PHP sessie loopt brak
  • Xanthium
  • Laatst online: 07-10 15:22
Hallo, ik probeer een login pagina op te zetten aan de hand van een PHP tutorial. Het werkt aardig alleen krijg ik steeds deze error bovenin de pagina als de gebruiker succesvol is ingelogd:
Notice: Use of undefined constant myusername - assumed 'myusername' in D:\wamp\www\index.php on line 3
Deprecated: Function session_is_registered() is deprecated in D:\wamp\www\index.php on line 3
Login Successful
check.php:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
<?php
ob_start();
$host="localhost"; // Host name
$username="krol"; // Mysql username
$password="blabla"; // Mysql password
$db_name="app"; // Database name
$tbl_name="members"; // Table name
// Connect to server and select databse.
mysql_connect("$host", "$username", "$password")or die("cannot connect");
mysql_select_db("$db_name")or die("cannot select DB");
// Define $myusername and $mypassword
$myusername=$_POST['myusername'];
$mypassword=$_POST['mypassword'];
// To protect MySQL injection (more detail about MySQL injection)
$myusername = stripslashes($myusername);
$mypassword = stripslashes($mypassword);
$myusername = mysql_real_escape_string($myusername);
$mypassword = mysql_real_escape_string($mypassword);
$sql="SELECT * FROM $tbl_name WHERE username='$myusername' and password='$mypassword'";
$result=mysql_query($sql);
// Mysql_num_row is counting table row
$count=mysql_num_rows($result);
// If result matched $myusername and $mypassword, table row must be 1 row
if($count==1){
// Register $myusername, $mypassword and redirect to file "index.php"
session_register("myusername");
session_register("mypassword");
header("location:index.php");
else {
echo "login failed";
ob_end_flush();
Ik snap dat de index.php de sessie van de check.php niet helemaal lekker overpakt. Ik snap alleen niet waar het aan kan liggen, na veel gepriegel leg ik m'n vraag daarom hier neer.
index.php:
<?php
session_start();
if(!session_is_registered(myusername)){
header("location:login.php");
<html>
<body>
Login Successful
</body>
</html>
bvd.. _/-\o_
  • fiftyhillswest
  • Laatst online: 15-10 16:28
PHP:
if(!session_is_registered("myusername")){
    //rest van het verhaal
misschien?
Had je door even te debuggen ook kunnen vinden, die error message is nogal obvious
[ Voor 69% gewijzigd door fiftyhillswest op 18-03-2010 18:19 ]
  • Avalaxy
  • Laatst online: 12-03 15:40
Zoals de error zelf al zegt is die functie deprecated. Zie: http://php.net/manual/en/function.session-is-registered.php
In plaat van session_register kun je dit doen:
PHP:
$_SESSION['hoi'] = "value";
En vervolgens checken of er een sessie is dmv:
PHP:
if (isset($_SESSION['hoi'])) {
     // doe iets
else {
     // doe iets
Overigens kom je code me wel bekend voor. http://www.phpeasystep.com/workshopview.php?id=6 anyone? :P
[ Voor 12% gewijzigd door Avalaxy op 18-03-2010 18:24 ]
  • Xanthium
Avalaxy schreef op donderdag 18 maart 2010 @ 18:23:
PHP:
PHP:
     // doe iets
else {
     // doe iets
haha ja dat was inderdaad mijn bron ;) dankjewel voor je tip, ik ga ermee aan de slag
  • Avalaxy
Xanthium schreef op donderdag 18 maart 2010 @ 18:30:
Neem deze er bij: http://www.tizag.com/phpT/phpsessions.php
Goede tutorial voor beginners imho.
