[SBS2008] WSUS werkt niet meer na update
  • Grolsch
  • Laatst online: 20-11 06:46
Hallo Tweakers,
na een aantal update's werkt m'n wsus niet meer op m'n sbs2008 server.
In de windows sbs console zie ik bij update's "not available"
Als ik handmatig windows server update services start krijg ik deze melding:
29
30
31
32
33
34
35
36
37
38
39
40
41
The WSUS administration console was unable to connect to the WSUS Server via the remote API.
Verify that the Update Services service, IIS and SQL are running on the server. If the problem persists, try restarting IIS, SQL, and the Update Services Service.
The WSUS administration console has encountered an unexpected error. This may be a transient error; try restarting the administration console. If this error persists,
Try removing the persisted preferences for the console by deleting the wsus file under %appdata%\Microsoft\MMC\.
System.IO.IOException -- The handshake failed due to an unexpected packet format.
Source
System
Stack Trace:
   at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Net.TlsStream.ProcessAuthentication(LazyAsyncResult result)
   at System.Net.TlsStream.Write(Byte[] buffer, Int32 offset, Int32 size)
   at System.Net.PooledStream.Write(Byte[] buffer, Int32 offset, Int32 size)
   at System.Net.ConnectStream.WriteHeaders(Boolean async)
** this exception was nested inside of the following exception **
System.Net.WebException -- The underlying connection was closed: An unexpected error occurred on a send.
Source
Microsoft.UpdateServices.Administration
Stack Trace:
   at Microsoft.UpdateServices.Administration.AdminProxy.CreateUpdateServer(Object[] args)
   at Microsoft.UpdateServices.Administration.AdminProxy.GetUpdateServer(String serverName, Boolean useSecureConnection, Int32 portNumber)
   at Microsoft.UpdateServices.UI.AdminApiAccess.AdminApiTools.GetUpdateServer(String serverName, Boolean useSecureConnection, Int32 portNumber)
   at Microsoft.UpdateServices.UI.SnapIn.Scope.ServerSummaryScopeNode.GetUpdateServer(PersistedServerSettings settings)
   at Microsoft.UpdateServices.UI.SnapIn.Scope.ServerSummaryScopeNode.ConnectToServer()
   at Microsoft.UpdateServices.UI.SnapIn.Scope.ServerSummaryScopeNode.get_ServerTools()
in m'n logboek heb ik een aantal meldingen welke er naar mijn idee mee te maken hebben:
Log Name: Application
Source: Windows SharePoint Services 3 Search
Date: 8-4-2010 19:40:02
Event ID: 2424
Task Category: Gatherer
Level: Error
Keywords: Classic
User: N/A
Computer: SBS2008.***.local
Description:
The update cannot be started because the content sources cannot be accessed. Fix the errors and try the update again.
Context: Application 'Search', Catalog 'index file on the search server Search'
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Windows SharePoint Services 3 Search" />
<EventID Qualifiers="32768">2424</EventID>
<Level>2</Level>
<Task>3</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2010-04-08T17:40:02.000Z" />
<EventRecordID>125799</EventRecordID>
<Channel>Application</Channel>
<Computer>SBS2008.***.local</Computer>
<Security />
</System>
<EventData>
<Data>
Context: Application 'Search', Catalog 'index file on the search server Search'</Data>
</EventData>
</Event>
Tijdens 1 van deze updates geinstalleerd op 02-04-2010 is het verkeerd gegaan.
Afbeeldingslocatie: http://i41.tinypic.com/35m1nhh.jpg
PVOUPUT - 13.400WP - Twente
  • alt-92
alt-92
ye olde farte
En heb je gecontroleerd (zoals de log ook suggereert) of je SQL DB benaderbaar is? Gezien het punt dat er ook een SQL SP niet goed geinstalleerd is....
[ Voor 29% gewijzigd door alt-92 op 08-04-2010 20:02 ]
  • Grolsch
Ikk kan de sql microsoft##SEE inderdaad niet openen, ik krijg deze melding:
Afbeeldingslocatie: http://i43.tinypic.com/2wcfyq8.jpg
  • Zwelgje
  • Laatst online: 17-08 09:02
staat de WWW service zo ingesteld dat deze kan 'interacten' met de desktop :?
dat je niet met de sql manager kan connecteren op die instance is normaal overigens, het is een internal database en geen sql express :)
ik zou denken dat je probleem iets met IIS te maken heeft, kijk eens in de IIS manager
  • Grolsch
Powershell schreef op vrijdag 09 april 2010 @ 08:18:
Ik heb de world wide web publishing service laten interacten met m'n desktop, en vervolgens IIS gerestart, maar ook dat lost mijn probleem niet op.
zie onderstaande screenshot:
Afbeeldingslocatie: http://i43.tinypic.com/15f5h61.jpg
het lijkt wel of wsus in 2 talen is geïnstalleerd.
Als ik de administration stop, en de beheer start werkt het wel :?
Zal die administration dan maar eens disablen.
[ Voor 11% gewijzigd door Grolsch op 09-04-2010 10:17 ]
  • Zwelgje
Grolsch schreef op vrijdag 09 april 2010 @ 10:11:
dat ding moet juist niet interacten met je desktop :>
  • Grolsch
en ergens op internet stond juist dat je dat wel aan moest zetten.
Ik heb die engelstalige weg gegooit, en die andere gestart, nu werkt het!
  • Grolsch
ik blijf trouwens onderstaande event melding krijgen in m'n logboeken
Event ID: 2424
Level: Error
Keywords: Classic
User: N/A
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>3</Task>
<Security />
</System>
<EventData>
<Data>
</EventData>
</Event>
Onderstaande posts heb ik gelezen, maar lossen het probleem niet op:
Error message when you perform a search query after you upgrade to the release version of Microsoft Windows SharePoint Services 3.0: "Your search cannot be completed because of a service error"
http://blogs.msdn.com/sha...-Beta-2-Tech-Refresh.aspx
