Asus P6X58D Premium - i7 930 @ 4.01Ghz Stabiel
  • Lipadoza
  • Laatst online: 24-10-2023
Hallo mensen,
P6X58D Premium mobo van asus met een mooie i7 930 stabiel op 4.01Ghz HT on
(Credits en Thanks to Xmisery http://www.overclock.net/...thread-5.html#post8397751)
Bij deze link Stabiele OC's voor 4ghz @ i7 920 en 930 op het P6X58D Premium en E mobo
settings:
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[191]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1531MHz]
UCLK Frequency.........................[3063MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.26250]
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.21875]
IOH Voltage............................[1.14]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
10h Prime 95 - Stabiel
30x "Very High" Intel Burn Tests - Stabiel
Temps
Idle 39-42C
Stress 60-70C Average of 65C
Voor de gene met het zelfde mobo en processor zouden theoretisch de settings kunnen overnemen en stabiel kunnen runnen mocht je BSOD's hebben kan je Vcore iets omhoog krikken
Graag zou ik nog wel mijn Ram lichtjes willen overclocken Iemand nog tips?
Feedback, Tips worden gewaardeerd.
Alle Credits gaan naar Xmisery
  • nedernakker
  • Laatst online: 16-11-2024
dit heeft natuurlijk geen zin, iedere cpu,mem en moederbord zijn anders, en dit geld dus ook voor alle instellingen.
het is zelfs onverstandig om de instellingen van een ander over te nemen, als er iets niet goed werkt weet je nooit wat er loos is.
gewoon van voor af aan beginnen en stapje voor stapje opzoeken wat je spullen kunnen.
Ryzen 7 5700G // 3060 Ti // 32 GB 1600 MHz // 1 TB NVMe // 2 TB SATA // 2x 2560x1440 @75 hz
  • Speedy-J
  • Laatst online: 13-10 07:58
Speedy-J
AMD Enthusiast
Ik ben geen Intel kenner hoor maar is die CPU PLL voltage niet wat aan de hoge kant?
Ryzen 7 5800@4.7GHz|Asus prime X570 pro|16GB G-Skill trident z rgb|Gigabyte rtx 2070 super|Custom WC van EK|chietech dragon|Corsair 750w rm x
  • Lipadoza
nedernakker schreef op dinsdag 06 juli 2010 @ 17:05:
Deze algemene settings werken wel voor de mensen met hetzelfde type moederbord en CPU. wellicht is een lichte bump van de Vcore nodig maar niet persé ik heb deze setup ook zo direct over genomen en de mijne loopt stabiel.
Wat betreft Ram komt het veel voor dat mensen ddr3 1600mhz hebben wat betreft voltage kan deze op auto gezet worden maar het gaat hier voornamelijk om de cpu voltages Ik ben trouwens niet de enige die dit succesvol heeft overgenomen en het zou alleen maar mooi zijn als andere ook geholpen kunnen worden met overclocken van jhun 920 of 930 met dit moederbord :)
  • Lipadoza
Speedy-J schreef op dinsdag 06 juli 2010 @ 17:28:
dit is zelfs het minimum pll gaat van 1.8 > 2.4 als het goed is :P
  • daniel360gt
  • Laatst online: 22-10 16:31
Dit kan toch ook in het i7 9xx (1366) topic? Wordt alleen maar meer zoek werk voor andere bezoekers.
En net als Nedernakker zeg, volgens mij is het veel slimmer om je eigen setting te zoeken. En als je iets niet weer het gewoon te vragen op dit forum.
Je wordt altijd vriendelijk geholpen en je leert er 10x meer van omdat je exact weet wat er speelt.
Uiteindelijk kan je die kennis gebruiken om nieuwelingen te helpen. Is dat niet de bedoeling van het hele forum?
Een raadsel voor een lekker speciaal biertje o.i.d., plaats je antwoord in mijn profielreacties: 2447202 (Hint: startpunt)
  • nedernakker
Lipadoza schreef op dinsdag 06 juli 2010 @ 17:33:
nee, zo werkt het dus niet, maar goed, ik heb geen zin om hier over in discussie te gaan. het is heel simpel, overklokken werkt niet op deze manier, geen stuk hardware is hetzelfde punt.
Lipadoza schreef op dinsdag 06 juli 2010 @ 17:34:
het minimum is wel goed, maar daartussen zitten stapjes van 0,02V
