden wordt. Handmatig zegt hij dat vlinder niet gevonden kan worden. Maar vlinder staat in /etc/hosts en kan gewoon gepingd worden.
[ Voor 4% gewijzigd door MacLinux op 08-07-2010 11:21 ]
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
Copy/paste eens de foutmelding die je krijgt als je op de laptop het commando 'mount -a -t nfs' uitvoert?
En na het uitvoeren even in de syslog kijken van de server (vlinder) of daar een foutmelding in staat.
  • MacLinux
eline@Ubuntu-Laptop:~$ sudo mount -a -t nfs
mount: onjuiste bestandssysteemsoort, ongeldige optie, ontbrekende codepagina,
ontbrekend hulpprogramma, slecht superblok op vlinder:/home/marcel, of een andere fout
(voor sommige bestandssystemen (bijvoorbeeld nfs of cifs) kan
een /sbin/mount.<type> hulpprogramma nodig zijn)
Soms staat er nuttige informatie in het systeemlog --
probeer zoiets als: dmesg | tail
root@vlinder:~# tail /var/log/syslog
Jul 6 19:38:09 vlinder smbd[19808]: [2010/07/06 19:38:09, 0] smbd/password.c:authorise_login(868)
Jul 6 19:38:09 vlinder smbd[19808]: authorise_login: rejected invalid user nobody
Jul 6 19:38:32 vlinder smbd[19811]: [2010/07/06 19:38:32, 0] smbd/password.c:authorise_login(868)
Jul 6 19:38:32 vlinder smbd[19811]: authorise_login: rejected invalid user nobody
Jul 6 19:38:47 vlinder smbd[19813]: [2010/07/06 19:38:47, 0] smbd/password.c:authorise_login(868)
Jul 6 19:38:47 vlinder smbd[19813]: authorise_login: rejected invalid user nobody
Jul 6 19:38:47 vlinder smbd[19814]: [2010/07/06 19:38:47, 0] smbd/password.c:authorise_login(868)
Jul 6 19:38:47 vlinder smbd[19814]: authorise_login: rejected invalid user nobody
Jul 6 19:38:48 vlinder smbd[19815]: [2010/07/06 19:38:48, 0] smbd/password.c:authorise_login(868)
Jul 6 19:38:48 vlinder smbd[19815]: authorise_login: rejected invalid user nobody
root@vlinder:~#
[ Voor 52% gewijzigd door MacLinux op 08-07-2010 19:00 ]
  • GraveR
  • Laatst online: 22-08-2025
Is op Ubuntu nfs-common geinstalleerd?
Anders zou het een probleem met de mount options kunnen zijn, hieronder een known-good NFS-regel uit mijn fstab van Ubuntu 10.04
192.168.86.1:/torrent      /media/Torrent     nfs     async,rw,noatime,nodiratime   0       0
  • MacLinux
Ik was dus idd nfs-common vergeten te installeren. Daarna werkte alles naar behoren. Mijn dank is wederom weer groot!!! _/-\o_
