VMWare server 2.0.1/2.0.2 op Debian 5 installeren
  • sariel
  • Laatst online: 22-09 15:35
Ik probeer Vmware server 2.0.1 of 2.0.2 te installeren op mijn Debian 5 machine. Zowel 2.0.1 als 2.0.2 lukt niet door een compile-fout tijdens het compileren van de modules. Hoe kan ik VMWare server wel installeren op m'n systeem?
Sysinfo:
Debian 5 testing (stable loopt echt veel te ver achter)
latest updates
Type: vserver systeem, vmware compileren echter in vserver-host, niet in virtuele server
kernel: 2.6.32-trunk-vserver-686 #1 SMP
cpu: Intel(R) Pentium(R) 4 CPU 2.66GHz
mem: 1.5Gb
Disk: 0.5 Tb (totaal over 4 disks)
GCC: 4.3 (4.4 ook geinstalleerd, VMWare weigert deze echter) /usr/bin/gcc symlinked naar gcc-4.3
Snippets:
Compileren Vanilla 2.0.1 en 2.0.2 (fout op regels 29-42)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
What is the location of the directory of C header files that match your running
kernel?
[/lib/modules/2.6.32-trunk-vserver-686/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: Entering directory `/tmp/vmware-config3/vmmon-only'
make -C /lib/modules/2.6.32-trunk-vserver-686/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-trunk-vserver-686'
  CC [M]  /tmp/vmware-config3/vmmon-only/linux/driver.o
In file included from /tmp/vmware-config3/vmmon-only/linux/driver.c:31:
/tmp/vmware-config3/vmmon-only/./include/compat_wait.h:78: error: conflicting types for ‘poll_initwait’
/usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/poll.h:70: error: previous declaration of ‘poll_initwait’ was here
In file included from /tmp/vmware-config3/vmmon-only/./common/vmx86.h:32,
                 from /tmp/vmware-config3/vmmon-only/linux/driver.h:29,
                 from /tmp/vmware-config3/vmmon-only/linux/driver.c:101:
/tmp/vmware-config3/vmmon-only/./include/x86msr.h:164:1: warning: "MSR_THERM2_CTL" redefined
In file included from /usr/src/linux-headers-2.6.32-trunk-common-vserver/arch/x86/include/asm/msr.h:4,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/arch/x86/include/asm/processor.h:21,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/prefetch.h:14,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/list.h:6,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/module.h:9,
                 from /tmp/vmware-config3/vmmon-only/./include/compat_module.h:27,
                 from /tmp/vmware-config3/vmmon-only/linux/driver.c:26:
/usr/src/linux-headers-2.6.32-trunk-common-vserver/arch/x86/include/asm/msr-index.h:225:1: warning: this is the location of the previous definition
/tmp/vmware-config3/vmmon-only/linux/driver.c: In function ‘LinuxDriverSyncCallOnEachCPU’:
/tmp/vmware-config3/vmmon-only/linux/driver.c:1423: error: too many arguments to function ‘smp_call_function’
/tmp/vmware-config3/vmmon-only/linux/driver.c: In function ‘LinuxDriver_Ioctl’:
/tmp/vmware-config3/vmmon-only/linux/driver.c:1987: error: ‘struct task_struct’ has no member named ‘euid’
/tmp/vmware-config3/vmmon-only/linux/driver.c:1987: error: ‘struct task_struct’ has no member named ‘uid’
/tmp/vmware-config3/vmmon-only/linux/driver.c:1988: error: ‘struct task_struct’ has no member named ‘fsuid’
/tmp/vmware-config3/vmmon-only/linux/driver.c:1988: error: ‘struct task_struct’ has no member named ‘uid’
/tmp/vmware-config3/vmmon-only/linux/driver.c:1989: error: ‘struct task_struct’ has no member named ‘egid’
/tmp/vmware-config3/vmmon-only/linux/driver.c:1989: error: ‘struct task_struct’ has no member named ‘gid’
/tmp/vmware-config3/vmmon-only/linux/driver.c:1990: error: ‘struct task_struct’ has no member named ‘fsgid’
/tmp/vmware-config3/vmmon-only/linux/driver.c:1990: error: ‘struct task_struct’ has no member named ‘gid’
/tmp/vmware-config3/vmmon-only/linux/driver.c:2007: error: too many arguments to function ‘smp_call_function’
make[4]: *** [/tmp/vmware-config3/vmmon-only/linux/driver.o] Error 1
make[3]: *** [_module_/tmp/vmware-config3/vmmon-only] Error 2
make[2]: *** [sub-make] Error 2
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-trunk-vserver-686'
make: *** [vmmon.ko] Error 2
make: Leaving directory `/tmp/vmware-config3/vmmon-only'
Unable to build the vmmon module.
Compileren patched 2.0.1 en 2.0.2 (fout op regels 153-168)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
:/usr/src/vmware-patches# sh vmware-server.2.0.1_x64-modules-2.6.30-fix.sh
Found tar file for vmmon module
Found tar file for vsock module
Found tar file for vmnet module
Found tar file for vmci module
Using patch file: /usr/src/vmware-patches/vmware-server.2.0.1_x64-modules-2.6.30-fix.patch
Using module directory: /usr/lib/vmware/modules/source
Using backup directory: /usr/lib/vmware/modules/source-backup
Backing up ./vmmon.tar to /usr/lib/vmware/modules/source-backup/./vmmon.tar
Backing up ./vsock.tar to /usr/lib/vmware/modules/source-backup/./vsock.tar
Backing up ./vmnet.tar to /usr/lib/vmware/modules/source-backup/./vmnet.tar
Backing up ./vmci.tar to /usr/lib/vmware/modules/source-backup/./vmci.tar
Untarring vmmon.tar
Untarring vsock.tar
Untarring vmnet.tar
Untarring vmci.tar
Testing patch
patching file vmci-only/Makefile
patching file vmmon-only/linux/driver.c
patching file vmmon-only/linux/hostif.c
patching file vmmon-only/include/x86svm.h
patching file vmmon-only/Makefile
patching file vmnet-only/Makefile
patching file vmnet-only/netif.c
patching file vsock-only/Makefile
Applying patch!
Preparing new tar file for vmmon module
Preparing new tar file for vsock module
Preparing new tar file for vmnet module
Preparing new tar file for vmci module
Trying to compile vmmon module to see if it works
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/linux/driver.o
In file included from /usr/lib/vmware/modules/source/vmmon-only/./common/vmx86.h:32,
                 from /usr/lib/vmware/modules/source/vmmon-only/linux/driver.h:29,
                 from /usr/lib/vmware/modules/source/vmmon-only/linux/driver.c:101:
/usr/lib/vmware/modules/source/vmmon-only/./include/x86msr.h:164:1: warning: "MSR_THERM2_CTL" redefined
                 from /usr/lib/vmware/modules/source/vmmon-only/./include/compat_module.h:27,
                 from /usr/lib/vmware/modules/source/vmmon-only/linux/driver.c:26:
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/linux/driverLog.o
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/linux/hostif.o
                 from /usr/lib/vmware/modules/source/vmmon-only/./common/hostif.h:32,
                 from /usr/lib/vmware/modules/source/vmmon-only/linux/hostif.c:72:
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/arch/x86/include/asm/thread_info.h:22,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/thread_info.h:56,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/preempt.h:9,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/spinlock.h:50,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/mmzone.h:7,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/gfp.h:4,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/mm.h:8,
                 from /usr/lib/vmware/modules/source/vmmon-only/./include/compat_page.h:23,
                 from /usr/lib/vmware/modules/source/vmmon-only/linux/hostif.c:32:
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/common/comport.o
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/common/cpuid.o
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/common/hashFunc.o
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/common/memtrack.o
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/common/phystrack.o
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/common/task.o
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/common/vmx86.o
In file included from /usr/lib/vmware/modules/source/vmmon-only/common/vmx86.h:32,
                 from /usr/lib/vmware/modules/source/vmmon-only/common/vmx86.c:40:
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/seqlock.h:29,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/time.h:8,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/timex.h:56,
                 from /usr/src/linux-headers-2.6.32-trunk-common-vserver/include/linux/sched.h:56,
                 from /usr/lib/vmware/modules/source/vmmon-only/common/vmx86.c:32:
  CC [M]  /usr/lib/vmware/modules/source/vmmon-only/vmcore/moduleloop.o
                 from /usr/lib/vmware/modules/source/vmmon-only/vmcore/moduleloop.c:35:
                 from /usr/lib/vmware/modules/source/vmmon-only/./include/compat_sched.h:23,
                 from /usr/lib/vmware/modules/source/vmmon-only/vmcore/moduleloop.c:31:
  LD [M]  /usr/lib/vmware/modules/source/vmmon-only/vmmon.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /usr/lib/vmware/modules/source/vmmon-only/vmmon.mod.o
  LD [M]  /usr/lib/vmware/modules/source/vmmon-only/vmmon.ko
cp -f vmmon.ko ./../vmmon.o
Trying to compile vsock module to see if it works
  CC [M]  /usr/lib/vmware/modules/source/vsock-only/linux/af_vsock.o
  CC [M]  /usr/lib/vmware/modules/source/vsock-only/linux/driverLog.o
  CC [M]  /usr/lib/vmware/modules/source/vsock-only/linux/util.o
  CC [M]  /usr/lib/vmware/modules/source/vsock-only/linux/vsockAddr.o
  LD [M]  /usr/lib/vmware/modules/source/vsock-only/vsock.o
  MODPOST 1 modules
WARNING: "VMCIDatagram_CreateHnd" [/usr/lib/vmware/modules/source/vsock-only/vsock.ko] undefined!
WARNING: "VMCIDatagram_DestroyHnd" [/usr/lib/vmware/modules/source/vsock-only/vsock.ko] undefined!
WARNING: "VMCI_GetContextID" [/usr/lib/vmware/modules/source/vsock-only/vsock.ko] undefined!
WARNING: "VMCIDatagram_Send" [/usr/lib/vmware/modules/source/vsock-only/vsock.ko] undefined!
  CC      /usr/lib/vmware/modules/source/vsock-only/vsock.mod.o
  LD [M]  /usr/lib/vmware/modules/source/vsock-only/vsock.ko
cp -f vsock.ko ./../vsock.o
Trying to compile vmnet module to see if it works
  CC [M]  /usr/lib/vmware/modules/source/vmnet-only/driver.o
  CC [M]  /usr/lib/vmware/modules/source/vmnet-only/hub.o
  CC [M]  /usr/lib/vmware/modules/source/vmnet-only/userif.o
  CC [M]  /usr/lib/vmware/modules/source/vmnet-only/netif.o
/usr/lib/vmware/modules/source/vmnet-only/netif.c: In function ‘VNetNetIfSetup’:
/usr/lib/vmware/modules/source/vmnet-only/netif.c:201: error: ‘struct net_device’ has no member named ‘init’
/usr/lib/vmware/modules/source/vmnet-only/netif.c:202: error: ‘struct net_device’ has no member named ‘open’
/usr/lib/vmware/modules/source/vmnet-only/netif.c:203: error: ‘struct net_device’ has no member named ‘hard_start_xmit’
/usr/lib/vmware/modules/source/vmnet-only/netif.c:204: error: ‘struct net_device’ has no member named ‘stop’
/usr/lib/vmware/modules/source/vmnet-only/netif.c:205: error: ‘struct net_device’ has no member named ‘get_stats’
/usr/lib/vmware/modules/source/vmnet-only/netif.c:206: error: ‘struct net_device’ has no member named ‘set_mac_address’
/usr/lib/vmware/modules/source/vmnet-only/netif.c:207: error: ‘struct net_device’ has no member named ‘set_multicast_list’
make[4]: *** [/usr/lib/vmware/modules/source/vmnet-only/netif.o] Error 1
make[3]: *** [_module_/usr/lib/vmware/modules/source/vmnet-only] Error 2
make: *** [vmnet.ko] Error 2
Sorry, problem compiling the vmnet module after it was patched
You must restore from this backup directory:
De patch is geleverd door een andere gebruiker die met deze patch VMWare wel werkend kreeg, maar het lijkt bij mij niet echt te werken.
Heeft iemand anders enige suggesties hoe ik het werkend krijg?
Copy.com
  • blaataaps
Wat gaat er mis met die patch?
  • hostname
  • Laatst online: 14-11 21:04
sariel schreef op donderdag 15 april 2010 @ 16:45:
Dan is het geen debian 5 meer, maar debian 6 (5 = lenny, 6 = squeeze, wat nu testing is) ;)
Op de debian wiki staat ook nog een patch voor VMWare server voor lenny, die heb je ook nodig waarschijnlijk.
Voor jouw specifieke probleem is ook een thread op de VMWare forums te vinden, met daar ook een patch bij...
  • sariel
@hostname: Ik heb net de patch uitgeprobeerd, kwam van hier, en het lijkt er op dat het tot nu toe werkt.
Na 5 minuten: Het werk :) Bedankt hostname :)
Enige tijd later: Deels....vmware mgmt webinterface is stuk. Doorzoeken dus :(
[ Voor 15% gewijzigd door sariel op 17-04-2010 10:49 ]
Copy.com
  • hostname
sariel schreef op zaterdag 17 april 2010 @ 09:20:
Toevallig Firefox 3.6? Zo ja, dan moet je even security.enable_ssl2 aanzetten in about:config.
  • jediah
  • Laatst online: 17:16
jediah
Wat vind je er nou zelf van?
Wou net zeggen dat je die fix moet gebruiken, zat met het zelfde probleem. Ben er zo ook uit gekomen !
  • sariel
hostname schreef op zaterdag 17 april 2010 @ 11:12:
Nee, Chrome. Maar IE en FF doen allemaal niets. HTTP 503 foutmelding, en catalina/tomcat lijkt ook niet te draaien op de server. Misschien iets mis met de JAVA of zo....ik heb nu nog geen tijd gehad om te puzzelen, ga straks of morgen wel verder zoeken.
Copy.com
  • raymonvdm
  • Laatst online: 12-11 17:01
Ik krijg het ook niet meer voor elkaar om Vmware Server te laten draaien op Ubuntu 9.10, ook bij mij lukt het niet om de in te loggen op de interface. Zoals gewoonlijk is het probleem veroorzaakt door de installatie van een nieuwe kernel.
Ik ga op dit moment virtualbox proberen om te kijken of die geen last heeft dat hij steeds doodgaat bij het updaten van de kernel. Ik ben er nog niet helemaal uit wat nu de ideale virtualisatie is voor thuis. Tot nu toe leek het VMware server 1.0x maar die lukte vorige keer al niet meer daar om zit ik nu te klote met Vmware server 2.02
@Topicstarter, is het inmiddels wel gelukt ?
