[SQL 2005] SP3 Install error MSI 1603 29527
Probleembeschrijving in het Engels, hopelijk geen probleem
Situation
OS: 2003 x64 R2 SP2
2 Cluster nodes.
Cluster was set up as one node, 2nd node was added later. Failover works without any errors.
Node 1 is running at 2005 SP3
Node 2 is running at 2005 RTM
When SP3 setup is launched from node 2(with resource group of instance on node 2) node 1 installation fails, and installation stops before node 2 is doen.
When SP3 setup is launched from node 1(with resource group of instance on node 1) node 1 installation fails, but because the passive node is updated first, it does succeed on node 2.
Any one know a way how to get around this
Relevent excerpt of hotfix.log:
05/26/2010 21:24:08.160 MSP Error: 29527 The setup has encountered an unexpected error in datastore. The action is RestoreSetupParams. The error is : Source File Name: datastore\cachedpropertycollection.cpp
Compiler Timestamp: Mon Nov 17 17:05:55 2008
Function Name: CachedPropertyCollection::findProperty
Source Line Number: 130
Failed to find property "OwningGroup" {"VirtualServerInfo", "", "ROSSSQLPRODSRV"} in cache
Source File Name: datastore\clusterinfocollector.cpp
Function Name: ClusterInfoCollector::collectClusterVSInfo
Source Line Number: 888
Failed to detect VS info due to datastore exception.
Source File Name: datastore\machineconfigscopeproperties.cpp
Compiler Timestamp: Mon Nov 17 17:06:00 2008
Function Name:
