Asus Xonar Essence STX nieuwe Béta-drivers
Asus heeft eindelijk nieuwe béta-drivers voor zijn Xonar Essence STX uitgebracht. Het is versie Beta Version 6.12.8.1771 en ze geven een hoorbare geluidsverbetering terwijl de geluidskwaliteit voor analoge set-ups al superieur was aan de creative-meuk. Ze zijn gewoon te downloaden op de nederlandse site van Asus.
Asus zegt er over: Xonar Essence STX bit-perfect ASIO driver (beta) for Windows Vista 32/64bit
1. Sample rate supported: 44.1 / 48 / 88.2 / 96 / 176.4 / 192 kHz
2. Supports one ASIO playback stream (maximum 8 channels) to analog output.
3. Supports one ASIO recording stream (2 channels) from analog input.
4. Recording source (microphone in or line in) is selected by system mixer.
5. To keep the ASIO stream bit-perfect, the following two rules apply:
(1)The ASIO stream has higher priority of using DMA buffer than other streams. That is, when the ASIO stream is played, other streams cannot be played.
(2)No volume control is available for the ASIO stream.
6. When there are more than two ASIO applications running, only one application gets the right to use the hardware resource. This is based on “first come, first service” rule.
7. Current buffer time is set at 10ms, will be adjustable in later version
Notice
In Windows Vista/7 32- and 64-bit systems, users should use “Run as Administrator” to run ASIO applications to get the best performance.
Disclaimer:
Please be noted that this is still test version and feedback in our support forum should you encountered any error during operation, we appreciate your assistance to make Xonar Essence STX bit-perfect driver better.
ASUS Xonar support forum:
http://vip.asus.com/forum...ard_id=21&SLanguage=en-us
[ Voor 71% gewijzigd door Verwijderd op 28-05-2010 12:05 ]
