SuSE 7.0 Named errors??!!!
  • 115 views sinds 30-01-2008
Beste vrienden die meer van linux weten/snappen dan ik :D
Ik krijg als ik mijn nameserver (bind8) start de volgende meldingen in mijn /var/log/messages te zien. Deze errors kreeg ik nooit. en er is ook nada veranderd. ja er zijn wat domeintjes bijgekomen.
Wat mij vooral zorgen baart is de Lame server meldingen.
mijn versie van named: Named 8.2.3-T5B Wed Sep 20 18:10:28 GMT 2000
root@mersenne:/usr/src/packages/BUILD/bind8-8.2.3/bin/named
de errors.. :'(
Mar 8 11:43:23 swammie named[29502]: listening on [10.34.137.17].53 (ppp0)
Mar 8 11:43:23 swammie named[29502]: Forwarding source address is [0.0.0.0].4299
Mar 8 11:43:24 swammie named[29503]: group = named
Mar 8 11:43:24 swammie named[29503]: user = named
Mar 8 11:43:24 swammie named[29503]: Ready to answer queries.
Mar 8 11:43:24 swammie named[29503]: Lame server on '203.0.74.212.in-addr.arpa' (in '212.in-addr.arpa'?): [128.250.1.21].53 'MUNNARI.OZ.AU'
Mar 8 11:43:25 swammie named[29503]: Lame server on 'compatible.nl' (in 'nl'?): [192.36.125.2].53 'SUNIC.SUNET.SE'
Mar 8 11:43:25 swammie named[29503]: Lame server on '203.0.74.212.in-addr.arpa' (in '212.in-addr.arpa'?): [192.36.125.2].53 'SUNIC.SUNET.SE'
Mar 8 11:43:25 swammie named[29503]: Lame server on '203.0.74.212.in-addr.arpa' (in '212.in-addr.arpa'?): [203.37.255.97].53 'NS.APNIC.NET'
Mar 8 11:43:25 swammie named[29503]: Lame server on '203.0.74.212.in-addr.arpa' (in '212.in-addr.arpa'?): [193.0.0.193].53 'NS.RIPE.NET'
Mar 8 11:43:25 swammie named[29503]: Lame server on '203.0.74.212.in-addr.arpa' (in '212.in-addr.arpa'?): [192.16.202.11].53 'NS.EU.NET'
Mar 8 11:43:25 swammie named[29503]: Lame server on '203.0.74.212.in-addr.arpa' (in '212.in-addr.arpa'?): [192.93.0.4].53 'NS2.NIC.FR'
Mar 8 11:43:25 swammie named[29503]: Lame server on '203.0.74.212.in-addr.arpa' (in '212.in-addr.arpa'?): [198.6.1.83].53 'AUTH03.NS.UU.NET'
Mar 8 11:43:28 swammie named[29503]: Lame server on 'compatible.nl' (in 'nl'?): [193.176.144.2].53 'NS.DOMAIN-REGISTRY.nl'
Mar 8 11:43:28 swammie named[29503]: Lame server on 'compatible.nl' (in 'nl'?): [192.16.202.11].53 'NS.EU.NET'
Mar 8 11:43:28 swammie named[29503]: Lame server on 'compatible.nl' (in 'nl'?): [192.93.0.4].53 'NS2.NIC.FR'
Mar 8 11:43:28 swammie named[29503]: Lame server on 'compatible.nl' (in 'nl'?): [198.6.1.82].53 'AUTH02.NS.UU.NET'
Mar 8 11:43:28 swammie named[29503]: Lame server on 'compatible.nl' (in 'nl'?): [193.176.144.130].53 'NS2.DOMAIN-REGISTRY.nl'
Mar 8 11:43:29 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [202.153.114.101].53 'M.GTLD-SERVERS.NET'
Mar 8 11:43:29 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [198.17.208.67].53 'F.GTLD-SERVERS.NET'
Mar 8 11:43:29 swammie named[29503]: Response from unexpected source ([193.0.0.193].53)
Mar 8 11:43:30 swammie named[29503]: ns_forw: query(compatible.nl) All possible A RR's lame
Mar 8 11:43:33 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [203.181.106.5].53 'B.GTLD-SERVERS.NET'
Mar 8 11:43:33 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [198.41.3.101].53 'G.GTLD-SERVERS.NET'
Mar 8 11:43:33 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [205.188.185.18].53 'C.GTLD-SERVERS.NET'
Mar 8 11:43:33 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [210.132.100.101].53 'J.GTLD-SERVERS.NET'
Mar 8 11:43:33 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [208.206.240.5].53 'D.GTLD-SERVERS.NET'
