• huub8
  • Laatst online: 28-06-2021
Ik probeer de volgende H-bridge na te maken in ISIS professional (maar om iets van resultaat te kunnen zien gebruik ik een "light bulb" in plaats van een motor): Afbeeldingslocatie: http://upload.wikimedia.org/wikipedia/commons/5/5e/Bipolar_Stepper_Motor_H-bridge.png
Helaas werkt mijn shema niet, ik krijg namelijk al direct foutmeldingen (ook als alle schakelaren open staan). Dit is mijn schema:
Afbeeldingslocatie: http://i49.tinypic.com/nrtbl.jpg
Ik krijg de volgende foutmelding:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
SIMULATION LOG
Design:   UNTITLED.DSN
Doc. no.: <NONE>
Revision: <NONE>
Author:   <NONE>
Created:  11/06/10
Modified: 11/06/10
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [B84EC890]...
Animation started with warnings...
PROSPICE Release 6.9 SP1 (C) Labcenter Electronics 1993-2005.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Reading SPICE models...
Building circuit...
Warning: Net #00000 has no DC path to ground.
Check pins: B1-+, D3-K, D4-K, Q1-D, Q2-D, SWITCH#0010-NO, SWITCH#0011-NO, SWITCH#0013-COM, X07F048E8#0-*, X079A7978#0-*, X090A0A90#0-*, X090A0D30#1-*, X090A07F0#1-*, X090A0550#1-*, X090A1060#1-*, X0908D588#0-*
Warning: Net #00001 has no DC path to ground.
Check pins: Q1-G, SWITCH#0013-NO, X07F048E8#1-*, X079A7978#1-*
Warning: Net #00002 has no DC path to ground.
Check pins: Q2-G, SWITCH#0010-COM, X090A0D30#0-*, X0908D588#1-*
Warning: Net #00003 has no DC path to ground.
Check pins: Q3-G, SWITCH#0012-NO, X090A1390#1-*, X0908D828#1-*
Warning: Net #00004 has no DC path to ground.
Check pins: B1--, D1-A, D2-A, Q3-S, Q4-S, SWITCH#0012-COM, X090A0A90#1-*, X090A02B0#0-*, X090A0010#0-*, X090A1390#0-*, X0908D828#2-*, X0908DAC8#2-*
Warning: Net #00005 has no DC path to ground.
Check pins: Q4-G, SWITCH#0011-COM, X090A1060#0-*, X0908DAC8#1-*
Warning: Net #00006 has no DC path to ground.
Check pins: L1_AVS1-+, L1_VP1-+
Warning: Net #00007 has no DC path to ground.
Check pins: D2-K, D3-A, L1-2, L1_AVS1--, L1_AVS1-B, L1_R1-1, L1_VP1--, Q2-S, Q4-D, X090A02B0#1-*, X090A0550#0-*, X0908D588#2-*, X0908DAC8#0-*, X0908DD68#1-*
Warning: Net #00008 has no DC path to ground.
Check pins: D1-K, D4-A, L1-1, L1_AVS1-A, L1_R1-2, Q1-S, Q3-D, X07F048E8#2-*, X090A07F0#0-*, X090A0010#1-*, X0908D828#0-*, X0908DD68#0-*
Instantiating SPICE models...
[SPICE] transient GMIN stepping at time=0.00025
[SPICE] Error 106 - TRAN:  Timestep too small; time = 0.00025, timestep = 1.25e-19: trouble with node "#00000"
Totaliters=11568, Totalsteps=55, Goodsteps=28, Badsteps=27
Real Time Simulation FAILED.
EDIT:
Ik zag net dat de bovenste transistoren wellicht omgedraaid moeten worden, dus dat heb ik net ook even geprobeerd. Ik krijg in die situatie geen foutmeldingen, maar het geheel doet ook niets...
[ Voor 4% gewijzigd door huub8 op 28-05-2010 15:30 ]
  • bobo1on1
  • Laatst online: 19-10-2025
Sluit de min van de batterij eens aan op gnd.
Impedance, a measure of opposition to time-varying electric current in an electric circuit.
Not to be confused with impotence.
  • ReneK
  • Laatst online: 19:54
Ik kan de netnummers niet terugvinden in je schema, maar ik zie wel een hoop
"No DC path to ground" meldingen.
Als de schakelaars open staan, zijn de gates van de FET's nergens mee verbonden,
en ongedefineerd met de zeer hoge ingangsimpedantie van de MOSFET's.
Je moet dus een DC path maken, bv. door dummy weerstanden tussen gate en source te plaatsen.
  • huub8
als ik een gnd aansluit aan de minpool van de batterij krijg ik inderdaad geen foutmeldingen meer, maar doet het ook niets...
Dit is het schema dat ik nu heb.
[ Voor 25% gewijzigd door huub8 op 28-05-2010 16:07 ]
  • lemming_nl
Dat gaat ook niets doen. Je moet het geinverteerde signaal aanbieden aan een van de twee kanten. Nu staan beide N-mos open.
Geluk is een weerloos oud vrouwtje, alleen op straat met een bom geld
  • huub8
sorry, maar ben hier nog erg nieuw mee. Zou je kunnen toelichten wat je daar precies mee bedoeld/hoe ik het kan fixen?
  • Onbekend
  • Laatst online: 23:44
Onbekend
huub8 schreef op vrijdag 28 mei 2010 @ 17:02:
Kijk eens goed naar Q1 t/m Q4 en vergelijk het eens met jouw eigen schema.....
  • huub8
ook als ik Q1 en Q2 omdraai doet hij het niet, en verder zie ik geen verschil...
  • Onbekend
Onbekend
Je hebt schakelaars (die met die twee rode puntjes) gemaakt.
Kan je de Gates met elkaar doorverbinden (zoals ook in het bovenste ontwerp staat) zodat je maar de twee aansluitingen 1a en 1b hebt?
Nadat je dit gedaan hebt, moet je 0V of 9V op 1a en 1b zetten om de schakeling te laten werken.
  • huub8
Ik heb het geprobeerd te maken zoals jij zei, maar ook zo werkt het niet:
Afbeeldingslocatie: http://i47.tinypic.com/24wy9n4.jpg
Wat is er nu dan nog fout?
  • Onbekend
Onbekend
huub8 schreef op maandag 31 mei 2010 @ 18:12:
Je moet wel de Gates van Q1 en Q3 met elkaar doorverbinden, en de Gates van Q2 en Q4 ook met elkaar doorverbinden (zoals op het eerste plaatje is aangegeven).
Daarnaast moet je de schakelaars vervangen door bijvoorbeeld wisselschakelaars. Hiermee kan je de Gates óf aan de 0V hangen, óf aan de +9V.
[ Voor 3% gewijzigd door Onbekend op 31-05-2010 18:18 ]
  • huub8
Aah, heel erg bedankt. Zo werkt hij inderdaad
