Java applet toevoegen in Publisher 2007
  • 115 views
Momenteel ben ik bezig met het maken van een website in MS Office Publisher 2007 en wil daar een java applet in toevoegen. Zodra ik de html codefragment ingevoegd heb en vervolgens de voorbeeldpagina aanklik, krijg ik de volgende melding in een wit scherm:
Java Plug-in 1.6.0_20
Using JRE version 1.6.0_20-b02 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\gebruiker
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
load: class starwars.class not found.
java.lang.ClassNotFoundException: starwars.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.FileNotFoundException: C:\Documents and Settings\gebruiker\Local Settings\Temporary Internet Files\Content.MSO\PubWebPagePreview\pub2432.4\starwars\class.class (Het systeem kan het opgegeven pad niet vinden)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.connect(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: starwars.class
Ignored exception: java.lang.ClassNotFoundException: starwars.class
Weet iemand wat ik mogelijk fout doe? Alvast bedankt
  • MueR
MueR
Admin Devschuur® & Discord
is niet lief
Je hint staat in
Dit topic gaat op slot. Zomaar een foutmelding dumpen zonder blijk van inzet scharen we onder Kan iemand even .. ?
Anyone who gets in between me and my morning coffee should be insecure.
