Wat betekend EEPROM ???
  • F0kke
  • Laatst online: 02-07-2025
!!! ATTENCION !!!
! DO NOT RUN PHONE WITHOUT EEPROM !
1.MOVE THE EEPROM OUT THE PHONE (WITH CABLES)
2.TURN ON PHONE WITH ANY SIMCARD
3.DESOLDER EEPROM FROM PHONE (PHONE MUST STAY ON)
4.READ THE EEPROM AND SAVE IT
5.UNLOCK READED FILE WITH THIS PROGRAM
6.WRITE! PUT IN PHONE
7.DIAL <- * * <-
8.DIAL NCK : 00000000
9.PHONE SAYS: WRONG NCK
10.TURN OFF PHONE
THAT'S ALL
THANKS FOR SPEAR ;-)
Ik heb dus geen idee wat EEPROM betekend. Het gaat hier om een Ericsson T18s. Wat betekend het?
  • havana
  • Registratie: Augustus 1999
  • Laatst online: 09:25
electrically erasable programmable read-only memory
EEPROM (electrically erasable programmable read-only memory) is user-modifiable read-only memory (read-only memory) that can be erased and reprogrammed (written to) repeatedly through the application of higher than normal electrical voltage. Unlike erasable programmable read-only memory chips, EEPROMs do not need to be removed from the computer to be modified. However, an EEPROM chip has to be erased and reprogrammed in its entirety, not selectively. It also has a limited life - that is, the number of times it can be reprogrammed is limited to tens or hundreds of thousands of times. In an EEPROM that is frequently reprogrammed while the computer is in use, the life of the EEPROM can be an important design consideration.
A special form of EEPROM is flash memory, which uses normal PC voltages for erasure and reprogramming
van www.whatis.com
DIT IS MIJN WEBSITE
  • havana
Trouwens, leer de werkwoordsvormen is
het is : "wat neukT" dus ook: "wat betekenT"
DIT IS MIJN WEBSITE
