Elke Setup.exe chrashed op A7V na install 4-in1
  • Jemimus
  • Laatst online: 11-01-2023
Hier is een mailtje dat ik naar Asus stuurde vandaag:
Hello there,
A while ago I bought the Asus A7Pro as part of a general upgrade.
I have since then been though 2 of those boards, and now have an A7V, but the problem persists.
The problem is this: Once I install the Via inf drivers, the drivers that lets Windows properly detect the Via chipset, almost all programs I try to set up, crash. Its not so much the programs, but the INSTALLER that chrashes.
This happenes most often when installing something from a CD, like a game. Probably 90% of alle the setups I have tried crash immedietly, with either an 'invalid page fault' in <unkown> or Kernel32.
Now remember, this problem ONLY orrurs AFTER the INF drivers have been installed.
I first noticed this of course installing the 4-in-1 package from Via. I managed to narrow it down to the INF Drivers.
The other parts of the driver set, such as Viagart, work fine and are stable (as far as I can tell by game performance)
I have tried various version of the 4-in-1 set, up to and including 4.28a.
I have a suspicion that it may have to do with the CDROM player, so I have tried various things with that (like turning DMA on and off, switching controllers, switching to slave and back)
However, I have also tried copying and entire CD-ROM installation to HD and tried the Setup from there, with no result.
My system specs are as follows:
Asus A7V (rev. 5000a)
AMD T-bird 900
2 x DIMM 128mb 133Mhz @ 133Mhz
1 Maxtor 10GB (Primary slave)
1 Maxtor 23GB (Primary Master)
Toshiba DVD-ROM (secondary Master)
Creative Geforce 2 GTS
Creative SB Live player 1024
Sitecom ISDN
Sitecom Fast Ethernet
Please awnser this mail soon, I sent one a few months ago, and never got a replay.
Wie weet wat? :-)
Wie mij helpt krijgt... een... uhm... ferme handruk?
  • EquiNox
EquiNox
Speed plz.
?? vaag probleem...
probeer eens te installeren zonder ide drivers?
Succes!
  • fredkroket
Ik had ook zoiets, dat was opgelost toen ik de Logitech QuickCam weggeflikkerd had. Het zat bij mij in de combi videokaart & webcam. Met matrox G400 deed ie alles goed, met me GeForce 1 & 2 GTS had ik ook van die crashes. T klinkt lomp, maar t was wel zo.
Als je iets installeert schakel je dan alles wat op de achtergrond zou kunnen draaien zoals virus checkers ..etc uit ?
  • Wekkel
  • Laatst online: 15:44
Wekkel
De downloadkoning
Je bent niet aan het tweaken? Ik kom dit soort problemen nog wel eens tegen op systemen met opgefokt geheugen (Cas 3 op 2).
  • Jemimus
Nou, ik heb nog even voorzichtig gekeken, en het blijkt niet de INF bestanden te zijn, maar de Via IDE drivers (silly me ;)....
Systeem is niet getweaked, en het is een kale Win98SE install....
All your IDE driver bugs are belong to me :-(
Bedankt trouwens voor de snelle reacties :D
  • EquiNox
EquiNox
Speed plz.
Dus je heb de buggy IDE driver geuninstalled?
Dat probleem heb ik ook eens gehad, maar had bij mij nix met die via drivers te maken. Het lag toen aan de drivers van m'n netwerkkaart!
  • straat
  • Laatst online: 26-08 06:19
Zou misschien ook handig geweest zijn als je Asus verteld had welk OS je draait :z
  • Jemimus
Equinox: Dit is een bekend probleem?
Elmo: Wat voor Netwerk kaart? Wie weet .... ;)
Sorry dat ik zo laat reageer (had even tentamens aan m'n hoofd), maar het was een realtek rtl8139...
Ik zie dat jij een andere hebt, maar mocht je nog steeds problemen hebben, probeer dan eens setup's te draaien zonder die kaart!
  • SiliconError
  • Laatst online: 29-10-2025
SiliconError
Ik haal dit topic maar weer omhoog :)
Ik heb een Asus A7M266 en ik heb het zelfde probleem.
Ik heb een deel van die 4in1 shit geinstalled (A7M heeft alleen een VIA Southbridge), maar nu heb ik het zelfde probleem :(
Alle setup.exe's klappen er meteen uit... niet handig dus.
Hoe uninstall ik die klotezooi, gewoon apparaatbeheer -> IDE ATA/ATAPI-controllers -> VIA Bus Master IDE Controller, en dan die wegpleuren? Of doe ik dan iets heel erg fout :)
PS.
Ik vroeg me sowieso af welk deel van die 4in1 ik weg moest laten.
Bij het mobo kwamen 3in1 drivers, maar die wil ik er niet meer opzetten, en 3in1 drivers kan ik verder niet vinden :(
Ik dacht dat ik de AGP bus dingen weg moest laten... toch :?
  • Redheinz
  • Laatst online: 12-08 14:59
Je kunt al die via-shit ook apart krijgen:
IDE
AGP
INF-driver
IRQ-router
Je hebt alleen de south-bridge-shit nodig, dus i.i.g. de IDE-driver
en ook de IRQ-router denk.
AGP = north-bridge dus NIET INSTALLEN
INF-driver weet niet wat ie doet!
Zin.
  • SiliconError
SiliconError
AGP heb ik dan ook apart gehaald op AMD.com :)
Ik heb dit probleem ook gehad. Hij liep vast als ik een via driver installeerde en maakte niet uit welke versie. Dit was onder win 98. Ik ben er nooit achter gekomen waarom dit gebeurde. Ik had toen een matrox g400, 2 netwerkkaarten een nisd (sitecom) en een die bij je bij de UPC krijg voor de kabel en een soundblaster live en een PCI bullet etech modem.
Nu heb ik win ME geinstalleerd en lukt het me wel om de via driver te installeren. Het lijkt alleen nu dat als hij apparaten beheer bijwerken (of zo iets) een heel stuk trager doet.
  • SiliconError
SiliconError
Hmm, in Win98 heb ik het ook :(
En idd heb ik het gevoel dat alles een stukkie trager gaat...