Mar 8 11:43:33 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [192.41.162.30].53 'L.GTLD-SERVERS.NET'
Mar 8 11:43:33 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [198.41.3.38].53 'A.GTLD-SERVERS.NET'
Mar 8 11:43:34 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [213.177.194.5].53 'K.GTLD-SERVERS.NET'
Mar 8 11:43:34 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [207.200.81.69].53 'E.GTLD-SERVERS.NET'
Mar 8 11:43:34 swammie named[29503]: Lame server on 'ns.enigmavoice.com' (in 'com'?): [192.36.144.133].53 'I.GTLD-SERVERS.NET'
Mar 8 11:43:35 swammie named[29503]: Sent NOTIFY for "0.0.10.IN-ADDR.ARPA IN SOA 2001022301" (0.0.10.IN-ADDR.ARPA); 1 NS, 1 A
Mar 8 11:43:36 swammie named[29503]: Sent NOTIFY for "babeforce.com IN SOA 2001012901" (babeforce.com); 2 NS, 2 A
Mar 8 11:43:36 swammie named[29503]: sysquery: query(ns1.easyraq.nl) All possible A RR's lame
Mar 8 11:43:36 swammie named[29503]: Sent NOTIFY for "tattooshop-hilversum.nl IN SOA 2001022301" (tattooshop-hilversum.nl); 1 NS, 1 A
Mar 8 11:43:39 swammie named[29503]: sysquery: query(ns.enigmavoice.com) All possible A RR's lame
Mar 8 11:43:39 swammie named[29503]: Sent NOTIFY for "saiyan-power.com IN SOA 2001030601" (saiyan-power.com); 1 NS, 1 A
Mar 8 11:43:40 swammie pppd[30966]: sent [LCP EchoReq id=0x7f magic=0x1217681c]
Mar 8 11:43:40 swammie pppd[30966]: rcvd [LCP EchoRep id=0x7f magic=0x486c6ef]
Mar 8 11:43:40 swammie named[29503]: sysquery: query(ns.enigmavoice.com) All possible A RR's lame
  • pjottum
  • Laatst online: 23:14
pjottum
¯\_(ツ)_/¯
Je draait vast geen primary dns voor die domeinen, wat het inhoudt is dat de andere partij zich niet goed aan de dns standaard houdt. nmap eens naar de betreffende server en ontdek daar een nt doos, weet je meteen het probleem. :)
Ik draai dus wel Primary dns.. da's dus het vage. ik doe helemaal geen secondary/slave DNS.
maar heb wel de secondary DNS op een paar domains naar een NT doos laten wijzen met SimpleDNS erop... dus jij denkt dat het probleem daar zit?
Het ziet eruit alsof je DNS-server alle queries forward naar andere DNS-servers.
Heb je alle root-dns servers wel goed erin gegooid?
Ik heb zelfs een nieuwe file opgehaald van internic. ik neem aan dat je de root.hints bedoeld?
Yep die bedoelde ik (tenminste als daar bij jou alle root-dnsservers instaan). Ik heb hem bij mij geloof ik anders genoemd.
Het lijkt erop alsof hij zelf geen DNS-lookup kan doen en gewoon alle lookups forward om de een of andere wazige reden.
Ik heb slechts heel af en toe een dergelijke foutmelding, maar dan ligt het toch echt aan de DNS-server aan de andere kant.
Waardoor dit bij jou komt zou ik niet precies durven zeggen in ieder geval
hmmz.. ik denk dat ik vanavond maar eens bind ga deinstallen en dan een clean dns opbouwen..
dank voor je hulp! :*
Tja ik heb weinig gedaan, maar goed:)
Anders kun je ook eens je zone-files posten, zodat er na gekeken kan worden
  • pjottum
pjottum
¯\_(ツ)_/¯
nou .. ik heb het hier ook, bij een heel normale installatie van bind. Dus ik denk niet dat het aan jouw server ligt, maar aan de andere kant. Je zou even kunnen kijken of je hem wat minder mondig kan maken, of in een aparte file laten loggen. Hoe .. man named :)
Het lijkt me toch niet dat de DNS-servers van o.a. RIPE en EU etc lame zijn!!
Ligt meer aan een fout in de eigen configuratie lijkt me zo
laten we maar hopen dat de fout bij mij zit zeg ik dan maar :) als de fout aan de andere kant zit kan volgens mij elk moment internic ploffen |:(
