0W-30 of 5W-30 olie gebruiken?
  • Erazzzer
  • Laatst online: 16:21
Erazzzer
Fear me, I'm German!
Ik heb een Opel Meriva uit 2005 met een 1.7CTDI. Om hier olie voor te gaan halen heb ik even in het onderhoudsboekje gekeken en daarin stond dat er altijd 5W-30 door de dealer is gebruikt. Nu heb ik op castrol.nl even gekeken en Castrol raad 0W-30 aan voor mijn auto. Ik heb 0 verstand van auto onderhoud, wat kan ik beter doen?
  • Gisae
Maakt niet zoveel uit. 0w30 is iets vloeibaarder op lage temperatuur.
Stukje over een specifiek merk olie, maar de strekking blijft hetzelfde:
Which 30 Weight Oil Do I Use, 0W-30, 5W-30 or 10W-30?
We get asked this question so often that we have included this special page dedicated exclusively to answering the question.
AMSOIL 0W-30, 5W-30 and 10W-30 synthetic motor oils are ALL 30 weight oils. The answer is that ANY one can be used regardless if your vehicle owners manual says to use, for example, a 5W-30. "W" means winter. In winter weather the 0W oil will flow like a 0W oil, and the 5W will flow like a 5W oil and a 10W will flow like a 10W oil just until the engine warms up. In order to understand the differences one has to first understand that the numerical values given to these various weight oils are strictly empirical numbers. For example, 0W does not mean that the oil has no weight. That is one of the reasons why we say it is strictly an empirical number.
In order to determine the differences between the three oils one has to look at the kinematic viscosity of each lubricant. The kinematic viscosity is essentially the amount of time, in centistokes, that it takes for a specified volume
of the lubricant to flow through a fixed diameter orifice at a given temperature.
Let's compare the kinematic viscosity of the three AMSOIL lubricants
AMSOIL 0W-30 is 57.3 cST @ 40 °C, & 11.3 cST @ 100 °C
AMSOIL 5W-30 is 59.5 cST @ 40 °C, & 11.7 cST @ 100 °C
AMSOIL 10W-30 is 66.1 cST @ 40 °C, & 11.7 cST @ 100 °C
As you can see from the data above the kinematic viscosities are extremely close. Therefore, whether you use the 0W-30, 5W-30 or the 10W-30 is strictly a matter of choice. With the small differences in kinematic viscosity you would be hard-pressed to detect these differences on initial engine start-up without specialized engine test equipment.
All three oils are excellent motor oils and ANY one can be used in a vehicle which requires either a 0W-30, 5W-30 or 10W-30 oil as well as in several other engine applications including an engine which recommends a 5W- 20 oil.
[ Voor 93% gewijzigd door Gisae op 09-03-2010 20:08 ]
Why have a civilization anymore if we no longer are interested in being civilized?
  • Erazzzer
Erazzzer
Ander vraagje, ik heb de webwinkel protex.nl gevonden. Castrol oliën zijn daar vele malen goedkoper dan bv. bij Halfords. Is Halfords gewoon duur met oliën of is Protex niet te vertrouwen?
http://www.opieoils.co.uk/ is een goeie toko
  • Erazzzer
Erazzzer
Alleen kost het verzenden 15,50 pond. Maakt het niet echt goedkoop
  • Spiller
  • Laatst online: 08-03 20:31
Ik haal mn 10w60 TWS gewoon van ebay.de. Scheelt 15 euro de liter met de dealer :)
Waarom zou Protex niet te vertrouwen zijn? Ben je altijd zo paranoide bij webwinkels?
Ioniq 5 P45
  • Erazzzer
Erazzzer
Nee, niet paranoide, maar de site ziet nou niet bijster professioneel uit. En googelen op ervaringen heeft niets opgeleverd, vandaar...
  • _JGC_
  • Laatst online: 16:40
De website van Kroon geeft 0W40, 5W40 of 5W30 aan als mogelijke oliesoorten. Als dat ding altijd al 5W30 gezopen heeft zou ik daar gewoon weer mee verversen. 0W30 moet ook gewoon kunnen. Persoonlijk ben ik van mening dat het niet echt uitmaakt of je nou Castrol, Shell of Kroon in je auto gooit, ze maken allemaal goede olie, en er zullen ook vast nog meer zijn.
De enige olie waar ik ver weg van blijf is goedkope zooi uit de bouwmarkt of van de Action, die troep wordt meestal aanbevolen als geschikt voor alle auto's, maar als je bij de meeste auto's in het boekje kijkt blijkt dat vaak toch anders te zijn.
  • Steffie
  • Laatst online: 16-10 16:17
Steffie
Opaque
Erazzzer schreef op woensdag 10 maart 2010 @ 15:07:
De prijzen zijn daar wel exclusief BTW. Ik heb alleen even naar de prijs van Castrol RS 2T gekeken en inclusief de BTW heeft dat praktisch dezelfde prijs als bij alle andere winkels. Van andere soorten olie weet ik zo geen prijzen uit mijn hoofd, maar ik kan me voorstellen dat je niet hebt gezien dat de prijzen daar exclusief BTW zijn.
[ Voor 15% gewijzigd door Steffie op 11-03-2010 02:19 ]
With the sun and the moon on either side of his helmet, a new star is born in the name of Valentino Rossi
  • Erazzzer
Erazzzer
Steffie schreef op donderdag 11 maart 2010 @ 02:17:
Ah oke, op de BTW had ik niet gelet. Dan dus toch maar gewoon naar de Halfords of Brezan...
